Question about Intertherm P3RA-048K Air Conditioner
Looking for a gas valve for a intertherm furance model no. mgh-055aacwl-06 ser.number mgh9009-00077
Out of a mobile home actuator valve not working
    Novelist:
    Champion:
  • 373 Answers
You need to contact your nearest a/c supply house. most company's that sale parts on line will not sale gas valves to the public due to liability.
Posted on Jul 01, 2014
  • 659 Answers
SOURCE: Gas Valve is leaking
I am a Nordyne dealer and you can replace your gas valve with a generic valve of your choice. You can try and find a supply house in your area that sells them or you can visit www.myhvacparts.com to find one.
Posted on Apr 05, 2009
  • 89 Answers
SOURCE: Intertherm MGH-056ABFC-91 won't kick on. Just
There is probably more than one limit switch. I'll have to get a wiring diagram of this unit. See if you can follow the wires from the wires from the limit switch and see if they go to another limit switch. Also you can put a jumper wire on the red wire and white wire on the unit outside and see if ti comes on.
Posted on Nov 03, 2009
SOURCE: 1990 Triple E mobile home
I've a similar problem and a new thermocouple solved it
J. N. Millet, Alberta
Posted on Jan 14, 2011
  • 37 Answers
SOURCE: I have an old Intertherm gas-fired furnace, Model
Sound like your blower motor is bad, but depending on the furnace age you could have an blower control board that has bad contacts. Need serial number or age of furnace,.Capacitors usually are not the problem, need to replace both motor and capacitor.
I
Posted on Nov 09, 2011
shastalaker7
  • 1515 Answers
SOURCE: i recently replaced my furance in my moblie home
Hi, most of the time, they tuck the manual in the heating section of the unit. Look around and you may find it. If you have then go with what Mike said to do.
Robert Horton
Posted on Dec 02, 2011
Looking for Intertherm MGH-075-ABWN-05 gas valve Model 36c67 type 177
WHITE-RODGERS Type 36C67 - Emerson
www.emersonclimate.com/Documents/White-Rodgers/instruction.../0037-5838.pdf
Type 36C67 complete gas control combines into a single compact package the functions of 3-position Gas ****, pressure regulator, 100% shut-off automatio pilot, main operator and Natural-LP Gas Selector. Termostat Circuit Current (24 V Model):. 0.23 Amps. Pilot Gas Outlet: Located at outlet end of the valve. Type of Gas:.
Need refurbished gas valve & tube - mobilehomerepair.com
https://www.mobilehomerepair.com > ... > Nordyne Service & Repair Feb 9, 2014 - The gas valve model is 36C67 Type177 part# is 6243700 ... Two are a electric oil radiator type & the other two are electric grid type. ... guys that you had to rebuild for me hoping it would solve my Intertherm model MGH-055-ABW36C67 gas furnace not heating up hot enough but did not resolve the problem.
36C67-175 - Hvac Controls - Amazon.com
https://www.amazon.com/Unknown-36C67-175/dp/B003WZWGDE Rating: 4.3 - ‎4 reviews
Product description. Robertshaw, Coleman, Evcon 24V, 1/2" x 1/2" inlet/Straight outlet, Dual Standing Pilot, Step Opening, Mobile Home, Gas Valve Replacement w/Two 1/2" Side Outlets & Reducer Bushing (1/2" x 3/8") ...Missing: intertherm
Apr 07, 2018 | Intertherm Heating & Cooling
I have a Intertherm furnace model# MGH-065-ABRN-05...The target burner needs to be replaced. I type in my model # and it isn't reconized. Is this a good number. Thank You
I don't think that is a good model #. Here is a link to their site and the furnace models there have a totally different type of #.
http://intertherm.net/Products/Furnaces/GasFurnaces.aspx
If you really need the burner, Id call Intertherm and then they can tell you what data plate you should be looking at.
http://intertherm.net/DealerServiceLocator.aspx
Jan 02, 2018 | Intertherm Heating & Cooling
I wonder if you have a picture of where the therm couple is inserted next to pilot for a intertherm mgh 055 furnace
try going to YOUTUBE and insert (intertherm mgh 055 furnace) in the search window for illuminating videos
Dec 22, 2017 | Intertherm Heating & Cooling
I recently replaced my furance in my moblie home an now o have a Intertherm gas furance and i would like to have owners manual with it it did not come with one thank yoiu
Robert Horton
Nov 06, 2011 | Intertherm P3RA-048K Air Conditioner
No problems, would like to find out the best way to remove blower for cleaning on an intertherm gas furnace mgh 075 ina mobile home
Generally ther is two screws at the base of the blower housing which hold it in place, remove the screws and pull, slide the entire assembly out. You will have to disconnect the electrical wiring to the blower and possibly the limit switch on the side if equip.
Aug 23, 2011 | Dayton Gas Furnace Heater
When I turn on my furance or ac the blower is always on even though the fan is set to auto. When it is on heat it never gives off any hot air, so it never warms up the house. I had someone look at it and...
If this is a mobile home furnace they usually have a two stage gas valve. Generally they just have a delay in opening fully and are convertable from L.P to natural gas or vice versa. It is a possibilty that the gas valve is bad. If so it will have to be replaced. First I would have someone check your thermostat to see if that is what is causeing the blower to run . does the burner ever light? I wouldsuggest that you hire a service tech. who is knowledgable on intertherm furnaces. I don't recommend anyone who is not trained to change gas valves,because of safty concerns. I hope this helps you some. Thanks
Nov 12, 2010 | Intertherm Heating & Cooling
Where are the furnace filters in my older furnace?
Open the door to the airhandling unit inside the closet by lifting upward on them. There should be two filters located on top of the A coil.
Dec 05, 2009 | Heating & Cooling
Apr 05, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm P3RA-048K Air Conditioner Logo
140 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
