Question about Ricoh MP-301SPF Copier : MP301
Reset the replace PCU on a Ricoh MP301
I have replaced the PCU, The Replace PCU does not go away
  • Ricoh Master
  • 3,320 Answers
  • 624 Answers
SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 17, 2007
  • 37 Answers
SOURCE: The PCU Reset procedure needed
switch the machine off at the switch hold down online and escape while switching on the switch , hold the buttons till you see service mode on screen , you need to go to engine , then drum , there you will find the setting to reset the pcu , or under data log is a function pm counter clear if it is giving you replace pcu on the screen
Posted on Nov 16, 2007
  • 37 Answers
SOURCE: Gettin a Error: replace Black PCU.
Hi yes you can fix it yourself it is just a warning that says the black pcu is almost warn out , but if the quality is still good you can clear the message is the sp modes by holding down online and escape whilst switching on the machine , under the menu "engine " is a sub menu called data log enter it and execute pm counter reset
hope this helps
  • 58 Answers
SOURCE: ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
  • 95 Answers
SOURCE: Ricoh fuser oil replace message
That is not a good idea. The oil is kept track of by counting pages, not by a sensor that measures the oil level. The oil runs out and the machine can't tell and now you have ruined the fuser. Which cost a lot more than the oil tank.
Posted on May 26, 2009
Printer is printing dark gray pages 2 weeks after replacing the PCU developer is getting all over the drum
Manufacture specific toner is usually the problem. Replace toner with manufacturer cartridge, or replace because it is bad. Take back to the store you bought it from.
Dec 18, 2014 | Ricoh Aficio MP3350
Ricoh PCU printing issue (black marks on prints)
Remove the ink carts and clean all the ink from the area that prints. This can also be a cartridge issue.
Jun 29, 2017 | Ricoh Office Equipment & Supplies
MX 351U SHOWING E7-90 ERROR CODE WHAT THE SOLUTION
This is a PCU PCB Communication error. 9 times out of ten it will reset by simply switching the machine off and then on again. If the problem persists here is the section from the manual that describes the possible causes and remedies.
E7-90
MFP - PCU PWB communication error
Trouble content
Detail
MFP
Cause
PCU PWB connector connection trouble. PCU PWB - MFP PWB connection trouble. PCU PWB trouble.
MFP PWB trouble.
Mother board trouble.
Check & Remedy
Check connection of the PCU PWB, the MFP PWB, and the mother board.
Check the ground.
Replace the PCU PWB.
Replace the MFP PWB. Replace the mother board.
I hope this helps
Good Luck
Follow me on Twitter @CDOS_Service
Jan 14, 2014 | Sharp Office Equipment & Supplies
Replace black PCU ricoh aficio cl3000
To replace the black PCU:
- Turn the printer off.
- Open the cover on the right side (as you're looking at the front of the printer).
- There are two green levers, one toward the front of the printer and one toward the back -- pull these out and lift the cover that they're holding all the way up (it should stay in place).
- Remove the black PCU by pinching the green lever and sliding the unit straight out.
- Take the new PCU out of the box, take off the tape around it and remove the cover on top of the unit.
- Align the new PCU along the rails the same way the old one was aligned (using the green arrow) and slowly slide it in. As you slide it in it will slide out of the bottom cover -- throw that cover away.
- Lower the PCU cover and slide the levers into place.
- Close the side door.
- Turn the printer on.
Mar 06, 2011 | Ricoh Aficio CL3500N Laser Printer
I have a Gestetner DSc38u and when I print colour I get a 'red'/'pink' line about an inch from the top of each page. Any suggestions?
If the line is only red or pink, it is most likely caused by the magenta PCU. Replace this PCU and your problem will go away.
Occasionally the magenta developer unit can cause a red or pink line, but the problem is more than likely from your magenta PCU. The PCU is easy to replace, and instructions will come in the box if you order an OEM replacement unit.
Jan 22, 2011 | Ricoh Aficio 3800CMF Laser Printer
How to clear the pcu code
The printer is set to display the "replace PCU" message after a set number of copies. The only way to clear the message is to replace the color PCU that the message mentions.
Apr 17, 2010 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio AP3800c--message to replace black PCU, have done same and still get message?
This must be done before drum is replaced.
Resets counter.
Start the SP mode and execute the
New Unit Set:
• PCU: SP5-999-001 ∼ 004
Feb 03, 2010 | Ricoh Aficio AP3800C Laser Printer
Ricoh aficio cl3500n reads replace colr pcu what is this?
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Ricoh MP-301SPF Copier : MP301 Logo
2,017 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
