Question about Apex Digital Apex 23" Class 720p 60Hz LED TV - White LE2312W
Where can I find the original base stand?
Lost my base stand but not the piece that screws onto the TV. Where can I get a new or used one of that stand?
  • Apex Digital Master
  • 3,320 Answers
TV manufacturers do not make spare parts. You could contact a retailer in your are and see if they have a damaged unit they could scavange the part from. Otherwise you could make a sketch and have the part made in a machine shop.
Posted on May 15, 2014
2 Suggested Answers
  • 718 Answers
SOURCE: I lost my manual for
You can download a user's manual and others from;
http://safemanuals.com/user-guide-instructions-owner-manual/APEX%20DIGITAL/LD3249-_E
Click on the pdf icon on the right part of the page.
Posted on Feb 17, 2011
I lost the 4 short screws for my sharp aquos tv stand model lc 52d62u.i need to know the exact size to replace them.
Google is your friend
This is very late (4 years) but may help someone some day. For my Sharp LC52D64U stand:
Arm to base: 4 - M6 x 35mm
TV to arm: 4 - M5 x 16mm
BTW: base model CDAI-A418WJ36 fits just as well as the original CDAI-A376WJ32 and is usually cheaper on ebay.
http://www.avsforum.com/forum/28-tweaks-do-yourself/1004261-missing-sharp-aquos-screws-help.html
Jun 21, 2016 | Sharp Televison & Video
I have wall mount and now I need remove the pedestal stand from the TV. But I have lost the manual and can some body explain the steps to remove the stand? Thank you
Without knowing the model of your TV, it may be tough, but typically it's 1 or 3 types:
- the whole base is a single piece that slots into the bottom of the TV, with a clip release.
- the base removes from the stand, and the stand removes from a slot in the TV. This may be fastened with clips or screws.
- the base is screwed into the TV, and you'll have to remove these to remove the stand.
If that doesn't help, please provide more details, like the make and model of your TV.
Dec 18, 2014 | Televison & Video
Can I buy screws to fix base onto my umc tv
Yes The screws that you took off the back of the tv mount on wall brackects mounted on the back of your TV should be the same size
6mm
Oct 23, 2014 | Televison & Video
I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
1 PointsProblem with Toshiba TV Accessories I lost my screws that goes to my tv stand the base I lost my screws that goes to my tv stand the base Toshiba 40 inch tv were can find the screw
Nov 02, 2011 | Toshiba Televison & Video
How do I remove the stand from the 42HP95 TV
Most flat panels have a plastic cover that hides the bracket screws holding the base onto the back of the unit. Check to see if you can squeeze the plastic and make it unsnap from the back of the TV. There should be 4-6 screws holding bars of metal, likely two, that hold the base onto the TV. Some have a snap-in base, but most use screws.
tom
Sep 02, 2010 | Toshiba 42HP95 Television
Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
Mar 26, 2009 | Vizio VU42L 42 in. LCD TV
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
Tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Sep 01, 2008 | Insignia LCDTV26 26 in. Television
Apex Digital Apex 23" Class 720p 60Hz LED TV - White LE2312W Logo
97 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
