Question about Sharp Comfort Touch AF-R120EX Air Conditioner
Sharp AF-S100FX Comfort Touch Air Conditioner not working
I was using my AC unit last night and it worked just fine, I turned it off myself. This afternoon I wanted to use it again but the power button had no effect on the system. I can adjust the "Timer" and "Temperature" and it shows up on the LED screen, just no noise and no air is coming out. Also, I restarted the the unit and every time after the reset the timer amount displays. I can't seem to turn off or turn on the system, it is stuck on displaying the timer. I cleaned filter, pressed on/off button while plugging it back in, restarted, and no avail. What could be wrong? Again, they system shows the LED screen, I can see timer(and adjust it) I can mess around with the temperature as well. The issue is, the On/Off button has no effect on the system and no air at all is coming out.
  • margie posada
    margie posada May 15, 2014
    NO error message whatsoever. (NO E1 message)
  • 552 Answers
You may have it in a timed mode. Here are the instructions for your unit. There will be a start delay if it is in timed mode. My Retrevo My Manuals
Posted on May 15, 2014
5 Suggested Answers
KOakaKO
  • 135 Answers
SOURCE: Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Posted on Aug 02, 2007
  • 674 Answers
SOURCE: Sharp AF-S125FX air conditionaer doesn't work when I plug it in
Sounds like there is something grounded inside the A/C unit or a fan or the compressor locked up. Could also be a motor winding in the compressor or one of the fans shorted thru.
Posted on May 02, 2010
  • 3 Answers
SOURCE: I have a Sharp Comfort Touch AC displaying E-1. ??
This is a reminder to clean the air filter. It happens every 720 hours of operation. Here are the steps to get it back up and running:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
Posted on Jul 26, 2010
bobicehouse
  • 1524 Answers
SOURCE: we have an E1 code
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Posted on Jul 22, 2011
What is thru wall for comfort touch?
Never heard of it. Maybe it is an air conditioner that is built into the wall and works in two rooms.
Aug 25, 2014 | Sharp AF-S100FX Comfort Touch Air...
My sharp comfort touch air conditioning 12,000 BTU FS-S125FX-A does not cool any more. It's running but at room temp.
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
Aug 07, 2011 | Sharp Comfort Touch AF-R120EX Air...
I have a Sharp Comfot Touch AC - AF-121208W that I inherited from my brother years ago. I do not see a "drain" but can see water inside the unit. How would I get the water out? I do not see...
The unit will have a small amoount of water in it just make certain that it is tilted tot he ouside to help it drain. check the filter and clean it while your at it . let me know
Jul 23, 2011 | Sharp Comfort Touch AF-R120EX Air...
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
Air conditioner will only run a short time then shut off.
Manula or online site will tell you what e-1 is, I would think it is a power outtage reading and unit needs to be reset. Dont be afraid to call your units manufacturer and ask tech how to reset unit with an E1 error.
Jul 07, 2010 | Sharp AF-S100FX Comfort Touch Air...
It turns off
The e1 code is a demand to clean the filter. It means the unit has been running for 720 hours. It does not mean anything is broken...unless it hasn't been running for 720 hours. That would mean the "clean the filter" timer is broken! There are 2 reset methods.
1) Unplug the machine. Hold down the power button while plugging it back in and wait until it beeps (for about 5 seconds). Let go of the power button. Unplug the machine again, then plug it in and try to use it as an air conditioner.
2) Unplug the machine. Hold down the Mode button while plugging it back in. Keep the mode button pressed until it beeps (for about 3 seconds). Let go of the mode button. The machine will start. Turn it off by pressing the power button. Resume trying to use it as an air conditioner.
If neither of these work, the "clean the filter" timer is broken and needs replacing.
Jul 23, 2008 | Sharp AF-S100FX Comfort Touch Air...
Aug 02, 2007 | Sharp AF-S120FX Air Conditioner
Sharp Comfort Touch AF-R120EX Air Conditioner Logo
188 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
