Question about Xante Ilumina Digital Color Press Printer
Yellow registration problems on xante 502
I can't get the yellow to register wit cyan, magenta and the black
  • 3 Answers
Clean all the registration sensors on the imaging drums and at the fuser end (there are 3 under a shifting piece of white plastic on the left side after transfer belt is removed.
Posted on Jun 03, 2014
  • 6 Answers
SOURCE: Xante cl30
If the printer is still under warranty, and a new yellow drum doesn't fix the problem, or if you install a new drum and the problem returns, Xante should provide you with warranty support. This problem can be caused by a defective high voltage power supply, and that is not a user replaceable item.
Posted on May 28, 2008
  • 6 Answers
SOURCE: Poor registration on Xante CL30 HSE
Make sure the drums are properly seated in their cradels, and if posible, avoid designing with white small text in heavy solid areas that are made up of process colours. For reverse type in a black background, use spot color black rather than rich black. Other than than printing on a not as heavy card, that is about all you can do.
  • 202 Answers
SOURCE: Registration of colors. The magenta
When you get to registration mode, press enter, then execute will appear, then press enter. Then display will say adjusting. Remember magenta, cyan and yellow register to black. If registration is still bad you need to remove the four drums and transfer belt. To the left you will see a plastic move it to the left and you will see a white plastic with two sensor one at each end. This clear plastic get dirty and then you have bad registration. Clean it with a Q-tip. This two sensors are locate just below the left of the transfer belt, one at each side. This usually get dirty with residue of toner.
Posted on Apr 01, 2010
SOURCE: what is the price of xante 502?
13000$
Posted on Apr 26, 2011
SOURCE: Good day
Most of the times the color background is a drum issue. The bigger the temperature, the more you will see this effect. There is a setting in the printer's menu, it's call BG Setting. Print the configuration menu to find it.It reduces or increases the background toning. Try this.
Posted on Nov 02, 2013
How do i adjust the color to color registration. the yellow on my machine is a bit off set
you have misregistration issue? go to printer's menu in calibration, in adjust registration and press enter. it will check the position of the drums. make it 2-3 times. if the result is the same, remove the drum and clean with some alcohol the drum's contact inside the machine. also clean with a cloth the LED surface, maybe it has some toner on it.
if again you have problem, see if you have any old used yellow drum to check.
May 02, 2014 | Xante Ilumina® 502 Laser Printer
When i print make lines on paper
make a file with 4 squares, each one full color. 1 magenta, 1 cyan, 1 yellow, 1 black. if the problem is drum, you will see which one
Sep 04, 2013 | Xante Ilumina Digital Color Press Printer
My HP 6500 only prints yellow and black. I refilled all three color cartridges and only the yellow is working. Any ideas?
This printer having four cartridges and two print heads.Each print head having two pens, black, yellow & magenta,cyan. As you said yellow & black are OK.. So replace Magenta & Cyan print head..
Oct 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
Type of catridge epson stylus R390 uses can't find
You can see the reference on the cartridge itself.
Take it with you when you buy new ones.
Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
Registration of colors. The magenta and cyan are alittle offset from the black. I can get into registration mode but do not know which keys to hit to adjust.
Jul 06, 2009 | Xante Ilumina Digital Color Press Printer
248 people viewed this question
Top Xante Office Equipment & Supplies Experts
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
