Question about Brodit ProClip for Citroen Dispatch 2008 - 2012 Center mount
Oil leak in turbo, how bad is that??
Look like radiator is leaking and probably somewhere else, i think it looks like it is spraying
Why is gearbox oil getting into rhe radiator on my jeep grand cherokee 2003
it is probably not gearbox oil. it is probably transmission fluid because it travels through the radiator cooling tanks. the cooling tanks may have a leak causeing the fluids to leak into the radiator.
Aug 30, 2012 | 2003 Jeep Grand Cherokee
1995 Volvo 850 turbo Station Wagon. Turbo is spraying/ leaking oil on the engine and causing it to smoke. what are some solutions to solve this problem
one of the oil lines probably has a leak in going to the turbo maybe able to get the part from auto parts but most likely will be a dealer part
Feb 18, 2011 | Volvo 850 Cars & Trucks
How much work is it to fix a leak. it is spraying out anti freeze up by the motor. It looks like maybe the where the seal may go
If the leak is a hose, not a big deal. Drain antifreeze disconnect hose, instal new hose, refill antifreeze. If the leak is a water pump also not a big deal, same procedure.
If the leak is in the radiator, a bit more complicated. Radiator can be replaced or repaired by a radiator shop.
If leak is coming from somewhere else on the engine, could be more serious, like a gasket leak. If this happened you would get fluids mixing ( oil/gas)
Good luck. A Haynes manual is a good investment for your car.
Feb 05, 2010 | 1997 Oldsmobile Achieva
Duracraft oil radiator - oil leak
The leak can be repaired, it is probably the sealant has dried and cracked. A plumber can fix this, so can a mechanic, so can a gas engineer or experienced electrician. Phone round your local businesses to see who will do the job cheapest. Tell them the heater is leaking from the seal between the radiator body and the thermostat where it screws in - you just think in needs fresh sealant. Shouldn't be expensive, its a 20minute job, unscrew the thermostat, clean up the threads, dab on the sealant and screw it back together.
Jan 25, 2010 | Kitchen Appliances - Others
The turbo is whistling and oil is leaking from somewhere im just wondering if i need to get a new turbo or my solution was a pipe could be off somewhere
both sounds like a pipe is off or has perished where the oil has leaked onto it ,oil leak could be feed or return pipe ??need to jack it up and have a good look
Oct 30, 2009 | 2000 Volkswagen Jetta TDI
2004 VW Jett Turbo / Oil Light Blinks and making an alarm sound
you've either got low engine oil, or the sensor has gone bad, or you have a leak somewhere. The leak may not be visible if it's leaking into another part of your engine or into the transmission via the rear engine seal
Sep 16, 2009 | 2004 Volkswagen Jetta
1996 F-250 powerstroke the truck only has 150000 miless on it ans with no visible oil leaks but it uses oil or leaks it. its not bad around town but when i went on a 700 mile trip it used about 3 quarts of...
unfortunatly its probably an internal leak and the motor is burning the oil.this could br caused by leaking valve seals,bad rings or more likely bad turbo seals.add some lucas oil conditioner and see if that helps.to check the turbo pull the tube going from it to the inter cooler and look for oil. due the same on the exhaust side
Sep 14, 2009 | 1996 Ford F350 Crew Cab
Oil spray onto underside of cat...v70 2.4 turbo AWD. Possibly turbo oil return pipe, oil seperator is part of block........not the external black one.
there is a seal on t hr breather box that could be leaking if there is oil across the oil pan if it is only on underside of car then the turbo return is leaking that is most common probably 10 dollars for gasket and seal and easy to change
Aug 18, 2009 | 1998 Volvo V70
Nissan 3.0 Hardbody Turbo Diesel
Your description sounds like a waste-gate problem.
These are intended to prevent overpressure from the turbo and yours might be faulty.
The oil leaks may not be related to the other problem - Jeez, would love to own some vehicle that never leaks oil from somewhere.
Jul 09, 2008 | Nissan Hardbody Cars & Trucks
Brodit ProClip for Citroen Dispatch 2008 - 2012 Center mount Logo
14 people viewed this question
Top Brodit GPS Experts
Gilbert Ruiz
Ted Maxwell
Mike Charette
Are you a Brodit GPS Expert? Answer questions, earn points and help others
