Question about Refrigerators
Maytag pbf1951hew service manual
Need service manual
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: Maytag PBF1951HEW lower freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
For
extra help go here:
http://www.applianceaid.com/procedures.html
Thanks
for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 17, 2011
I need service manual for maytag dryer mde7400ayw?
Thats a older model and service manuals for it are no longer published. Thier is generic service manuals available at Lowe's HomeDepot and your local public library. However they only cover basics of all dryers and dont get into paticulars of any one brand. What kind of problems are you having we here can guide you through since some of us have extensive knowledge on the Maytag and other brand dryers having been in the field and serviced them for decades
Aug 16, 2011 | Maytag Dryers
My maytag neptune fav6800vaw washer will not complete the wash cycle. i press pause but the lid does not unlock so the machine is still filled with clothes & water.
I would go into Service Mode and try to unlock the lid latches. Google this
Neptune TL Washer FAV6800AWW
Go to the 5th post down there is a link to the Service Manual. The Service Manual will show you how to get into Service Manual and unlock the lid Locks. If you can't unlock in Service Mode the Service Manual will show you how to release the washer top from thew base to remove your clothes.
If you need additional help post in that forum for help ; Maytag/Magic Chef/Admiral/Jenn-Air
Aug 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I need a water filter for a msd2655 maytag.Which one should I use?
Your model requires the=> PuriClean II Model UKF8001AXX
Here is the page from the Service Manual=> PuriClean II Model UKF8001AXX
Should you require a user manual or Service Manual User Manuals Click Here=> Maytag User Manuals I was going to link your user manual but the site is down and has been reported automatically. And if you have other questions please ask me here at Fixya, Thanks, Sea Breeze
Apr 12, 2011 | Maytag MSD2655HE Side by Side Refrigerator
CANT FIND THE DEFROST CONTROL BOARD, model# pbf1951hew serial# 10680921ee how old is this frig
We have here below a link with parts layout of your fridge including the Defrost timer and any other part.
In the diagram is part No 12,
Timer, defrost
Part Number: AP4077325 made by WHIRLPOOL
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171979&diagram_id=1359777#d1359777
We would appreciate a testimonial for your free solution
Oct 19, 2010 | Refrigerators
0. We need a manual for Maytag Neptune TL. IT IS
f your machine is a FAV6800A or FAV9800A see if this post will help. Service manual link or located there. here it is just in case
Clutch Fix
Here it is just in case;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How do you put a fav6800 maytag washer into dianostic mode
You need the Service Manual;
Here are some handy links; The Service Manual for reference. Sears Parts Direct for reference.
From Page 14 of the Service Manual;
Enter / Exit Service Mode To enter Service Mode press the Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps.
Rich
Feb 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Power Interruption
power interuoption is a power cut / power went off it needs resetting your tech should be able to do this
Jan 21, 2010 | Maytag MER6772 Gemini Electric Kitchen...
I need to find a repair manual for Maytag MDG5500AWW gas dryer
Most service manuals have to be purchased, but you may find what you need for free by following the link below. You can purchase service manuals at, www.repairclinic.com
http://laundry.manualsonline.com/manuals/mfg/maytag/maytag_washerdryer_product_list.html
Sep 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MY REFRIGERATOR IS MAKING A CLICKING AND BUZZING SOUND FOR ABOUT 3 DAYS NOW. NOW IT IS NOT COOLING!! COULD IT BE THAT THE COMPRESSOR WENT OUT???? IT'S A MAYTAG... MODEL # PBF1951HEW... IT'S ONLY 3 YEARS...
It certainly sounds like a faulty compressor. Your refrigerator has a 5 year parts and labor warranty. You are responsible for any other charges. This work MUST be done by a factory authorized service company! The warranty policy can be found in your user's manual. If you need a user's manual, you can download 1 for free at the website link below. You must register to gain entrance, then input your type of product, make, model no., click go, and it will find your pdf. format file, which you can then download.
http://www.managemyhome.com/mmh/products/ManualSearch.action?product.productName=Refrigerator&product.brandName=Maytag&product.modelNumber=PBF1951HEW&docUrl=http%3A%2F%2Fwww.managemyhome.com%2Fmmh%2Flis_pdf%2FOWNM%2FL0408037.pdf
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 11, 2008 | Maytag Refrigerators
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
