Question about Standard Horizon Hx300 Compact Floating Handheld Vhf Radio unpublish
Checking input of ATIS
I manually put in ATIS - how can I check that it is correct
  • Janice Waller
    Janice Waller May 15, 2014
    I put the ATIS number in per instructions. It then tells you that you must put the number in again. It did not act the same (different sound to the beeps) As a result would want to check to see that the ATIS is actually installed and is the correct number. Thanks
  • 641 Answers
Kindly check this site for checking if it is correct.
https://ivao.aero/training/documentation/books/ADC_Fill_ATIS.pdf
Posted on May 15, 2014
Wii wireless won't connect error52031
Ok so far heres what works, entering in everything manually.
1. Go into connection types, Hit "Manual Configuration"
2. Input your SSID
3. Input the correct security type, this is key.
4. Put your password in properly
5. For ip address "Do not auto obtain".
6. open up cmd in your computer, type in ipconfig
7. Now input that ip address but add 10 to the last number so "192.168.0.1" will be entered as "192.168.0.11"
8. Enter the rest of your info inside such as subnet mask and default gateway exactly as you see it in your ipconfig.
9. Now hit next, hit configure now for your DNS. When asked about DNS hit "Dont auto obtain".
10. For the first server put in 8.8.8.8
11. For the second server put in 8.8.4.4
12. Hit Next, when asked about a proxy hit no proxy
13. Leave mtu as the default
14. it should work, if not check the ip and that it is the internet ip + 10. Good luck
Sep 02, 2017 | Video Game Consoles & Games
D sub comes up and screne gos black.shut screne off and put screne back on and d sub comes up again and gos black again,,what is the cathold and drivers in the answer I got before.is it something I can...
It sounds like you have not selected the correct INPUT to the device.OR not connected the cable correcty to the input.
Check your user manual for the device.
Sep 21, 2014 | Cars & Trucks
Hagar EG103 timerswitch when i set a program it says on but it has not switched on
Check if programs have conflict, such as ON at Monday, but OFF all days of week.
Check if wiring is correct: The imput voltage does not put power to the switching terminals. Add a jumper wire from input terminal 3 to COM terminal 6.
Check load rating of timer vrs load rating. For example 2300 watts maximum incandescent and halogen, but 400 watt fluorescent tubes, and max 500 watt CFL.
Some timers have minimum watt requirement, but is not apparent in the manual.
If timer clock keeps time, and can be set, then timer input is wired correctly with correct voltage
Copy following links for Hagar timers:
http://waterheatertimer.org/How-to-program-Hagar-timer.html
http://waterheatertimer.org/pdf/EG103E_103V_User_Instruction.pdf
Apr 21, 2012 | Hardware & Accessories
My tv does not respond to the remote and has to be turned off and on manually first , when it eventually comes on it is on channel that is not supported by our digital signal. I have tried to skip the...
If this set is still under warranty return it for repair/replace.
Do you have the correct remote for this tv ?
If it is correct you can do a quick check to see if it is putting out a signal. Turn on a digital camera and point the remote at the lens. Press the power button and others on the remote and watch for a flash on the camera lcd screen.
Check that the input signal cable on the back is on the correct socket. Disconnect the unused input cables.
Go into the menu and set the input signal source to match the connection on the back.
Scan in the stations.
(There may be signal interference causing the problem)
Are the channels found within reception range?
You can check your freeview broadcast coverage at;
http://www.freeview.co.uk/HD
Feb 08, 2011 | Televison & Video
My Bose Lifestyle 12 - No Sound
What sound are you putting into the system? Have you checked that the audio you're putting into the system works into some other device? Have you checked that you have the correct input device selected?
If you have checked that the audio going into the system is working properly and you have the correct input device selected then yes, audio in but nothing out = something is broken inside.
Nov 01, 2017 | Bose Lifestyle 12 System
Cant get anything when i use the two hdmi inputs in and one hdmi out to a monitor
First thing to check, If you turn your monitor on to the correct input you should be able to see an immage from your receiver. It may be a setup screen, blue screen or flash as you change inputs on the receiver. If you do not see anything from the receiver check the HDMI cable from the monitor out of the receiver to the input on your monitor. Next is the setup of the DVD player and the Yamaha receiver. Check that the receiver HDMI ports are turned on and assigned to the correct port. Check that the disc player is setup to out put HDMI and that formats like DTS are turned on if your receiver supports this. This will give you the best picture and sound out of the equipment you have. To get in to the set up of your DVD player and receiver and use the on screen display you may need to connect them to the monitor with a composite video cable first. Make sure the monitor is on the correct input. Once you have finished the setup you should be able to switch the monitor back to the HDMI input.
Aug 21, 2009 | Yamaha Audio Players & Recorders
Which graphics card is best Ati radeon hd 3800 series or radeon 6600gt/ati
have a look on ATIs website and check out what each cards have to offer for your computer, this way you can view supported evidence on your choice and not opinion. The site is http://ati.amd.com then look in ATI products and search for graphics crads
Hope This Hepls
Nov 18, 2008 | Computers & Internet
All inputs work except for the component videos.
When your tv shows a blue screen it not getting a signal!! In your mit's you have to go into the customer menu and turn on the input/device. The device control is on the remote, click over to input and activate (enter). Also, look into owners manual, the customer service at mit's will step you through it if you wish. Note: put cables into comp 1 (eg), make sure colored cables are correctly inserted, and audio. (red, blue, green) red/white; audio.
Apr 02, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Dvdirect signal missing
In my case...DVDirect may have been detecting some sort of copyguard (copy protection) ....not sure.
Sep 04, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
Standard Horizon Hx300 Compact Floating Handheld Vhf Radio unpublish Logo
46 people viewed this question
Top Standard Horizon Radio Communications Experts
AnyMHz.com
AnyMHz.com
Norm Pearl
Clint Millett
Are you a Standard Horizon Radio Communication Expert? Answer questions, earn points and help others
