Question about GE JASRM24912 Remote Control
I have a sky remote and i want to set if for a philips tv
  • 325 Answers
TV
RED + SELECT (flashes twice)
999
Try your volume now... Sky remote has a Philips code as a Default
Hope this Helps
Little Dish Fitter
Posted on Sep 20, 2009
The tv does not respond to some buttons on the remote but does to others. The ones not working are Power and Channel but Volume and Mute work. New batteries make no difference.It is a Phillips tv with...
There is a way that you can check the remote buttons are working.
Get a mobile phone with a camera on it.
Set the phone to camera mode.
Whilest looking through the mobile. point the the Tv remote at the camera phone and press each button individually. what you will see on your mobile is a light coming from the remote for the buttons that are working. If certain button are not working you will see no light through the camera phone. If this is the case you may need to get a replacement remote.
If you do need to replace the remote this can be quite expensive to buy from the manufactor. So what I would surgest is getting a sky remote off a friend or family member. or even Tesco. argos. It does not matter what the remote is ie Standard, Sky+ or HD remote. (which ever you can get cheaper) The reason behind this is Sky remote have a default code in them to work PHILIPS tv's. When you get this remote if it does not work your telly straight away. What I would then do is remove the battery's from the remote for a minimum of 10 minutes that way it loses the code someone has set it up for and defaults back to Philips Code.
All of the above will sort your Problem out.
Thanks Little Dish Fitter
You owe me a Pint. : )
Sep 24, 2009 | Philips 19PS50S 19" TV
TV Remote not working.
Philips
0081
584,065,040,041,582,221,115,071,351,402
Try these i acnt find one for your model but sometimes others for the same make might work
Let me know,plz
JonnieC
Jan 20, 2009 | Philips Magnavox 27MS343S 27" TV
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Oct 17, 2008 | Philips HDD065 MP3 Player
PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
Television
you can press both volume buttons on the set to bring up the televisions menu. From there you can use channel and volume buttons to navigate the menu.
Sep 15, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
GE JASRM24912 Remote Control Logo
81 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
