Question about Briggs 20 & Stratton Toro Craftsman Lawnboy Snapper Lawnmower Air Filter 491588
Runs but will not pump water - Briggs 20 & Stratton Toro Craftsman Lawnboy Snapper Lawnmower Air Filter 491588
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Impeller is bad
Posted on May 15, 2014
How do I stop pump from running? Cistern connected pump does not seem to be pressurizing. Pump not cutting off, and getting hot.
Pump probably needs to be serviced. It probably pressurizes a tank and when that tank reaches a pressure the pump is turned off. But just guessing.
May 27, 2015 | Plumbing
How to change a water pump on a 2003 ford windstar
the water pump is run by the serpentine belt. i know on some 3.0s they had the water pump run by a secondary belt that runs the fron cam. which ever it is, remove the belt by the tensioner pulley and remove the water pump pulley. unbolt the water pump and slide it out. may require removing the upper intake. if the water pump is hard to reach from the top, try removing the plastic fender wells and getting to it from behind the tire.
Jan 10, 2014 | Cars & Trucks
What's the difference between in-line and submerged water pumps?
There are many differences between the two of them in the way they run but the main difference is the in-line water pumps run outside of water and stay dry the whole process and submerged water pumps run underwater usually in the sump of your filter.
Aug 09, 2012 | Fish
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
Onga water pump not pumping water thru to house
either water lock or motor burnt out ,
Mar 17, 2012 | Plumbing
Our pump was running dry for at least a day because a leak dropped the water level below the skimmer. it runs on 220 and sounds like it's running but no water movement in or out. i need a new pump, right?
not necessarily if running may need to be bleed[air bound and need to let out air ]or may need to be primed if there is a bleeder on pump housing un- screw to release air until water runs out --- if still no water pumping may have damaged the impeller depending on ur pump may have to only replace impeller or pump housing
Jul 20, 2010 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Water is not pumping throughout pump
It means your pump was running dry. Running your pump dry normally damages the mechanical seal.
However, you may open and fill the priming port full
with water. Using the gate valve, set it at full close and
start the pump running. Then, open the gate valve two
full turns to stabilize the water flow. Send your e-mail
for further assistance. Thank you and God bless U.
Jul 29, 2009 | Plumbing
Briggs 20 & Stratton Toro Craftsman Lawnboy Snapper Lawnmower Air Filter 491588 Logo
54 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
