Question about Timex Watches Field - T49905
Reset timex t49905 circuit board - Timex Watches Field - T49905
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
I recommend getting it to watches repair shop
but if u insist remove the battery and but it back
Posted on May 15, 2014
Is there a reset button on my timex ws4
Yea, but it isn't a button. This is probably two 'pads' on the circuit board within the movement of your watch that need to be 'shorted' together with metal tweezers. Consider a watchmaker.
Oct 06, 2012 | Timex Expedition WS4 WideScreen 4...
No alarm, chime, or beep battery is hew, all displays are working, just no sound.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 22, 2010 | Timex T5E231 Ironman Triathlon 100 Lap...
Even after changing the battery, the display fades on a Timex.
It sounds like a short circuit somewhere in the watch. A visit to the authorised dealer sound necessary.
To find your nearest dealer go to "casio.com" click on "support" , then from the menu on the left, click on "repair and service" to find your dealer or service center.
Feb 09, 2010 | Timex Sports Ironman Triathlon 100-Lap...
I have a Timex expedition chronograh. Every thin
The nice thing about Timex is they have a 12 month warranty that covers just about everything. If you have had the watch longer....
Get the batteries checked. Battery life is typically about 2 years.
If the battery is fine then you can try having the watch reset but in most cases the LCD board or circuit board is damaged the watch has to be replaced to have it function correctly.
Sep 16, 2009 | Timex Expedition 84601 Wristwatch
I recently had my battery changed on a timex expedition adventure tech altimeter watch, now the chime doesn't work and the alarm doesn't beep. Please help. Thank you.
You can attempt to have the circuit board reset if it has an "AC". This may or may not fix the problem. Usually when a sound board goes out you have to replace the whole circuit board or movement.
Sep 14, 2009 | Timex Expedition Adventure Tech Altimeter...
It stops for a few minutes then runs well again
The problem that you have is with the watch's circuitboard. Inside this circuit board you have what is called a quartz chrystal, which transmits direct pulses to the circuit board, as for the watch to run properly. And as it is not at all possible to regulate or adjust the function of the crystal's pulses, which itself is integrated in the circuit board, there is no other way than to replace your watch's circuit board.
P.S. If you do not have the necessary watchmaker's knowledge to fix this yourself, you will have to find your nearest watch repair shop, and ask for help.
Please rate if this was helpful.
Jul 30, 2009 | Timex Expedition T41261
After replacing a battery in a timex ironman with data link, they tell you to short the ac pad and the vss pad. Were are those points located?
You will find them on the module itself.
So after replacing the battery look on the PCB (printed circuit board) for the letters"AC" and "VSS". Adjacent to these markings there should be little contact points (probably gold or silver looking in colour)
Use a paper clip or similar and bridge (short) these two points simultaneously. Please rate my solution.
Jul 26, 2009 | Timex IRONMAN Triathlon Data Link T53722...
Random display resets of TIMEX Ironman Triathalon(100 lap memory)
Hello RLOWE803,
While I was looking for pictures specific to resetting this watch, I came across your post and thought to reply. I recently replaced the batteries on my watch, which I have owned for nearly 7 years. It is an Ironman Triathlon 100 Lap watch. When I replaced the batteries this time, I forgot to reset, in essence reboot the system, by using a metal needle point tweezers to briefly connect the positive side of the battery to the "AC" pad on the small circuit board for at least 2 seconds. I remembered to do this with at all the other times I had replaced the battery and did not have any troubles after it. This time I forgot and now have the same issue you described. I am not sure where the "AC" pad is on the back of the module. But, it should be apparent if I did it correctly in the past.
Give that a try before sending it off to be repair and wasting time, money and trouble.
Good luck,
CAZ
Jul 22, 2009 | Timex Sports Ironman Triathlon 100-Lap...
Expedition Indiglo Waterproof 50m
how much is this worth my uncle gave it to me
Jan 17, 2008 | Timex Expedition 40141 Wristwatch
Resetting Watch
Here's the inside of my Timex Expedition Dive watch. To reset the watch after replacing the battery, press down with a small screw driver on the metal tab that the red arrow is pointing to.
Nov 20, 2007 | Timex Expedition 84601 Wristwatch
Timex Watches Field - T49905 Logo
48 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
