Question about Vehicle Parts & Accessories
Any ideas wot my code is ? m162428 - Vehicle Parts & Accessories
2007 Dakota wont start; fuel gauge reads empty, but I put 5 gallons in it to make sure it wasn't empty. Any ideas?
run the fault codes
reasons for not starting are
broken timing belt /chain
cam/crank position sensors wot working
immobilizer inoperative
problem ignition control module
failed coil/s ECM fault
no fuel pressure ---faulty pressure regulator
faulty pump
gear not in neutral or park
Sep 30, 2016 | 2007 Dodge Dakota
Hi, im merlin. I own a 04 reg. 125 T 280, if i
Hello there,
Fault codes below
P0251 Injection Pump Fuel Metering Control "A"(Cam/rotor/Injector)
P12XX Fuel and Air Metering
No idea what it means but obviously fuel / fuel pump /injectors problem
Sep 19, 2014 | Cars & Trucks
Vauxhall zafira 1.6 petrol 2008
fix the faulty sensor indicate by the code . Change the quality of fuel you are using ( higher octane rating). Pinning is detonation cause by incorrect air/fuel ratio and timing and is associated with the wrong octane rated fuel
Jul 05, 2014 | Brodit ProClip for Vauxhall Zafira B 2005...
I wot my codes to werk
work? There's usually a special menu for that.
Oct 28, 2012 | Nintendo DS Lite Pink Console
2000 sonata starts but will not run except at WOT. changed temp sensor, crank sensor, throttle sensor and cam sensor. Same problem remains. any ideas?
u keep doin that n ull be on welfare-never parts replace to solve a problem always get opinions and facts 1st-should of had it code scanned for free a discount or zone-theres still time--hav u been givin it tuneups n fuel area service?
Sep 01, 2009 | Hyundai Motor 2002 Sonata
Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
Apr 11, 2008 | Bosch Washing Machines
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
