Question about GPX ml861B 8gb
How do I turn it on?
Charger says full charge and button is turned to ON but not turning on, what do I need to push to turn it on?
  • GPX Master
  • 3,320 Answers
ML861B ML861B
This is why name brands cost more.
Posted on May 15, 2014
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
May 03, 2014 | Tablets & eReaders
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Razor ground force battery says its fully charged but gokart wont turn on
Here is the owners manual for the future (in case you don't have one.)
http://www.meijer.com/assets/product_files/pdf/1000422_groundforce_manual.pdf
It sounds like the push button fuse next to your charging plug. Push that in and try again. Otherwise it could be a wiring defect.
Aug 19, 2012 | Razor 300001-SL Ground Force Go Kart
Will not turn on, and will not charge, totally dead
Or if all you get is a green light when its plugged into an external charger, then you could have blown one of two Microchips on the charging circuit and to get it working again they will have to be replaced. If it has just become corrupt you can try resetting the tomtom
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for at least 15 to 20 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Exact location of reset hole is in the picture below
Aug 09, 2011 | Tomtom GO 300 GPS Receiver
Tomtom 720GO wont turn on
The problem was solved as described in my posting of Aug.15,2009
Aug 15, 2009 | Tomtom GO 720 GPS Receiver
I have a 1950 Pontiac Chieftan with a straight-8 engine. When I push the starter button I hear a click and a hum, but the starter won't turn over. Lights and horn work fine, so I think electrical system is...
if the battery is to weak it cannot turn the motor using the charger power .with a full charge battery and those problems bad starter or froze up motor. if you must have charger on it to have power bad battery
Aug 06, 2009 | 2004 Nissan Maxima
My iRobot scooba won't turn on after a full charge
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Jul 26, 2009 | iRobot 5800 Scooba Vacuum
My palm pilot m515 wont turn on or charge
try turning it on while its on the charger .. if that works then you might need a new battery .. if it doesnt then do a "reset" ... unscrew the top off the stylus and use it to push the reset button on the back (top center) ... if that doesnt get it going then you can do a hard reset but that will erase all your information (like telephone numbers and such) ... you do a hard reset by holding down the on/off button while pushing the reset .. if it works on the charger but quits when on battery then you need a new battery ..
Jun 27, 2009 | Palm m515 Handheld
Garmin does not turn on
Turn the on button at the top of the device o by pushing it to the left and hold in that position for at least 20 seconds. The device will reset and turn on. This has worked several times for me when the 780 has refused to turn on.
Nov 18, 2008 | GPS
Cell phone problem
try removing the battery, removing the sim, plug in the charger -> try turn on. Insert battery (no sim), plug charger -> try turn on Remove charger -> try turn on Insert sim/battery/charger -> try turn on.
Aug 14, 2007 | Nokia 6280 Cellular Phone
GPX ml861B 8gb Logo
37 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
