What is the answer to 5,439 rounded to the nearest thousand
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
5,000
Posted on May 16, 2014
  • 7993 Answers
SOURCE: ACME Skateboards Inc., has paid
Doesn't any body do their homework anymore? How are they supposed to learn anything?
Draw your graphs by hand or on a graphing calculator.
Think about the intersection points. (What does that mean when two curves intersect?)
Use the equation for the demand to obtain D for a particular x.
You can also determine by how much one function exceeds another for a particular value of the x variable (the graph is rather clear).
I assume you can solve a quadratic equation.
Use these hints to solve the problem.
Here is a graph. I even restricted it to the first quadrant so as not to mislead you into giving meaningless answers.
Hope it helps.
Posted on Oct 04, 2009
  • 7993 Answers
SOURCE: my ti 30 calculator always rounds to the nearest
To stop the calcultor rounding your answers to the nearest INTEGER, press [2nd][FIX] followed by a number other than 0. For exemple
[2nd][FIX] 3 will display the numbers with 3 decimal digits.
Hope it helps.
Thank you for using FixYa.
Posted on Nov 25, 2009
  • 7993 Answers
SOURCE: Everytime I put decimals into my calculator, it
Increase the number of decimal digits in display.
  1. Press [SHIFT][MODE] to access the {SETUP)
  2. Enter the number (6) corresponding to option [6:FIX]
  3. In screen that is displyaed, enter the number of decimal digits you want (2, 3, or 4). If you enter 0, all decimal numbers will be displayed as integers (rounded). If you enter 9, you will have long numbers but that is hardly ever necessary.
Posted on Feb 22, 2010
  • 7993 Answers
SOURCE: all of my answers show up rounded to the nearest
  1. Press [MODE].
  2. Highlight Normal, it is not highlighted already, and press [ENTER].
  3. Use DownArrow to move cursor to the second line.
  4. If you want to keep all possible decimals digits highlight float and press [ENTER], then press [2nd][MODE] (QUIT) to exit configuration screen.
  5. f you want a limited number of decimal digits (2,3, 4 or 5), highlight the corresponding number on 2nd line an press [ENTER], then [2nd][QUIT] to exit configuration screen.
Posted on Mar 02, 2010
SOURCE: i need to round 301,421,
Well that would be... 301,500,000 rounded UP, or 301,400,000 rounded down.
BUT the second answer, 301,400,000... is YOUR answer....
The nearest hundred thousand is 400,000... hence the answer, see?
Posted on Aug 19, 2010
Round 54,692 nearest thousand
"Round 54,692 nearest thousand"
Since 54,692 is 69.2% of the way toward 55,000, which is MORE than 50% past the middle of that thousand, then 55,000 is the correct answer!
May 08, 2017 | Office Equipment & Supplies
What would the answer be to the problem 39,000 rounded to the nearest thousand
To round a number, we first have to find the column in question. In this question, we need the thousands column, which has a 9 in it. Next, we go to the column immediately to the right. If the number is 4 or less, we don't add one to the thousands column and set all the numbers to the right to zero. If the number is 5 or more, we add one to the thousands column and set all the numbers to the right to zero.
In this case, the number in the column immediately to the right is a 0, so we don't have to add 1 to the thousands column, and rounded to the nearest thousand, we get 39,000.
Good luck,
Paul
Apr 18, 2015 | Office Equipment & Supplies
159.501 rounded to the nearest thousand?
Calculators usually have a position switch to do it for you.
Rounding Numbers to the Nearest Thousand - AAA Math
www.aaamath.com/g3_41cx1.htm To round numbers to the nearest thousand, make the numbers whose last three digits are 001 through 499 into the next lower number that ends in 000.
Feb 16, 2015 | Office Equipment & Supplies
Round 105,099 to nearest thousand
The question basically is whether 105,000 becomes 106,000 or not.
It would not round down below 105,000 because it is already higher than that. So we concentrate on the "tail" of the number 105,099 and ask whether 099 (essentially 99 more than 105,000) is more than half way towards 106,000. In order to do that, the "tail" would have to be at least 500 (i.e., half way towards 106,000) as in 105,500. Because 99 is less than 500 the answer is no, the "tail" is not big enough to round up the number 105,099 to 106,000. The answer to rounding 105,099 to the nearest thousand is that because the "tail" is less than half way towards 106,000, the number would instead would round down to 105,000.
Nov 05, 2014 | Office Equipment & Supplies
What is 82,596 rounded to the hundreds, tens, thousands, and ten thousands.
Rounded to the nearest hundred: 82,600
nearest ten: 82,600
nearest thousand: 83,000
nearest ten thousand: 80,000
Sep 17, 2014 | Office Equipment & Supplies
Round to nearest thousand
hello, if yonth place youur talking math then it means to make answer to thousandth place
ex 1.234
2 is in 10s place
3 is in 100s place and
4 is in thousandth place
so it is 1.234 to the thousanth
Apr 03, 2014 | Computers & Internet
Round to the nearest ten thousand
What is 22.2036033112 rounded to the nearest thousand
Jan 04, 2014 | ixl.com Computers & Internet
I need to round 301,421, 900 to the nearest hundred thousand can you help me?
Aug 19, 2010 | Casio MS-80TE Calculator
48 people viewed this question
jasbo
jasbo
