Brother mfc 495cw
I cant get the scanner to work when the ink cartridge is empty. How do I resolve this?
  • 1,087 Answers
That seems obvious - put a new cartridge in! I believe the system says you can't use the scanner if you can't print the result. Annoying but . . .
Posted on May 15, 2014
Mix-it-up
  • 832 Answers
SOURCE: MFC 210C Ink Problems
Steve,
did you watch the display after replacing the cart?
Very often the machine asks if you have changed the cart and demands an answer (1 for yes).
You can try to do an update of the firmware, too. Go to www.brother.com , choose your country and then your machine. Download a small update tool and run it.
If it aint getting better:
Do unplug from power outlet (even though you have done already) wait 10 Min. leave scanner cover open and take all carts out. Plugin to power again and leave scanner open. Wait uintil machine gives a warning signal. Reinsert carts and close cover: now watch the display and give always the answer YES(1).
Posted on Mar 04, 2008
  • 21 Answers
SOURCE: Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Posted on Nov 05, 2008
bob_computer
  • 3153 Answers
SOURCE: not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Posted on Aug 22, 2009
pineworks
  • 4041 Answers
SOURCE: Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 04, 2010
How do you remove mfc-495cw printer head
This is a common problem with Brother ink jet units. Cleaning the head will not fix the problem. Call Brother at 1-877-brother and tell them your unit is "missing black" on prints. They will probably cover this problem under a special warranty for this problem at no charge to you.
Sep 04, 2012 | Brother Mfc-495cw
How to remove brother mfc 495cw printhead
You can download the manual here: <a href="http://www.pdfsnatch.com/2013/05/brother-mfc-495cw-manual/">Netgear n300 manual</a>
May 14, 2012 | Brother MFC 490cw Color Inkjet...
I cannot find the slot to replace ink cartridges! Brother LC61CL
Which Brother all-in-one printer or copier do you have? The LC61CL cartridges fit MFC-255CW, MFC-290C, MFC-295CN, MFC-490CW, MFC-495CW, MFC-5490CN, MFC-5890CN, MFC-5895CW, MFC-6490CW, MFC-790CW, MFC-795CW, MFC-990CW, MFC-J410w, MFC-J615W and the DCP-165C . The cartridges could fit other printers as well.
I know that the MFC_795CW has a cover on the right hand side that you need to open when the unit is on. Then the cartridge carrier will move to the ink changing area. (For a new printer, there is a green protector in place that you need to pull out. Keep this in case you move the printer later.) This location applies for the DCP-165C copier as well.
If the unit is on but the cartridge carrier does not move to the opening of the ink cartridge cover, then something may be blocking the carrier from moving. This could be a scrap of paper or other foreign object blocking the route.
Brother has the support for most of their printers available here: http://www.brother-usa.com/Support/ . There is a specific link for just the manuals on the page as well.
More complete trouble-shooting guides are available if you search for your model from the Brother search box at the top right hand corner of the page. Go to the product details page and then see the Brother Solution Center links on the right hand side of the page.
I hope this helps.
May 05, 2011 | Brother Office Equipment & Supplies
I installed a new black ink cartridge(lc61bk) on a brother mfc-495cw and now nothing is printing.
Check out if you've installed it correctly. Also check out other ink cartridges, are they empty? If yes you won't be able to print anything. However, if all ink cartridges are OK then try to reset the printer or reinstall the drivers. You can find help in MFC 495cw users manual
Feb 27, 2011 | Brother MFC 490cw Color Inkjet...
My Brother MFC-495cw will not print. It pulls paper through but nothing prints.
This is due to the ink...Check you ink cartridges if they are still full of if the ink has dried out thats wht printing is not working
Jun 11, 2010 | Brother MFC 490cw Color Inkjet...
My Brother MFC 495 cw scanner won't work
Hello i just bought a Brother MFC-495CW printer and for the life of me cannot get wireless to connect even though i have setup everything correctly as far as i know. Any help would be appreciated.
Dec 16, 2009 | Office Equipment & Supplies
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
Open the new ink cartridge bag for the color shown on the LCD,
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 210C series ink replaced
The brother machines require ink in all the cartridges as it is always flushing ink through the heads to "clean" it. This means you must have ink in all cartridges at all times unfortunately or the brother will not work. Even if you could somehow get it to work it could damage your printhead anyway.
Good Luck
Please rate my advice, good or bad.
Feb 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
19 people viewed this question
jasbo
jasbo
