Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
Have Malibu ML300RTW Transformer...
For some reason, five landscape lights went out at same time. One flood light still is powering on. Tried changing the bulbs. Wiring is fine. Is it a problem with the box itself?
  • 4 Answers
Doesn't seem to me it could be the transformer/controller as it either puts out voltage and current or it doesn't. I can't think of any way it would selectively operate certain bulbs. You said wiring is fine, but you should check voltage at the end of the line to ensure it's getting close to 12 volts all the way down the wiring. If not, there may be a problem between transformer and misbehaving bulbs. Doesn't seem likely that 5 bulbs would go out a once, but that would be all that's left.
Posted on May 15, 2014
SOURCE: Malibu landscape transformer
I discovered that I hadn't turned the manual switch to off on the one that wasn't working properly.
Now they both work fine. The instructions that come with the Malibu Transformer is not easy to understand and it does not go into enough detail. There isn't a trouble shooting section which would help.
Posted on Apr 15, 2009
SOURCE: Malibu transformer shuts down early
I'm thinking that a better brand is in order. Mine shorted out and started a fire. Luckily we had just returned from vacation and put it out with a hose.
Posted on Sep 05, 2010
gotgeek2
  • 565 Answers
SOURCE: I have a Malibu ML300RTW transformer with a 50 ft.
Usually 50 - 75 ft. is as far as you want to go, especially with 16 gauge wire. What happens is the lights get dimmer as the length of the run increases. If you don't mind the lights getting noticeably dimmer, go ahead and add the other 4 lights. Using a heavier (12 gauge) wire will help a lot. You'll want the 12 ga. to start at the transformer, preferably running the whole length. Also, using a smaller watt bulb will help.
If you have a 120 volt outlet near the approximate middle of the new (total 150 ft.) run, you could relocate the transformer to that location and have two 75 ft. runs in 2 directions.
Posted on Nov 29, 2010
Testimonial: "Thank you for your response. Your advise was exactly what I needed to know."
SOURCE: I have a ML300RTW Malibu
You can buy cheap plug-in timer, set power pack to override and then plug power pack into cheap timer.
Otherwise there are no repair parts for power packs other than on-off trippers.
Power packs come with 5 year limited warranty, so you are within warranty period. Good job saving the date of purchase, you outshine with that detail.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 02, 2011
  • 5089 Answers
SOURCE: Intermatic Malibu ML300RTW Transformer Trips curcuit breaker when plugged in. Can I assume that the 4 year old transformer needs to be replaced?
Try the transformer on different outlet.
Move wires inside breaker box to different circuit breaker.
Check is breaker is loose, or makes crackling sound.
Copy following links for resources:
http://waterheatertimer.org/pdf/How-to-find-ground-fault-in-household-electric-circuit.pdf
Posted on Jul 01, 2012
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
Jun 16, 2016 | Intermatic Malibu 300W Power Pack...
Where can I buy a replacement photocell for my Malibu 300W low voltage landscape lighting transformer?
You can buy the Malibu Photocell Low Voltage sensor on eBay. Go to eBay and search "Malibu Photocell Sensor" and you should see it. Or search eBay item number 371829265599
Mar 26, 2016 | Intermatic Malibu 300W Power Pack...
I have 3 landscape lights that were working but quit working in a system with about a dozen other lights that continue to work. I presumed the bulbs needed replacement but that didn't help. I verified...
My experience has shown that this is nearly always a connection and/or wire corrosion issue. Be certain that all connections are clean-if not clean with fine grit sandpaper or replace. Remember these devices are exposed to the weather on a continuous basis.
Nov 04, 2013 | Intermatic Malibu 300W Power Pack...
Malibu Lighting ML300RTW Transformer Motor
Motor has gotten weak, and is overheating and soon will not work.
Some people report taking apart motor and cleaning gears.
Others report that they didn't record how the gears came off, and can not reassemble.
PB912M10 Clock module is not sold separately.
Switch power pack to override so lights are ON, and plug transformer into cheap wall timer.
Copy following link for tips to get power pack to last longer, troubleshoot, and warranty, etc.
Nov 04, 2012 | Intermatic Malibu 300W Power Pack...
Malibu landscape lighting transformer problem
Testing ohms across A and B will read open circuit through transformer coil.
Testing DC voltage across terminals A and B should read 12 volts DC, and nothing less.
Transformer should make humming sound when working.
Test that receptacle has power and breaker is not tripped.
There are no repair parts for power packs, but they come with 5 year limited warranty.
May 30, 2009 | Intermatic Malibu 300W Power Pack...
Apr 14, 2009 | Intermatic Malibu 300W Power Pack...
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
78 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
