Question about Canon PIXMA MP600 all-In-One InkJet Printer
Error code 5010 green & orange lights flashing printer will not operate
  • andyjanice Jun 23, 2009
    I unplugged the printer for 7 minutes the plugged it in again and still get the same 5010 error message!
  • Canon Master
  • 13,433 Answers
First
1. Turn off the printer
2. Disconnect the printer from the power outlet (totally unplug the printer)
3. Wait for 5 minutes
4. Plug the printer back in to the electrical outlet.
5. Turn the printer on
let me know if the problem is still there.
Posted on Jun 23, 2009
  • Ekse Jun 23, 2009
    Please send the brand and model of your device by using the add a comment link.
My canon MP 610 shows code 5010, also the green & orange lamps are flashing aleranately .
same problem here but i think; its a hardware problem or maybe scanner but if u face error 2:4 thats i confirm problem with connecter cable from scanner into motheboard...just check cable connecter scanner connect properly if doesnt work.......send to canon service center
Aug 21, 2011 | Canon MP610 Photo All-In-One Printer
Cannon Pixma ip90 printer mechanical failure code 5100. Printer works for about 2 inches then stops with failure code 5100
The error 5100 actually means nothing. You need to look at the printers green and orange lights. they will be flashing in a certain sequence. Count the way the lamps flash ie.Green are mechanical faults and orange are operator correctable faults. When you have the info repost and i will help you further.
Jul 27, 2011 | Canon Office Equipment & Supplies
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Problem on a canon 3100
    The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
    Two orange flashes: Out of paper, paper jam, or paper feed error
    If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
    Three orange flashes: Paper jam
    If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
    Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
    Replace the empty BJ tank and press the Resume button to continue printing.
    Five orange flashes: BJ cartridge is not installed properly
    Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
    Six orange flashes: BJ cartridge (printhead) is not installed
    Seven orange flashes: BJ cartridge (printhead) is defective
    Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
    Eight orange flashes: Waste ink absorber almost full
    The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
    The POWER light flashes orange and green alternately: Service error
    A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
    Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Error 5010 and flashng green and orange
    I found out my machine is dead.
    I'll have to buy a new one
    Jan 08, 2009 | Canon PIXMA MP510 All-In-One InkJet...
    Operator Error Canon i850 printer
    Start with the printer OFF
    1. Hold down RESUME and then hold down POWER
    2. Release RESUME
    3. Press RESUME twice, then release POWER
    4. Let green light blink until printer is done futzing
    Select function with RESUME press POWER to execute:
    presses - light color - function
    Number of presses - light color - function
    0 presses - green - Test print (or exit service mode on i960)
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
    2 presses - green - EEPROM initialize
    3 presses - orange - Reset waste ink counter
    Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
    Error code 5010
    Yes, same thing happens to me...Error code 5010...and flashing green and orange...alternating lights.
    I was trying to photocopy (in basic black, not colour). I had a few pages to copy. I got this 5010 Error code after EACH copy!
    I had to turn off the printer after each copy and then turn it back on for the next copy. That's not the worse of it.....once I turned the printer back on and hit copy again...the printer took a VERY long time to scan the item for the next copy. It took me a good 40 minutes to copy 15 pages.
    Sooooo irritating!!!!!
    Anyone know what to do?
    I've also had the paper jam on me tons of times. I am really disappointed with this product. I would not recommend this printer to anyone!
    Mar 24, 2008 | Canon PIXMA MP510 All-In-One InkJet...
    Canon PIXMA MP600 all-In-One InkJet Printer Logo
    742 people viewed this question
    old marine
    old marine
