Question about Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer
How to load staples in the stanley-bostich 66760?
3 Suggested Answers
  • 6 Answers
SOURCE: I can't load staples in a borrowewd SX150 stapler
check the crown size. some are 9/16 others are 1/2
Posted on Dec 01, 2009
  • 1383 Answers
SOURCE: air leaks around green cylinder at trigger area
Your nailer uses a trigger valve (part # tva6 cost about $20) and is sold at www.bostitch.com or generic valves sold on ebay . If you have a source for orings, you could try to repair the valve. Remove the roll pin that holds the trigger to expose the tva6 valve. There are roll pin/pins that hold the valve in just above the valve in the body. Remove these pins and apply air pressure to gun to pop-out the valve. Use caution when you do this. Remove nails, lower pressure to gun and use glove or rag to catch valve because it could come out with force. With tva6 valve in hand remove two pins that hold valve together and remove inner plunger. The middle oring on plunger is cause of leak. Try using an oring about same size as the broken seat. It must fit pretty tight to work. If you had a small leak it could be that the firing pin orings fit too loose or just too worn. Use silicone lube or oring lube on the orings and the valve port. Good holidays.
Posted on Dec 02, 2010
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
How do I unjamb a stanley heavy duty sharpshooter
Hi, You do it very carefully. Take the refill chamber apart and remove all staples or nails. If one is jammed remove it. When all is clear reload and try. Good luck
Jan 12, 2015 | Heavy Duty Stanley Bostich Heavy-duty...
I HAVE A STANLEY BOSTICH ELECTRIC STAPLER,WHEN YOU CLOSE THE DRAWER WHERE THE STAPLES GO YOU GET A KNOCKING NOISE
I recommend that you will post your question under the correct category (Stanley Office Supplies) and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
Oct 04, 2012 | Stanley Electric Desk Stapler, 45 Sheet...
Setting staples too deep
The depth is set by the bumper and the bumper spacer. Are you sure these were put back in? the air pressure only makes a small difference on the depth...
Mar 11, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Staples not coming out
yes they are, I would double check the guage and shape of the staples for this tool to ensure they are correct. If you give me the model number I will find what guage you need and get back to you.
Oct 25, 2009 | Stanley Tools & Hardware - Others
Aug 31, 2009 | Stanley Air Tools & Compressors
I AM HAVING TROUBLE OUT OF MY BOSTITCH MIIIFS FLOOR NAILER
D Farley,
I repair these nailers all the time. Anytime the nail or staple is bending you have 2 causes. Either the stapler has a broken blade, the magazine is loose on the foot gate, or you are shooting into plywood over concrete. that is allowing the staple to hit the cement subfloor. Use 11 /2" staples on 3/4" wood floor over 3/4" plywood when over concrete.
Dec 16, 2008 | Stanley Bostitch MIIIFN Flooring Nailers
Bostich nail gun plumger not retracting
spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
Nov 27, 2008 | Heavy Duty Stanley Bostich Heavy-duty...
Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer Logo
46 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
