Question about LG WM1814CW Front Load Washer
Why is thesoap dispenser of lg washer not dispensing ?
  • 3 Answers
SOURCE: LG Front Loading Washer overflows at detergent dispenser
you mean where you put the regular HE soap in? That slot is normal to overflow. The water carries the soap down (Lift the little doohickie up, it's removable for powder deterg.), and it carries it all the way to the tub...Unless i don't get it...but I'm reading the phrase "Its like the water will not go down to the tub.", and it makes me think the whole tray is overfilling with water..if this is the case, I can't help you, but filling over of the Main HE Soap tray is normal. (Just a little, if the whole thing starts filling uncontrollably, hit the power button.)
Posted on Mar 14, 2007
  • 69 Answers
SOURCE: LG WM2233H Washer
Most likely the small electric motor that moves the water injection pipe on to the various outlet mainifolds has stripped its plastic gears, afraid the only solution is a new soap dispsener assembly
Posted on Oct 01, 2007
faggly
  • 74 Answers
SOURCE: lg wm-2277 dispenser tray
Hiya Vanch... disconnect the electric.. remove the lid screws at the rear.. slide from the front to the back with lid.
Depress the tab at the top of the drawer "gently" whilst easing the drawer from the machine.
Refit lid.. connect up to electric.. Sorted!!
Regards Faggly
Posted on Mar 19, 2008
MNTECH
  • 1543 Answers
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
Posted on May 23, 2009
SOURCE: Bleach remains in bleach dispenser after washing and even after extra rinse cycle
I put the bleach in with the load right on top of the whites, so I dont have bleach left in the dispenser for the next load. Seems to work okay.
Posted on Jun 10, 2009
OMy front load LG washer is gushing water from the detergent dispenser!! Repair suggestions???
Some washers are designed to flush the detergent dispenser to eliminate residue after each wash cycle.
Feb 02, 2015 | LG 3.9 cu. ft. Front-Load Washer, Metallic...
I have LG washer less then 1 yesr old and bleach is not dispensing from dispenser
You may have one of 3 issues. The dispenser valve is not working for the bleach dispenser, the control board is not feeding power to the dispenser valve or the dispenser drawer is not draining the bleach properly. You will need an authorized LG technician to help you with that.
Good luck
May 30, 2011 | LG WM2701HV Washer
The bleach dispenser did not dispense bleach during Tub Clean cycle. The drawers were clean (only have had washer 3 wks)
I just called LG and they said for this model WM2101HW the bleach will only dispense from the soap dispenser during the tub clean cycle
Apr 16, 2010 | LG WM2101HW 4.0 cu.ft. Washer
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Bleach dispenser
RU SURE ITS NOT WATER NOT BLEACH ,,THERE WILL ALWAYS HAVE WATER IN THAT DISPENSER
Nov 25, 2008 | Washing Machines
Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Nov 25, 2008 | LG WM-2277HW Front Load Washer
LG Tromm Not Dispensing Bleach
My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
Nov 24, 2008 | LG WM-2277HW Front Load Washer
Problems with LG WM-2277HW Front Load Washer
It is a rare problem but I've seen it happen.  The only way to resolve this issue immediately is to remove the top of the washer to gain access to the dispenser.  The dispenser can be disassembled by unsnapping the top section where the hoses are connected.  Once the top section is lifted, you can safely pull the drawer out.  Not sure what happened but more than likely the water dispenser has warped downward causing it to jam the drawer.  Recommend replacing the dispenser to resolve this problem.
Jul 23, 2008 | LG WM-2277HW Front Load Washer
LG WM1814CW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
