Question about Kitchen Ranges
The oven on my Rangemaster 110 Dual Fuel cooker is not reaching the set temperature.
I have fitted a new upper element but the problem persists. The temperature struggles to exceed 150 degrees C
    Loyalty:
    Visited the website for 30 consecutive days.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 18 Answers
As I am just taking a shot in the dark to help you on this one. test your sensors with a continuity tester to make sure the normally open is not closed and vise verse with normally closed not open if it is not a sensor use schematics to see what is suppose to be closed (shorted or just working properly )or open (no connection) most of the time it is something simple so dont go out and buy a bunch of stuff until you have tested to make sure that is the problem.
Posted on May 16, 2014
SOURCE: Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Posted on Jan 17, 2008
grandadfixer
  • 99 Answers
SOURCE: Rangemaster 110 Fan runnig slowly
Needs new fam assembly.We can supply parts if req.woolleysltd@yahoo.co.uk
Posted on Nov 05, 2008
SOURCE: RANGEMASTER 110 Cooker FLAME FAILURE DEVICE fitting
My progress to date (20090127):
1 Turn off the gas supply to the oven
2 Turn off the electricity supply
3 Remove the oven linings
4 Remove the storage drawer
5 Remove the three screws holding on the bottom trim and the trim
6 Crank up the front roller
7 Pull out the oven carefully making sure the gas hose and electrical lead are long enough and not caught
8 Working from the rear of the Rangemaster, for the right-hand oven, remove the four screws on the corners of the large cover plate at the back of the oven about half way down on the left-hand side as viewed from the back.
9 Remove the cover plate.
10 Go to the front of the oven. Above the burner assembly, towards the left is a thin metal rod running front to back. This is held in place by a clip at the back and by the hole in the metal frame at the front. Remove the metal clip at the back using a pair of long-nosed pliers. Retain the clip.
11 This should release the metal rod (flame sensing device) and you should be able to push it through the hole and out at the back. It is attached to a long copper wire.
12 Go to the back of the range. You should be able to work the wire back through the hole in the rear metal plate and up to the gas valve. The wire is held in place at the gas valve by a bent clip on the rear right. Carefully bend this clip back towards the oven to release the wire.
13 The wire goes down under the gas valve and to a threded bolt end into the bottom of the gas valve ad the bolt is held in place using a locking nut.
14 Remove the locking nut using a small spanner. The threded bolt should now turn, with the aid of long-nosed pliers.
15 The next trick is to remove this threaded bolt on the end of the copper wire and I have not figured out how to do that. It will unscrew a good way but becomes tight and will not come out, as though something inside the valve is holding it in place. Could it be that the flame sensing device has to be removed and inserted from inside the gas valve? If so, what a daft piece of engineering this is.
16 HELP.
Posted on Jan 27, 2009
ginko
  • 19396 Answers
SOURCE: Rangemaster 110 oven heats by itself
That happens either because the timer control is faulty, or because there is a contact on the element wires or connectors, and the element is grounded.
Control board and wiring harness are tested using a multimeter.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 17, 2009
  • 149 Answers
SOURCE: I have a leisure rangemaster 110 dual fuel cooker.
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me info@topoftherangeltd.co.uk
Posted on Mar 27, 2010
Why is my left oven of our leisure Rangemaster 110 dual fuel not reaching high temperature?
Your left hand oven is a conventional oven it has two heating elements one at the top and one at the bottom, if one of these is not working then the high temperature cannot be reached.
May 07, 2015 | Rangemaster Kitchen Ranges
Leaky door on Rangemaster 110 Dual Fuel
Hello John,
these doors open on the side, they have the hinges under and above, with screws, at least when they look like the ones in the link.
These hinges can be adjusted with the screws at the bottom.
I wish you good luck, Dik
Rangemaster 5779 Tecnik Range Cooker 110 Dual Fuel NG Stainless Steel Oven...
Feb 20, 2018 | Rangemaster 110 (Gas) Kitchen Range
I've a dual fuel 1100 rangemaster professional- when i use the ordinary oven i get a pool of water under it,what's causing this and what can i do to stop it
this condensation. and your cooker is removing the moisture in the air in the room. this if not fixed will rust your cooker from the inside out , you will need to fit an extractor fan to your room or if one already fitted get a larger one. or use a dehumidifier
Feb 27, 2010 | Rangemaster Professional 110 (Duel Fuel)...
What do I look for? Rangemaster Kitchener 110
Problem solved, took the back off the inside of oven and the element had a huge burn hole in it. Brought a new element from the local spares shop £17+vat. Easy to fit and it works better than ever.
Nov 13, 2009 | Rangemaster Kitchener 110 Electric Range
How to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
electrician
Regards
Sandra
Dec 15, 2007 | Kitchen Ranges
Left hand oven
The left hand oven needs a new flame failure device fitted , it is a normal oven not for slow cooking . This repair can only be carried out safely by a registered Gas Safe engineer . Visit WWW.gasSafeRegister.co.uk or ring freephone 0800 408 5500 to find one in your area.
Jun 02, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
