Question about Riccar Vacuums
Riccar supralite makes a loud rattling noise like the roller is banging around
  • Riccar Master
  • 1,320 Answers
If the noise is not something in the brush roll or the brush roll bearings or shaft is damaged the impeller may have something stuck in it or it may be broken.
Posted on Jan 03, 2015
SmartAlec
  • 171 Answers
SOURCE: Loud rattling noise.
Hi there SmartAlec from NelsonVacuums.com.au here. Often when an upright is making a rattling noise it can be something caught in the roller and every time the brush turns it knocks against the body and since it turns really fast it can sound quite bad. Take the roller out and clean inside that area and see if that helps. Hope it does. Happy Vacuuming :)
Posted on Sep 03, 2009
Vac Belts
  • 701 Answers
SOURCE: Dyson Makes a loud noise like something is impeding the
I would try changing the belt. Even though the belt may look fine it can be stretched or worn and that can cause loud noises. You can get dyson belts here:
http://www.vacbelts.com/dyson.htm
Posted on Oct 28, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: I have a Filter Queen
Hi there, as per your information i guess its a problem of power transformer. He can't supply the proper power in the motor & thats why the noise will come from the transformer. Thanks & waiting for your feedback.
Posted on Feb 22, 2010
Dysonteam
  • 167 Answers
SOURCE: loud noise from brush roller
Hi its Darran at Dyson.
Maybe worth checking the brush bar and cleanerhead for a blockage or for any damage.
If you cannot find a problem, please call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 15, 2010
  • 377 Answers
SOURCE: Our Riccar SupraLite Upright Vac used to glide
Suggest you check the wheels to see if they are moving freely. Also check the beater brush to see that it is moving freely. Be sure the belt has not broken. If it has, replace with a new one. Also take the time to clean the beater brush of any debris and spray a little WD40 on both ends of the beater brush axle.
Posted on Sep 12, 2010
Have a bagged Biss ll Powerforce vacuum that has started making a loud rattling noise under the base of the motor compartment. Noise is louder when using the hose. Suggestions? Thank you!
Something broke or got sucked in and is trapped in there. Put it up on a table and take the bottom apart, it's time to clean the roller anyway :)
Nov 02, 2016 | Vacuums
How do i replace the fan on a riccar rsl3 vacuum cleaner?
RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Feb 20, 2016 | Riccar Vacuums
Why does my riccar supralite vacuum makes a loud rattling noise like the roller is banging around?
You have something wrong with your brush roll or you have damaged the fan. Remove the brush roll and belt and turn the vacuum back on, if the noise is gone it is likely something wrong with your brush roll, if the noise persists you probably have a broken fan. You have to remove the motor and fan housing after removing the top cover, unscrew the bolt holding the fan on and install a new fan (you can get one from any Riccar or Simplicity vacuum dealer)
May 15, 2014 | Riccar Vacuums
Replace electric cord on Supralite
From Which brand you machine ?
Oct 15, 2013 | Riccar Vacuums
I need to replace the belt on my Riccar supralite vacuum and need instructions
Lay the vacuum upside down, remove the bottom plate, remove the brush roll and belt, install new belt around motor shaft and brush roll, pull on brush roll to stretch belt far enough to drop brush roll back into place.
Aug 14, 2013 | Riccar 8955 Upright Vacuum
Loud noise coming from cyclonic cap
sounds like you'v lost a rubber seal check this diagram on the link below see if you can see anything missing
http://www.vacpartswarehouse.com/Dyson-DC24-Upright-s/3888.htm
Apr 01, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Riccar supralite sounding rough
it could be the bearings at end of brushbar,take belt and brushbar off and see if it's ok, if ok would sudjest replaceing bearings
http://www.riccar.com/ftp/whitepapers/RSL_SupraLite_OwnersManual_8-08.pdf
Mar 22, 2013 | Vacuums
Our Riccar SupraLite Upright Vac used to glide across the floor so easily, but now we have to push it pretty hard. This just recently started. What can be wrong?
Sep 12, 2010 | Riccar 8955 Upright Vacuum
Aug 03, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Vacuums Logo
96 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
