Question about Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV
What size spark plug does it take for a 2 cycle Troybilt leaf blower ? and what is the gap?
Won't run
5 Suggested Answers
  • 74 Answers
SOURCE: leaf blower won't start. I think it's the module
If you haven't done it already, install a new plug. It's possible you're being fooled by a faulty/fouled plug. A fouled plug may not spark visibly - like if there is dirt down in the recesses of plug around the electrode. It would be a good idea to check it with a new plug before spending $80 bucks for a new ignition module.
Posted on Aug 13, 2009
  • 85 Answers
SOURCE: i have no spark on my leaf blower. i have replaced
try the switch it may be bad or dirty
Posted on Feb 06, 2011
SOURCE: what is the gas/oil mixture
40:1
Posted on Jul 09, 2011
2strokeJim
  • 577 Answers
SOURCE: gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Posted on Nov 28, 2011
Spark plug gap
Most 2 cycle products it should be 0.025
Oct 24, 2016 | Echo Garden
What is the spark plug gap for 18cc weed eater?
search
What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
Jun 07, 2015 | Weed Eater Featherlite 18cc 2 Speed Gas...
Spark plug gap size ?
for ???
most 4 cycle lawn mower engines .028~.032
most small 2 cycle stuff .024~.028
Aug 10, 2014 | Toro 93-3884 Simplicity 1716959 Bolens...
SPARK PLUG gapping
Hi
I guess you have sorted this one by now.
However if not makers recommend 0.020 inch (20 thou gap), however I have found that 0.025 (25 thou gap is more versatile for both starting and running.
Regards
Jacko from down under
Dec 28, 2013 | Stihl Garden
Spark plug
Champion is the kind of plug. most are 5/8 of an inch.
Jun 14, 2013 | Poulan Pro 25CC 2Cycle Gas Blower
Troybilt yard blower won't start
Change the plug and check the coil....
Make sure there isn't trash in the gas tank because it could be clogging the fuel line causing it to just spin over but not crank / start...
I hope this helps...
May 12, 2013 | Garden
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
My leaf blower won't start. I've checked, fuel, cleaned filters, and carbon build up. I realised spark plug isn't firing, so I replaced it but it's still not firing.
did you make sure the new spark plug was igniting if it is or if its weak you might have broke the flywheel key was it running fine when last used there can be alot of things it could be 2 cycle engines must have 120psi of compression ,the right fuel mixture,good plug right gap between flywheel & magnito (spark plug wire connect to to get spark) and not rust on flywheel & magnito hope this helps let me know thanks
Nov 10, 2009 | Garden
I am gettinno spark from the spark plug I have put in a new plug,
first check to make sure the on/off switch isnt shorting out anywhere. try resetting the gap between the flywheel and the igniton module. you can use an index card or manilla envelope to set the gap. if it still doesnt work try replacing the module
Nov 22, 2008 | Craftsman 4 Cycle Blower/Vac
Troy-Bilt 31cc 2-Cycle Gas Powered Blower/Vacuum #TB320BV Logo
118 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
