Question about Kenmore Refrigerators
Sa 6400 Two weeks ago the freezer of my Kenmore refrigerator stopped keeping ice cream frozen. This week it stopped keeping anything frozen so I emptied the contents and found the right side blower vent iced over. I defrosted and removed the ice blockage but after 24hours I only have a moderately cool freezer. Is it finished or is there a fix?
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 650 Answers
If you just removed the ice from the front of the panels there is still a lot ice behind the panels. A complete defrost will be necessary. You may have a defrost problem. If you remove the panels you could check the defrost heater for continuity. if it is good then the defrost thermostat or timer could be the culprit.
Posted on May 17, 2014
catriver
  • 878 Answers
SOURCE: freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Posted on Aug 28, 2006
  • 1314 Answers
SOURCE: Kenmore Refrigerator not cooling well.
you have a defrost problem there are three compontes to the defrost systems the defrost thermostat the defrost timer and the defrost heater now when you open the freezer door you should hear a fan running now bear with me on the lower left hand side of your freezer compartment around where the wheel is at the bottom of the cabinet you should see a round hole where a strange plastic screw head is turn that slowly to the right till the freezer fan stops now the timer is in defrost in your freezer compartment remove the lower panel and you will see the evaporator looks like an aluminum honey comb now you will see a heating element like in a stove that's your defrost heater and clipped on one of the tubes you will see a small dome shaped disc one wire coming from fridge one wire going to the heater element ok if you turned the defrost timer till the fan stopped and by this time the element isn't on then take the defrost thermostat out of the loop by un plugging the fridge for safety then unplug the defrost thermostat from the heater and the other side from the fridge .Plug the heater to the fridge where you unplugged the thermostat and if the heater comes on after plugging the fridge back up you have a bad defrost thermostat but for real folks the timer and thermostat usually fail close so close together i recommend just replacing them both at the same time . now while your chasing down the parts if you need to save your food can take a hair drier and after removing the back panel in the freezer melt all the ice there will work good for about 4 days before freezing again
Posted on Jan 15, 2008
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
  • 306 Answers
SOURCE: frigidaire freezer not freezing ice cream
The freezer temp settings are not low enough or you are getting ready to have a poblem with the defrost circuit.
Posted on May 06, 2009
  • 2128 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
Freezer light, ice maker, and ice/water dispenser stopped working
did you replace the light . or just tighten it . and is ice cream soft . it sounds like the tempt is above 15 deg . and needs to be colder . this may be a control problem . but ck the little things first . clean the coils / make sure inside fan and under neath fan are going . re ck control settings . .. if problem does't go away . then look at control ..
Jul 29, 2010 | Frigidaire Refrigerators
My freezer doesn't keep ice cream frozen more than a couple of hours. Other foods are frozen, but some slightly 'soft' frozen. Up until a couple of weeks ago it would produce ice cubes regularly. Now if I...
YOUR DEFROST TIMER MAY BE BAD OR THE HEATERS ARE BAD. WHAT HAPPENS IS THE EVAPORATOR IS FROZE OVER WITH ICE AND CAN'T TRANSFER THE COLD . UNPLUG THE FRIDGE FOR A FEW HOURS (HAVE RAGS AND MOP READY) AND IT WILL WORK AGAIN TEMPORALLY . THE LESS YOU OPEN THE DOORS THE LONGER IT WILL LAST.. BACK IN THE DAY IT WAS CALLED DEFROSTING THE FRIDGE AND WAS DONE ONCE A MONTH OR SO
Jan 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Cuisinart Ice Cream Freezer Bowls Not Freezing Anymore
I would take the freezer bowls out of the freezer, run them both under the sink to thaw both bowls out, dry both bowls thoroughly, and then set them both on the counter so that the liquid settles toward the bottom of the freezer bowls. After 1 hour, place the bowls FLAT back into the freezer - don't forget to wrap them in a plastic grocery bag or some other sort of plastic bag. Try to make ice cream again after 24 hours or more of freezing. Let me know if this works, so I can pass the good news along to others.
Aug 03, 2009 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Kenmore Refrigerator cooling fluctuating
IS this unit a frost free? I'm wondering if the motor in your timer is running slow.If that happens it could take too long before the freeze cycle comes back on. Or check the terminator out. Either that or check the electric to make sure nothing shuts off the unit like a timer for the lights.
Jun 10, 2009 | Kenmore 64802 Top Freezer Refrigerator
Frigidaire freezer not freezing ice cream
May 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer way too cold - ice cream hard as a rock
The freezer may get as low as -18 degrees F or 0 F this is the point when life and bacteria stops growing.
Ice cream shouldn't be that cold unless it is whipped with air.
Feb 27, 2017 | Kenmore Refrigerators
Freezer not keeping things frozen
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Jun 12, 2008 | Freezers
I have the same problem and from reading on the web I think I have found the problem. It is a bad Freezer Thermistor and they are very inexpensive. I am posting a link that can help you determine if this is the problem.
I found some service instructions for Kitchenaid side by side fridges with electronic control. Since both your fridge and KA's are made by Whirlpool, the instructions should apply. I learned something new, there are TWO thermistors! To download the instructions go to Service Matters Online click on technical reference, then next pge click on I accept, next page click on technical library [left sidebar], next page click on job aids [left sidebar], next page click on search job aids [upper middle of the page], next page type in refrigerator then click on search, next page click on KA side by side electronic control [KAR-10], next page click on the pdf symbol, then print out the document.
Feb 08, 2008 | Kenmore 72073 Top Freezer Refrigerator
Water freezing at bottom of freezer, food not freezing
maybe? yeah but have you checked that the drainage hole is is clean and clear from any trapped dirt, that is sometimes a major problem, it stopped my freezer from functioning for weeks!! but the day i cleared it the water was gone, and the freezer was working as good as new!
Dec 22, 2007 | Maytag 23 cu. ft. Side-by-Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
