Question about Magnavox ZV450MW8 DVD Recorder VCR
Magnavox zv450mw8 vdr/dvd combo shuts off when placed in rewind more, otherwise works fine.
The unit plays tapes well and fast forwards and rewinds while playing with no problem. However, when I stop the playback and select the rewind mode, the unit shuts off. When I power it back on, it ejects the tape. Is this something easy to fix or should I replace the unit? Thanks for your help.
2 Suggested Answers
atang1
  • 734 Answers
SOURCE: Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Posted on Feb 21, 2012
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
Magnavox ZV450MW8 shuts off when trying to rewind.
Unplug the machine and pick it up and shake it, this will tell you if something is in there that shouldn't be or that something broke off.
So many things could be wrong that it is probably not worth fixing if it is not a foreign object inside.
May 15, 2014 | Magnavox ZV450MW8 DVD Recorder VCR
The VCR shuts off after just a few seconds of playing or rewinding or fast forwarding. The tape goes in, and when you push play (or any direction), the unit will try and play it and then it will shut the...
There is a part that is called an idler wheel assembly that is critical for play, rewind, and fast forward, and may have stopped working. The second possibility is that the drive belt that runs the idler assembly has broken or come off.
Jan 01, 2011 | Philips DVDR3435V/37 DVD Recorder/VCR
Rewind/fast forward not working right
Rewinding while playing (usually it's called "review") is different from regular fast rewind. The machine drives the tape differently. This is usually done with a gear, but older machines used rubber belts or drive wheels. As the rubber wears out they slip against the parts they are supposed to drive and the tape doesn't move. If I remember correctly most Emersons had one rubber wheel called an idler that caused this trouble.
If you'd like to try repairing the machine yourself, try a Google search for your particular model and "won't rewind". There are a number of parts sites and forums that may have detailed information about what needs to be replaced and where on your model.
If you don't feel up to doing this yourself, you might want to consider replacing the machine rather than paying for repair. At today's labor rates - assuming you can find a shop that even still takes VCRs for repair - a new combo VCR/DVD machine might be only a few dollars more than the cost of repairing your current VCR.
May 29, 2009 | Emerson Televison & Video
Magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
on vcr's if the tape is hard to turn the tape will sense this and reject the tape. Try to get a tape that you can feel turn free eaiser. I would rewind it to the middle of the tape so each side is equal and it would make the tape run easier. If it runs ok then the unit is bad and is too sensitve to the pull on the tape. This is all designed in the electronics and there is not much you can do about it then get return it if you can.
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Magnavox ZV450MW8 DVD Recorder VCR Logo
80 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
