Question about Troy-Bilt Pony Garden Tiller
How to remove pully from a TH 1002 rototiller?
    New Friend:
    Problem Solver:
  • 7 Answers
Hi without having it in front of me... Do you mean pulley or flywheel? There is a lot of good info out there especially UTube videos. I am thinking if its a pulley it should have holes in it that you can jam a screwdriver in to stop it from spinning, then use a wrench or socket to get nut off. Spray the heck out of it with brake clean or WD40 first. Remember, you break it you gotta fix it!
Posted on May 15, 2014
Troybilt Rototiller. Most likely the Pony model. Tiller is about 50 years old. Belt slips. I put on a new belt last year. Is there any adjustment of the pullies to tighten the belt?
On the engagement lever where it locks in.The lock block will wear on the bottom or the engagement lever gets bent.What we did was weld a brace to the engagement lever and maybe a little build up on the block where the wear is.
May 08, 2011 | Garden
It's at top dead centre on th crank the cam pully marks at top of head and inlet valve just on opening th dizzy pully marks are lined up with the crank locator when you look from th marks and have taken...
You have the wrong valve openong. To time an engine properly the Exhaust valve opens when you go past TDC, n ot the intake. The intake should be closing as you come up on TDC. Just pull the dizzy back out and give the engine one complete turn and put it back in. Hope this helps.
Jan 26, 2011 | Ford Futura Cars & Trucks
Where can i find drivers for hp pavilion dv5 1002 nr for windows xp?
Th HP support site should have all the drivers for their systems.
I also know that you can get all HP drivers with the driver finder program.
Mar 30, 2010 | HP Pavilion dv5-1002us Laptop PC
How to remove the fan blade in a 1998 suburban and replace it?
A Clutch FAN Requires the 4 Nuts/Bolts @ the Pully Bunched up in the Center Behind the FAN & In Front of Water Pump, Once Assmbly is Removed there are 4 BOLTS that Fasten the (FAN) to the CLUTCH assembly. It is Wise th REPLACE BOTH FAN & FAN CLUTCH ASSEMBLY AS A SET
Aug 28, 2009 | 1998 Chevrolet Suburban
I Cant put the belt back on for the blades how is it done
diconnect the blade housing from the deck adjustment lever leaving the back of the deck mounted this should allow you to have access to th pully's.also remove the pully shrouds from the top of the deck.(be sure to reinstall the pully shrouds at re assembly.hope this helps
Jul 11, 2009 | Husqvarna 19.5hp 46" Yard Tractor
We require help with a broken belt on the rototiller
bring the broken belt to napa auto parts or kragen ,,or go to www.managemyhome.com they can tell you where to buy or get it
May 20, 2009 | Garden
Transmission oil change.
"ue only G-L 4 gear oil having a viscosity of SAE 85W-140 or SAE 140"
Apr 21, 2009 | Troy-Bilt Chipper Shredder
Craftsman rototiller 3 5 model 917 299130 leaks
Sounds like you are speaking of the float bowl.
It should not have a hole in it.
You could purchase the part from Sears or a small engine shop.
If it were mine, I'd remove the bowl, clean it, and patch with a gasoline impervious material such as JB weld.
Apr 05, 2009 | Craftsman Garden
Troy-Bilt Pony Garden Tiller Logo
56 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
