I am installing a S1-43101972100 control board to replace Evcon 2702-310/A. Where do I connect the M1 wire from the blower motor and where do I connect the COM & 24VAC wire on this board?
The old board has an locations for these wires to be plugged but the new board does not have an location.
  • 549 Answers
There is a wiring harness for this conversion. i have included a link to a source. It may be difficult to find a schematic to make this conversion and safer to use the harness. Control Board S1 43101972100
Posted on May 15, 2014
  • 1 more comment
  • Tax Fletcher
    Tax Fletcher May 15, 2014
    Yes I have the wiring harness, however those three wires don't have an connection on the board.
  • Hjalmer Lamminen
    Hjalmer Lamminen May 16, 2014
    If that is the case then the board must be set up in a way that you don't need to hook up those wires or it would have come with instructions on how to do that.
  • David Seeger
    David Seeger Sep 22, 2014
    Tax Fletcher did you ever figure out where to hook up the M1 wire? I am in the same exact situation as you. I have installed the board and also the wiring harness (which has a 12->9 pin and 6->4 pin wiring converters). There is a "park" on the new board where I am thinking I should put M1. On the old 2702-310 board I noticed the M1 contact was simply soddered to the back and didnt go anywhere - as if it were stubbed out. Is this what "Park" does on the new board? Thank for any help!
My control board is indicating a pressure switch stuck open.
You might want to see if the switch still shows continuity when the vacuum line is disconnected. Try touching the two switch wires together.
Nov 21, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Where do the 3 wires from the blower motor connect to on the control board for high speed use in the summer time? Black, Blue, and the Red one? The white is a no brainer. I can go to M1, cool, and heat....
Hello, the black wire is your high sped motor tap and it should be on cool as you have it. Blue is med-hi and red is your low speed motor tap. You have it wired correctly. Now the freezing can be caused by 2 things, low airflow or a low refrigerant charge. Low airflow can be caused by a dirty air filter, dirty evaporator coil, dirty blower wheel or the blower itself is running slow due to a weak capacitor. Anytime the motor is changed out the capacitor should aswell. If the airflow appears to be ok then the unit is low on refrigerant.
Jul 11, 2012 | Heating & Cooling
Fan wired directly to L1 runs constantly. no schematic on inside of cover. 5 wires from blower motor, brown to M1 yellow to M2 and black piggybacked to L1, white to neutral, others not hooked up. terminal...
Sounds like this unit was worked on in the summer and has a bad control board so the tech jumped it out till a control board was available . Take the black "high speed" and place on fan terminal to confirm. Get a new board and replace wire for wire you should take a picture first,and the plus are the easiest to find there spots so start with them.
Jan 03, 2010 | Heating & Cooling
Konica minolta bizhub 162 have error C0000(main motor malfunction) i try with another motor but same thing! any ideas?!
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Nov 30, 2009 | Office Equipment & Supplies
Error code c-5102 in Konica minolta c252
Here’s your GEEK-steer …
This thread appears to cover the solution to your problem related to error "C5102: Main Motor’s failure to turn":
http://www.copytechnet.com/forums/konica-minolta/15515-c252-m1-operation-test.html
In addition, here’s the link to “Bizhub C250P” related support downloads:
http://kmbs.konicaminolta.us/content/support/supporthome.html
Hope this helps, and please post back with a status report and/or any further assistance you might need.
"Today's the best day of my life...and NOW you're part of it!"
Dec 15, 2008 | Konica Minolta bizhub C250 All-In-One...
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
352 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
