Question about HP Laserjet Cp2025n Printer
I have a HP CP2025 that sometimes tells me I need a new roller but other times works. I have always used Tray 2. Recently it stopped printing invoices I have received in pdf format so the paper goes through but it's a blank page. However, it does print word documents! Help please? Thanks Penelope
  • 3 Answers
When it says it needs new rollers, it means they're worn down. I ignored mine (for the same reason as you) and it started to pull the paper crookedly, as well as not to feed it all the way through causing a "jam." Have your IT person price roller replacement against the cost of a new printer and make your decision. Wish I had better news.
Posted on Jun 19, 2014
2 Suggested Answers
jaylex
  • 417 Answers
SOURCE: HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Posted on Jan 28, 2008
Hp clj 2025 cleaning
I had the same problem and it was the pick-up roller that was at fault. You can buy a new one for less than 20GBP or do what I did. Take the old one out and reverse the rubber. There are plenty of online tutorials on how to change the pick-up roller - the first one you remove. It's a two minute job. Reversing the rubber is easy. Just prize the inner clip out of the roller and put the rubber back on with the shiny side out. It worked first time and no more print errors. HP CP2025 How to Replace the Pick up Rollers and Separation Pad
Jan 20, 2014 | HP Office Equipment & Supplies
I have an HP CP2025 and when it goes to print it says there is a jam in tray 2 but there are no papers stuck, no debris, nothing. It just tries three times to pick up paper and then says there is a jam....
This is called a phantom paper jam and is caused by the printer not being able to grab the paper and feed it into the paper path to print on. There are paper pickup rollers right above the paper tray and when they get worn down they can not grip the paper so they slip. The printer thinks the paper is jammed because it never arrived in the printer. These rollers are user replaceable and come in a kit called RK-CP2025, they are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=318
I hope this helps,
BuddyMc
Mar 28, 2013 | HP Laserjet Cp2025n Printer
We have a laserjet 2420dn which prints fine from Tray 1 but constantly jams when printing from Tray 2. It only prints OK from tray 2 when there is ONE sheet in the tray. I changed the pickup roller in...
In addition to the pickup roller, the separation pad in the tray should also be replaced. This pad keeps more than one sheet from feeding at a time. When we do maintenance on a printer we always replace both to stop this from happening. The part number you want is RM1-1298-000. It is used in quite a few different HP printers.
Apr 16, 2011 | HP LaserJet 2420 Printer
I am getting the error code 13.05.00 on an HP laserjet CP3505n printer. The manual says that it is a front door jam. The jam is occurring every other time I try to print a document. The document is being...
13.05.00 HP CP3505N
Problem Solve. Same error. Generally either a real or phanton jam from the paper tray or manual feed tray.
SOMETIMES the manual feed would work but always one corner on the paper turned down when printed.
Remove toner cartridges and bottom paper tray
Turn printer on its back. The black plastic flap (about 9" long) that hangs down a small amount (near the white main feed roller) had one end most likely the wrong side of the small metal rollers above it.
This flap should hang about vertical. One end of it is most likely the wrong side of the small mostly metal roller above it. Each End of this flap should be about mid way between the two smaller metal rollers.
WITH CARE take a timber skewer and carefully encourage this flap back so that both ends are in the correct place
Sep 02, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
HP Laserjet CP2025 stopped printing.
First thing to do is to turn off the HP. Clear out any print jobs that are sitting on your computer print que waiting to be printed. Turn the printer back on, wait about 1 minute then try printing again. If this does not work then clear the print job again and reboot your PC. Try printing again. If still you can not print then reply here with how the printer is connected to your PC. By USB cable? Ethernet? etc.
Thanks
Jun 09, 2010 | HP laserjet Cp2025dn color Card Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
HP Laserjet 2420 will not print from tray 2
Take out the toner cartridge and paper cassette , turn the printer upside down. The feed roller should not free wheel. Sometimes the roller ends break off,
Jan 28, 2009 | HP LaserJet 2420 Printer
Will not print. says out of paper but there is paper in the tray.
this is indicate that the roller is having some kind of problem.
open the backdoor, make sure there is nothing preventing the roller (should be 3) do its job.
take out the paper from the paper tray. make sure there nothing in the way of center roller path.
re position the paper. load enough paper, so that the paper is right under neath the center roller, remove 2 sheet. try to print. if it pickup the paper, then it is telling you that the roller need to be replaced. if it still having problem pickup the paper. then there is something else we need to investigate.
Hp always being having problem with their printer roller since day one. over time the roller become smooth, and not able to pick up paper.
if the porblem presist, please repost it in this thread. so I can help you to solve the problem.
Nov 13, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP 2420 Tray 2 Open or Empty
Needs feed roller replaced, you can see it when you remove cassette and look up, they wear and tray one uses a diiferent feed roller hence it still works. Cleaning the roller (rag with a little metho) sometimes helps but it should be replaced otherwise it will return.
Nov 08, 2007 | HP LaserJet 2420 Printer
HP Laserjet Cp2025n Printer Logo
67 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
