Bush washing machine wh60.will not fill with water,water goes to machine,water valve ok ,door closes ok
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
  • 1294 Answers
SOURCE: Fisher & Paykel Washing Machine
Close your external inlet valve to the machine. Disconnect hose of washing machine from the valve; keep a bucket there and open the valve to see if water comes well. Next check the screens (filters) on the hose, clean well. This shd be done on both ends of the hose/s. Refit carefully. Check for leaks. If water still (don't forget to open the valve!) does not enter machine change the inlet valve of your wash machine. Can be done yourself. Rate me pl...........if helped.
Posted on Apr 26, 2008
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
TheMobilian
  • 8220 Answers
SOURCE: Water fill valve on Kenmore series 90 top fill washing machine
To get into the machine read THIS first.After you have accessed the innards then you can easily remove and check the water valve. . Hook the water up to the valve. Get a suicide cord and apply 120 vac to each of the coils and see if they open.
Posted on Jan 21, 2009
  • 159 Answers
SOURCE: Samsung washing machine J1045 water over filling
This sounds more like the inlet valve is being supplied with constant power when its not supposed to be.This is normally due to the old valve spikeing the PCB & now you are getting constant power supply to the new valve.I think PCB needs to be changed as well.OE error was an after effect of the machine over filling.
Posted on May 25, 2010
My bosch exxcel 7 washing machine do not fill up with water
First check the water inlet valve and check for continuity with a meter if that checks ok open the cabinet and check the pressure switch diconnect the clear hose and blow into it check for obstruction also blow into the pressure switch itself you should hear a click if that is ok and you still do not have fill the valve may be stuck in the closed position so change that part
Feb 07, 2012 | Washing Machines
Only get cold water entering washer ... no warm or hot
1. Close hot water valve behind washer.
2. Remove hot water line from washer side and place it in the drain.
3. Open hot water valve to ensure pressure and hotwater is ok in your drain.
4. If not, problem is home related.
5. If pressure and hotwater are ok, then see if your fill valve filter is clogged where you disconnected the hotwater hose attached to the machine.. Its called a fill valve. Sometimes they get clogged.
6. If the hot water side of fill valve looks ok with no blockage, then you might be looking at a new fill valve.
Feb 11, 2010 | Washing Machines
WHEN MACHINE IS OFF DOOR IS OPEN TO AIROUT
TWO LIKLY REASONS FOR THIS
1ST IS YOUR APPLIANCE CONNECTED INTO TRAP UNDER SINK IF SO MAKESHORE ITS NOT YOUR WASTE RUNNING BACK TO MACHINE
2ND INLET VALVE IS LEAKING-TO SOLVE THAT A NEW VALVE IS NEEDED
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HI - I was given a Maytag Neptune MAH5500B - just installed it and it does not work! It just makes a humming sound but after 7 minutes it is still not filled with water or rotating or anything. The door...
ok check to make sure you have the water turned on
thsat 7 mins is just about right
it is shutting down on slow fill
, the humming kinda tells me the water valve is opening properly
and calling for water
please check the screen and source
let me know
Oct 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Washer HELP
check for a sensor switch located underneath the door , its a safety device to ensure that door is tightly closed . hope it helps
Apr 18, 2008 | Washing Machines
Hotpoint washer Won't rinse
your cold water valve will be your problem or you've turned the water supply off, if the supply is not off put the machine on to the final rinse if it fills it will be the main rinse valve gone. The cold water valve is a double one with 2 solaniods. Unplug the machine turn water supply off remove fill hose there are 2 screws keeping the top on, remove them lift the lid off.undo the screws that keep the valve on, take note wiring and remove pull the black hoses off, replace with new one. The resistance of the valve will be around 3.4 kohms
Oct 07, 2007 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
