Question about Toshiba SD-6200 Multi-disc DVD Player
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
HARD DRIVE WORKS PERFECTLY BUT I CANT GET DVD DISC DRIVE TO WORK WHEN I PUT BLANK DISJK OR RECORDED DVD IN TO WATCH IT WILL NOT LOAD,LOAD MESSAGE APPEARS FOR SEVERAL MINUTES THEN MESSAGE APPEARS THE DISC CANNOT BE PLAYED OR RECORDED PLEASE CHECK THE DISC.I HAVE NOTHING WRONG BRAND NEW DISC
    Problem Solver:
  • 14 Answers
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Posted on Jun 23, 2009
Re DVDR pot tweak: 2 potentiometers on my Samsung DVD-R150 are labelled 'VR20High' & 'VR19Low', can anyone tell me 1 which is the DVD pot and 2 whether to turn the screw clockwise or anticlockwise?
if you have moved them needs an ohmn meter or osilloscope
they both a very narrow range so cant do much wrong by tweeking
i cant find anywhere to buy those two pentimeters in 2017
they could be dust effected
note where they are positioned
put both in the middle position and gently move them back and forth
then back to original position
Apr 16, 2017 | Samsung Televison & Video
Wont boot
go to BIOS and enable the secondary drive auto detect.
if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
Apr 02, 2009 | Intel Motherboard
Can't Record, wont read blank DVD
Have the same problem with this piece of junk.
Tried all the solutions. Clean lens etc. Nothing helped.
Tried replacing the drive with another that I had. No go, apparently has some proprietary firmware.
I was about to throw it in the trash when I suddenly realized that it had a TV tuner. Hooked it up to my computer through a Pinnacle Dazzle interface and VOILA I had a hard drive recorder. I either just watch it on my monitor or burn a DVD if it is something I want to keep. Hey that is better than pitching something you paid $300 bucks for in the trash. You can pick up a dazzle or similar on EBAY for a lot less than a new Hard disc recorder will cost you.
Jan 23, 2009 | RCA DRC8005N DVD Recorder
Dvd will not record
Hi and welcome to FixYa,
Initially, try to clean the lens using a CD disc cleaner. Additionally, verify that your blanks are either DVD-R or DVD-RW.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Samsung DVD-R130 DVD Recorder
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Drive cant write any disc
If the unit was working ok and suddenly the unit stop to read the blank disk, the problem could be related to a dirty lector (need to clean) or unit firmware (need to be updated)
In that case you can update your firmware here:
http://drivers.softpedia.com/progDownload/Matsushita-DVD-RAM-UJ-840S-104-Download-14615.html
Remember
1) You have to use a blank "recordable disk" to allow your drive write a disk
2) Not all disks are compatible
3) Try differents brand
4) Clean your drive lector
5) Update your firmware
Oct 24, 2008 | HP Compaq nx6310 Notebook
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Errors burning to 1x to 16x DVD-R
I have had much luck recording on off brand 16X discs as follows:
1) Record a "dummy" program on the hard drive, need only about 15 or 20 seconds.
2) Put a blank disk in drive, and COPY that dummy program to disk. Do not finalize.
3) After a minute or so, window will come up and say "Cannot
complete copy."
4) Now while above window on screen, click HOME MENU, COPY, New program list, Select your movie/program to copy, go ahead and finalize, and START.
5) Think you'll find this is successful, however there might be some brands of blank disks that won't work.
6)Let me know if it works for ya. JGIDUSKO@CFL.RR.COM
Jul 04, 2008 | Pioneer DVR533HS DVD Recorder with 80GB...
Toshiba SD-6200 Multi-disc DVD Player Logo
393 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
