Question about Sharp Comfort Touch AF-R120EX Air Conditioner
What is clean start - Sharp Comfort Touch AF-R120EX Air Conditioner
How do I operate my self-cleaning oven..no manual..
Thank you for your post, Pattie Cromie!
I see that you would like to operate self-clean on your Frigidaire range and you do not have the manual. Typically, to start self-clean you would need to push the button labeled "Self-clean" and make sure there is nothing inside the oven before starting a self-clean cycle. Also before starting self-clean close the door because of the temperatures that are created within the oven the door needs to be closed and locked. I hope this has been beneficial. -Matt
Oct 14, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Wont start when cold
check the wiring connection under the inlet manifold for your cold start injector and your cold start sensor. clean or dry it if dirty or wet. pull apart and clean.and clean the butterfly at your throttle with throttle cleaner.and clean your idle control valve piston may be sticking due to dirt.
Nov 16, 2013 | Volvo 760 Cars & Trucks
I have no instructions for my roomba 560 so dont know how to start it
Turning Roomba on and off • To turn Roomba ON, press CLEAN once. You will hear a beep and the CLEAN button will light. • To start a cleaning cycle, press CLEANagain. Roomba will start a cleaning cycle. • To pause Roomba, press CLEAN while Roombais cleaning. • To turn Roomba OFF, press and hold theCLEAN button until Roomba's lightsturn OFF.
Sep 21, 2011 | iRobot Roomba 560 Robotic Vacuum
How do I start the self cleaning? I hit clean and it does not start
On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
Aug 29, 2011 | GE JKP45 Electric Double Oven
It has a hard time starting, it will start, stall, start again, stall, then when I give it a little pedal as I try to start it, it will start, once it is started it runs great. could it be the ISC motor? I...
You are in the right area. First I would check that the throttle interior along with the plate itself is spotlessly clean along with the access passages to the ISC. I would remove the ISC and ensure the the valve likewise is spotlessly clean and has good freedom of movement. Plenty of clean cloths and WD40 spray help in the clean up. Make sure the electrical connector withe ISC is clean and tight with no breaks in the loom. Test the engine when all cleaned up and if the idle is still problem then, and only then, consider changing the ISC.
Feb 09, 2011 | 1993 Cadillac DeVille
Kenmore elite dishwasher - setting the default wash
Select the desired cycle. If you want to run the last cycle that
was completed, you can simply press START once to show which
options you used, then press START again to start that same cycle.
Jan 25, 2018 | Kenmore 24 in. 17482 / 17484 / 17489...
1995 honda cbr f3 wont start
I would think about investing in a carb re-build kit.
Dec 22, 2008 | 1998 Honda CBR 600 F(3)W
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Self clean
Usually the oven has to be locked closed with a handle on on the front door. This will activate a safety mechanism that will allow the cleaning cycle to start. If the safety switch is malfunctioning or the door is not closed properly, the cleaning cycle won't start.
Apr 20, 2008 | Ovens
Sharp Comfort Touch AF-R120EX Air Conditioner Logo
60 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
