How do you stop floating pop ups - Computers & Internet
    Genius:
  • 1,342 Answers
Use AdBlock or Adblock pro for Chrome or Firefox.
Posted on May 16, 2014
Flooding xj900
Hi I had the same problem after rebuilding my CB900 carbies a few years back.
The floats hang down so far in the carb that they actually get stuck down even when the fuel flows in after a rebuild.
Turn the fuel on and tap the bowls with the handle of a screw driver (plastic) I used a long shaft screw driver that way you can pretty much get all of them from one side.
This light tapping jults the floats and it allows them to pop up with the pressure of the full bowls if helps with them moving.
Hope this helps.
Oct 06, 2014 | 1990 Yamaha XJ 900 F
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
800 vs carb overflows out breather tube when engine is started and it will not stop. Had both carbs rebuilt and when re-installed this problem started.
Sticky float valve. Tap gently on the side of the bowl with the handle of a screw driver. If it continues, they'll have to be popped off and the floats reseated.
Jul 05, 2011 | Suzuki Intruder LC 250 Motorcycles
My sump pump doesn't shut off, I am assuming it has to do with a float switch. It is a model number 506158..can I just replace the switch (where is it) or should I purchase a new pump. Thanks for your...
These units are normally factory sealed. You can buy a secondary float switch from a hardware store which intercepts the pumps power at the wall outlet and takes over the float switch duty. compare the costs as it may be more benificail to replace the pump
Jun 21, 2010 | Little Giant Submersible Sump Pump 2760...
Flooding out front cyl with fuel....rebuilt carbs with new seats and metering valve...floats checked out ok.....did not remove top covers and diaghram....hate to even ask but .....could a bad valve cause...
Theres a problem to the front carburator thus the flooding, the float pin is not sealing of the fuel supply once the bowl is full.You will have to reset the float, remove the bowl and operate the float manually( by your fingers lifting it to seal) letting the fuel to flow, if it stops thn for sure the float needs adjusting, if it doesnt stop the flow thn the pin is not sealing,you may have to replace the float pin.
Hope this helps!.
Knight (Yamaha seca XJ750R 1981)
Apr 17, 2009 | 1988 Yamaha XV 535 Virago DX
Toilet won't stop running
I have a Kohler toilet and Ingenium fill valve 85297-AA. My toilet kept running, the fill valve black cylinder wouldn't pop up and when I added blue food coloring to the tank, the blue color seeped through to the toilet bowl. First I replaced the flapper and that allowed the fill valve piece on the cylinder to pop up correctly and blue dye no longer seeped through to the bowl. I still heard a hissing sound when the toilet tank had filled and no water was going into the overflow tube. I called the tech support number on the Kohler website 1-800-4KOHLER (1-800-456-4537) . Here's what solved the problem: Turn off the water to the toilet.Take off the white cap of the fill valve by pushing it down and turning it counterclockwise as you would open up a childproof pill container. Then unhook the metal hook. Hold a cup upside down (I used a strong plastic cup) over the part of the fill valve that is left in the tank and turn on the water. (You need the cup because otherwise the water will squirt up to the ceiling.) The water will flush out the fill valve. Replace the cap and the hook and flush.
Nov 28, 2008 | Home
Float problem with Hoover Steam Vac Deluxe
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Dec 16, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Red float keeps popping up
You need to clean the debris channel. Put the machine on a waist high flat surface open it and remove the dirty water container. You will see three vertical screws which lock the scroll above the motor to the clear plastic panel at the front of the machine. Open these screws and remember which one belongs where. To the left of the scroll, there is a black horizontal screw which should also be removed. If you look closely, you will see the right hand of the first three screws (brushes face to your right hand) has also released the plexiglass (clear plastic screen where you see the dirt and soap flowing at the left side. Now put the machine on its side and look at the front edge of the plexiglass just ahead of the brushes. There are two screws which have to be removed - one on each side and bingo the plexiglass shape lifts clear. Clean out the muck, check the scroll channel for similar muck and reassemble.
The muck is plugging the dirt path and fooling the red float that the tank is full.
Re assemble the reverse of the disassembly procedure. Do not use a power screwdriver as you will likely shear the screw heads.
Good luck,
AMSW
Nov 10, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
