Question about Biztree Business-in-a-Box
Why can't I get BIB to open. It downloaded but I don't know if it installed properly.
I downloaded it and and installed it but when I open it from the shortcut on the desktop nothing happens...
  • Big Steve
    Big Steve May 27, 2014
    Hi Kim Cottrell, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Biztree Master
  • 1,087 Answers
Get back to BizTree and ask for support at
Posted on May 27, 2014
Install tank bib pouch on 2005 harley softail
If you mean the chrome extension panel that fills the area between the rear of the dash and the back of the tank, then yes, you will remove it and not use it.
Most I have seen goes under the dash, so you will need to remove it to install the bib then reinstall the dash with it's rubber gasket.
Dec 13, 2013 | Harley Davidson Motorcycles
How do i install a rear fender bib?
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Mustang Seat Tank Fender Bib Plug Go Installation Video Guide Tip of the...
May 16, 2013 | 2003 Harley Davidson FLSTF Fat boy
No i don't just trying to help a elderly lady
It's not the sprinkler. The valve is not seating completely. You will notice the sprinkler it is leaking from is the lowest one in that particular zone. Don't take it out on the sprinkler it's not his fault. Think of it as if you didn't shut a hose bib off completely the leak doesn't drip at the bib it shows up at the end of the garden hose. Same principal. The valve is the hose bib.
Apr 17, 2013 | Rainbird Rain Bird 1806nsi Pop Up No Side...
Black slim in hot water
SOUND LIKE YOU NEED TO DRAIN AND FLUSH YOUR WATER HEATER TANK. THERE IS A HOSE BIB AT THE BOTTOM OF THE TANK. RUN A HOSE FROM IT TO A DRAIN OR OUTSIDE. SHUT OFF THE COLD WATER INLET VALVE AND OPEN THE HOSE BIB. OPEN HOT FIXTURES IN THE HOUSE.CHECK THE DRAINING WATER FOR CLARITY. IF CLEAR OPEN THE INLET VALVE AND LET IT FLUSH(YOU MAY GET MORE DISCOLORED WATER, RUN UNTIL CLEAR). SHUT HOT WATER FIXTURES, CLOSE THE HOSE BIB AND LET TANK REFILL.
Mar 30, 2013 | Water Heaters
I purchase a ****** bib for my new Grandaughter who lives in NC and her father my son is a die hard ****** fan who is serving in our armed services (Not that should have anything to do with this but he was...
Hello
This is not Pathmark.This is a fix it your self website.But since your here ill see if i can t get you a address.
Here is a link with phone number.As i dont know your address you will need to find a local store.OR call the main cutomer service number and demand a new bib.
http://pathmark.com/contactUs.asp
Also here is the manufacturer.
www.mcarthursports.com
Sep 23, 2011 | McArthur Sports McArthur Dallas Cowboys...
I HAVE A WATER ONLY BOILER MODEL WR11E IT IS ONLY 6 MONTHS OLD AND THE PROBLEM IS THE WATER IS ONLY LUKE WARM AND NOT HOT AS IT WAS BEFORE
Turn the boiler off. Connect a garden hose to the drain bib. Shut the water supply valve off.
Open the drain bib and drain boiler. Close drain bib and open supply valve.
When boiler is full, go to the farthest faucet and open the hot water and let run.
Go back to supply valve and turn off and on a couple of times rapidly this will "bounce" sediment loose.
Repeat above twice.
Nov 08, 2010 | Heating & Cooling
How to properly install and insulate a new hose bib
Get yourself what is called a "Frost Proof" hose bib. This puts the shutoff valve in the assembly well inside the cellar so insulation will not be a concern. I believe they come in two different lengths so get the longest one. Make sure you have a shutoff installed in the supply pipe (it should already be there) so you can shut off the water completely to the hose bib. Hope this helps.
Jun 08, 2010 | Plumbing
Franklin BIB-1450 cannot turn on.
Turns out the batteries that I tried were dead. Bought new batteries and installed them. The Franklin BIB-1450 now works. Yay!
Jul 31, 2009 | Franklin BIB-1450
Leaking outdoor hose bib
ok this is an easy one.  you have what is called a  frost free hose bib.  this is split or has a hole in it after the seat.  the seat is inside the house wall.  you need to cut off the copper inside the house and replace the valve .  if it is not a solder joint than have someone hold back on the copper on the inside and you should be able to spin it off and replace it.  P.S if this is the case make sure you use T-tape on the threaded conection
Jun 21, 2009 | Plumbing
No hot air with Firstco UC-HW Series Fan Coil Unit How do you clean, fix or troubleshoot?
remove door at water coil, find hose bib, connect garden hose, cycle unit, open hose bib, allow to flow until no air just solid stream of water. turn off valve. close door. check temp.
Dec 15, 2008 | Heating & Cooling
Computers & Internet Logo
44 people viewed this question
Top Biztree Computers & Internet Experts
Andrew Taylor
Andrew Taylor
ray gallant
Dan Shibata
Dan Shibata
Are you a Biztree Computer and Internet Expert? Answer questions, earn points and help others
