Question about Ruud Matching Split Air Conditioner
How to connect wires for ruud fan motor - Ruud Matching Split Air Conditioner
2 Suggested Answers
SOURCE: replacing fan motor in a RUUD air conditioner
Friend wired the motor to the unit.
Posted on Jul 21, 2008
I installed a run capacitor for my blower motor on my RUUD ac model UGPH10EBRJR. now it runs all the time. I even disconnected my thermostat and it kept running. is it my thermostat? or something else
An open limit switch may make the fan run all the time. Try disconnecting the Green wire @ the furnace...if that does the trick, then either the thermostat fan relay is stuck, or there is a short between the Red & Green wires somewhere in the thermostat wire.
Jan 18, 2015 | Ruud Heating & Cooling
Hello all My Rudd AC unit will start and run find maybe for 10 minutes and cool air then the fan outside will stop and unit hums or hisses and blows hot air inside vents. I changed out Thermostat and Run...
Welcome to the world of Ruud! Ok James heres the deal. It sounds like the condenser fan motor has failed. Its not a repairable item but the motor is not too expensive. Disconnect the main power at the fuse block on the side of your house next to your a/c. Remove the screws that hold the top fan section and carefully turn the fan/panel assembly over taking care not to stress the wires. Determine how the fan is mounted (probably 4 screws) and go find your new motor. Both Rheem and Ruud use the same motor mounting. Most a/c supply houses have a motor that will fit or go to graingers. Make sure you get a matching run capacitor for that motor. It will have separate wires and not share any wiring with the old capacitor. The old capacitor will have to stay in place since it is also connected to the compressor. The old motor will have 3 wires and the new one 4 (2 brown for the capacitor and 2 others to put on the contactor that the compressor wires go to). If its a heat pump it could be a board and youll need help. good luck
Aug 15, 2013 | Ruud UBHC Air Conditioner
Connecting protect condenser fan motor 5 wire to dual capacitor. old fan motor has 3 wires. which wires go where?
Wiring a fan motor to a dual capacitor, the leads with the stake on's go to the fan and common.
Usually the brown with white strip goes to the middle or "C" terminal and the plain brown goes to the fan or "F" terminal the other three are power and usually use the black and red connected to the fan relay.
Jun 13, 2011 | Ruud UAKA037 Air Conditioner
I have RUUD and just replaced the condensor fan motor with a 5 wire Protech....the old fan was wired with black connected to contactor, orange to one side of cap and brown to the other side of the...
look on the side of the motor it will have a wiring diagram your fan supplies voltage to the capacitor its self so two of your wires go to the capacitor not just one. good luck
Aug 11, 2010 | Heating & Cooling
How do I troubleshoot a ruud a/c fan motor
You can disconnect the compressor from the contactor and wire the motor up to the 220 to see if
fan will run. If fan turns hard by hand, replace motor otherwise you may just have to replace the capacitor.
Jun 27, 2010 | Ruud UAKA037 Air Conditioner
The outside fan motor (OFM) will not turn off.
it sounds like your fan connector is on the same side of the contactor where your high voltage enters you should have 3 wires 1 wire for each pole of the contactor and 1 wire off the capacitor does the compressor run all the time too? try turning the power switch off on your indoor air handler / gas furnace if the power goes off the fan goes off then it could be low voltage wiring
Jun 30, 2009 | Ruud UAMB Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud Matching Split Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
