Question about Honda Lawnmower Hrr216 Hrs216 Hrb216 Recoil Starter
My lawnmower is a Honda HR 214 type SXA. The starter cord quit retracting. How do I fix that?
Also, the starter cord needs replacing. I carefully unbolted the top, looked around, and put it back on. I need advice. Thanks.
  • 641 Answers
How do u fix a loose starter cord people?
Hi Rick:
Most starter cords rely on a recoil spring to make them retract.
Sometimes when the cord is replaced it is longer than the original so just needs to be shortened. Pull the cord all the way out and if you have way more than you use for a pull start, then shortening it is a fast fix.
To do that, pull out the cord a couple of feet. flip a slip knot in it to keep it from retracting, then take the start handle apart and shorten the cord about 6 inches. Should work fine.
If the cord is talready too short to make it shorter, you'll need to put another wind on the spring.
Reply as a COMMENT to this post af you need coaching through that.
Hint. Don't dismantle the spring assembly so it can get out. They are related to rattlesnakes.
Cheers.
Feb 08, 2016 | Garden
How do u get into the pull cord assembly to fix the cord to the coul
Hi Martha,here's the type of lawnmower I have,it's a video showing you how to replace your rope,if not your type of mower,let me know what type and hopefully I can find you a video,it's real simple.I bought my mower from Lowe's. Small Engine Repair Replacing the Starter Pull Cord on Briggs Stratton...
Aug 02, 2015 | Electrical Supplies
Fix recoil when pull cord on sanli lawnmower broke
Take the starter assembly off the mower. Unwind the spool using whatever method works (2 screwdrivers?) until you capture the remaining. cord. Pull it all the way out. Pin the spool so that it can't retract. Remove and replace the cord. Re-assemble. Back to cutting grass!
Mar 15, 2015 | Garden
How do I reinstall the manual pull cord on a 20 inch lawnboy lawn mower?
I think you need to replace the whole rewind unit as the dawgs must have engaged the starter cup if it was running !
Sep 21, 2014 | Garden
Starter cord on lawnmower will not pull out
Hi Mary. You will need to remove the starter box on your mower. The coil box may be rusty or the pully may need fixing. Try using some oil spray and see if the pully now works. If the starter coil is clean the mower may be ceased.
Jul 27, 2013 | Garden
How do i fix the pull start and re tension it so cord retracts?
You take the top of the motor off with the starter, then rewind the spring,then is a good idea to replace the rope with a new one they sell rope at a lawnmower store, get 5 feet or more if the rope is up on the handle, take a piece of rope with you to get the correct size.
Aug 20, 2012 | Electric Earthwise Corded Lawn Mower...
I have a Briggs & Stratton Sprint 3.75 hp lawnmower and it seems the cord is pulled almost all the way out and won't retract. How will i know if it is broken? or should I be able to wind it back up...
You should be able to Fix this yourself if your a fair garage tinkering mechanic. However...I need the engine and type number off of the engine to get you parts information. The spring is broken in your recoil. It is a matter of removing the air shroud, taking off the pulley / spool and changing the spring.
http://www.ehow.com/video_2328977_how-install-lawn-mower-starter.html
and how to tension the spring:
http://www.ehow.com/video_2328961_how-tension-lawn-mower-starter.html
There are 2 different types of springs used so having your engine model / type number is important so that you can get the right spring. One of the 2 part numbers is: 390066
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Briggs & Stratton Briggs Stratton...
How do you tune the carb on a honda hr194 petrol lawnmower
most carbs just need to be rebuilt it's not a hard job but when your finished adjust the mixture screw out 1 full turn of the screwdriver. that will get it started then fine tune it from there....good luck
Apr 04, 2010 | Garden
GXV140 Carburetor removal
The carb just slides off of the posts. The gaskets are holding it on and may tear when you pull it off. The linkages must be disconnected to get it off as well. There are two bolts on the throttle plate that can be removed so the plate can move to make disconnecting the linkages easier. Some people remove the posts by threading two nuts on and tightening them against each other so that the inner one can be turned to unscrew the post. That didn't work for me as both nuts still turned together.
Apr 03, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Pullcord violently retracting on Craftsman lawnmower
It is possible that the 'dogs' that engage the crankhaft were stuck in the out (engaged position). Once the engine started, it wound the rope in the opposite direction until the dogs slipped and retracted. Romve the top cover that includes the pull start unit. Check for smooth and sticky free operation while pulling on the cord. Try using a very light oil to lube if nessesary.
Apr 29, 2009 | Sport & Outdoor - Others
Honda Lawnmower Hrr216 Hrs216 Hrb216 Recoil Starter Logo
167 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
