Question about Vehicle Parts & Accessories
Why is my car not starting toyota noah 2002?
Did a scan and the following codes where given p0105 malfunction,p0110,p0115,p0120,p1120,p01125 p1656,p 1755 malfunction,p1760,p1200.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
That\'s more codes at once then I have seen in a long time. Take it to a mechanic, serious serious internal engine problems
Posted on May 15, 2014
NO POWER TO SPARK PLUG toyota noah 2003 showing error code p0105, p0110, p0115. some one help me plz.
code p0105 refers to manifold absolute pressure (MAP) sensor/ barometric pressure (BARO) sensor--circuit malfunction===causes --wiring---MAP sensor--BARO sensor--ECM
code p0110 refers to intake air temperature (IAT) sensor--circuit malfunction===causes---wiring ---IAT sensor--ECM
code po115 refers to engine coolant temperature (ECT) sensor--circuit malfunction===causes---wiring--ECT sensor---ECM
Dec 25, 2013 | Cars & Trucks
2002 PT Cruiser CRD 2.2 Engine management light is coming on the dash after you drive for about 10 or 15 mins If you leave the car for about 2 hours the engine management lights goes out the codes are...
Take your car to an auto parts store and ask them to put a code reader on your car. They not only tell you what the codes are (see below) but also the most likely cause and most likely solution. Or Go Look up OBDII Codes
I personally would start by buying throttle body cleaner and having them show you where to spray it.
Code 1511: Idle Switch (Electric Control Throttle)Circuit Malfunction
Code 0070: Outside air temperature sensor -circuit malfunction
Code 0015: Engine Coolant Temperature Circuit Malfunction
Code 0010: IAT Circuit Malfunction
Oct 24, 2013 | Chrysler PT Cruiser Cars & Trucks
Toyota fault code p0105
Well po105 is a generic code for map sensor cicuit malfunction.The other 2 codes i dont have a listing for but a bad map sensor will cause grey/black smoke
Sep 01, 2012 | 2002 Toyota Land Cruiser
Code po120 mazda protege 1.5 L..code po110...code po115.....code po195
P0110 DTC - IAT Circuit Malfunction
P0115 DTC - Engine Coolant Temperature Circuit Malfunction
P0120 DTC - TPS A Circuit Malfunction
P0195 DTC - Engine Oil Temperature Sensor Malfunction
Hope this helps to identifiy.
Oct 04, 2011 | Cars & Trucks
HAVE CODE PO420 IN MY CAR NISSAN ALTIMA 2002 2.5
this is a common code on nissans and it is due to the O2S1 sensor reading that the cat is operating below threshold-can be
- Three way catalyst converter Bank 2
- Engine Control Module (ECM) Program
- Exhaust tube
- Intake air leaks
- Fuel injectors may be faulty
- Fuel injector leaks
- Spark plugs may be faulty
- Improper ignition timing
most of the time it can be corrected by a nissan dealer, by reprogramming the stringent maps in the ECM, and the put out bulletins saying they would cover it if under 80,000-8 years, so that is not going to work-check the other possible issues then make calls to the dealer and see if you can get them to treat you like a future customer instead of a bother.
Apr 19, 2011 | 2002 Nissan Altima
I JUST WANT THE CODES FOR CHEVY TRAILBLAZER 2004...
  • Feb 7/11 - P0405
  • Jan 11/11 - P0336 - P0326
  • Dec 28/10 - P0217 - P0218 - P0163 - P0230 - P0231 - P0232
  • Dec 9/10 - Trouble Codes: P0170 - P0173 - P0162 - P0154 - P0142
  • Dec 6/10 - More DTC articles: P0157 - P0158 - P0160 - P0200
  • Nov 30/10 - DTC articles posted: P0505 - P0156
  • Nov 18/10 - More new articles: P0143 - P0144 - P0146 - P0147 - P0152
  • Nov 12/10 - P0120 - Throttle Position Sensor/Switch A Circuit Malfunction
  • Nov 11/10 - ECT Circuit Codes: P0116 - P0117
  • Nov 10/10 - P0111 - IAT Circuit Range/Performance Problem
  • Nov 7/10 - P0110 - Intake Air Temperature Circuit Malfunction
  • Nov 6/10 - P0108 - Manifold Absolute Pressure/Barometric Pressure Circuit High Input
  • Oct 21/10 - P0216 Injection Timing Control Circuit Malfunction
  • Sept 11/10 - Knock Sensor DTCs: P0327 P0332
  • Mar 15/10 - P0607 Control Module Performance Code
  • Mar 4/10 - P0606 PCM Processor Fault DTC
  • Feb 10/10 - New ECT Sensor article
  • Feb 9/10 - P0012 & P0022 - Camshaft Position - Timing Over-Retarded
  • Feb 2/10 - P0115 - Engine Coolantmag-glass_10x10.gif Temperature Circuit Malfunction DTC
  • Jan 19/10 - P0105 - MAP/Barometric Pressure Circuit Malfunction
  • Feb 10, 2011 | 2004 Chevrolet TrailBlazer
    Volvo S40 Error code P0110 and P0105
    there is two sensors that those code refer too. The map sensor, and the iat sensor. and both would have an effect on gas mileage. Both sensors would just make the car run a rich mixture.
    Oct 16, 2008 | 2004 Ford Focus
    Vehicle Parts & Accessories Logo
    74 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
