What is the significance of the 'c 'shaped cartilages that reinforce the tracheal ring?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
You posted this question in the wrong place (PC Laptops), I'll answer it anyway as I know quite a bit of Biology :).
The C shaped carilages are present around the trachea so that trachea doesn't collapse due to pressure changes inside the trachea during ventialtion (breathing in/out). Hope this helped :)
Posted on May 15, 2014
What is the rear left exterior window seal on the 2011 hhr. its rubber seems like it has a bendable metal inside
It may have a metal band in it to help it hold its shape and provide some reinforcement.
Apr 30, 2017 | Cars & Trucks
Water valve leak
No, its correct. Its just labeled incorrectly in the manual. The Bushing should be pushed up all the way(use dish soap to lubricate that oring) and the clip installs on the bottom of the bushing.
Jan 05, 2014 | Bosch 1600H-NG Natural Gas AquaStar...
What is conch piercing?
Conch piercing is a type of ear piercing: Inner conch piercing is done at the center of the ear cartilage. Likewise outer conch piercing is done on the outer part of ear cartilage.
Feb 20, 2013 | Health & Beauty
I don't know how to change the head light on my 1997 Jeep grand Cherokee. there doesn't seem to be any screws to loosen the light.
Hi Clint,
I just want you to know that you are not crazy or blind!
The reason you cannot find any screws is because you are dealing with a snap-together vehicle.
If you only want to replace the bulb, you can reach around the radiator support and twist the bulb retainer to remove it and the bulb. If you are wanting to replace the ENTIRE headlamp assembly, follow the instructions below.
REMOVAL
Grasp lower edge of headlamp lens and pull straight back (away) from Grille Opening Reinforcement (GOR) . Disengage lower adjuster pivots from lens assembly.
Grasp upper edge of headlamp lens. Pull straight back (away) from grille opening reinforcement (GOR). Disengage upper adjuster pivot from lens assembly.
Rotate bulb lock ring counter clockwise. and remove ring and bulb from lens.
INSTALLATION
Replace by seating the assembly in the lamp housing and turning the lock ring 1/8 turn clockwise to secure.
Align upper adjust pivot into headlamp opening and snap into place.
Snap lower adjuster pivots into place.
Oct 16, 2011 | 1997 Jeep Grand Cherokee
WHAT ARE LIGAMENTS?
The functions of ligaments, tendons and cartilage involve supporting and connecting various tissues and structures in the body.
  1. Ligaments
    • The function of ligaments is to connect bone to bone. Ligaments provide stability in the joints by preventing too much movement.
    Tendons
    • The function of tendons is to connect muscle to bone. Tendons carry the force from the muscle that moves the bone.
    Hyaline Cartilage
    • Hyaline cartilage is a flexible tissue that is also strong and resistant to pressure. It provides flexible support for structures in the nasal septum, larynx, trachea and bronchi of the respiratory tract, and in joints.
    Elastic Cartilage
    • Elastic cartilage supports the external ear, auditory and eustachian tubes, epiglottis and larynx.
    Fibrocartilage
    • Fibrocartilage provides a firm but not rigid support in the intervertebral discs, at the insertion of tendons and ligaments, around part of the knee, and in healing fractures.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Computers & Internet
An ink cartridge is not installed properly. canon 1p1300
An ink cartilage is not Installed properly printer's cover cartilage Installed properly
Jan 02, 2011 | Canon PIXMA iP1300 Printer
We put the toiet in twice and it is still leaking around the base. we replaced the rubber seal. there is a rubber transition piece with a rubber seal around it and I think this is the problem
Yes, that is likely the problem. I reccomend going with the old tried and true reliable wax ring seal.
For each toilet I put in I install the poly reinforced wax ring with horn. This has consistently served to prevent leaks and call backs alowing me to have no warranty issues.
I reccomend it over the rubber seal anyday.
Here is a pic of the poly reinforced wax ring with flange.
Here is a link to ace hardware's product.
These can also be found at any plumbing supply house Lowes, or HD.
http://www.acehardwareoutlet.com/(rcxnquezsohrpqjz1bzfc345)/ProductDetails.aspx?SKU=43430
Oct 10, 2009 | Toto CST414M-11 Aquia Dual Flush Elongated...
How do I attach the fabric seat of my evenflow supersaucer? It was detached for washing and now I cannot figure out how to re-attach it. Fran. email:franblakely@yahoo.ca
Nope still couldn't get it following the instructions....Finally figured it out. start with the 3 plastic rings fully assembled on the saucer. Then you need to pull the fabric over the top of the upper plastic ring and then feed the elastic through between the upper ring and the middle ring from the outside to the center through the 1/4 inch space and then attach the elastic bands to the hook point. The fabric needs to be surrounding the upper plastic ring such that your child will not rest against the plastic directly with their head. the plastic tabs are really only for reinforcement, even though they fit perfectly and snap right in the the middle ring (took me a while to get over that).
Aug 17, 2008 | Evenflo Jenny Lind Crib
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
