Question about Nintendo Wii Console
Wii will not power up
My wii will not power on at all. Power supply works (12 v DC reading on voltmeter). Plugged in its as if there is no power. No lights, no reset ability, no nothing. I have disconnected power for hours with no results.
    President:
  • 2,777 Answers
Sounds like the actual board itself has died, either that or the AC adapter somehow shorted out. Either way you need to call Nintendo support, it's probably still under warranty:
1-800-255-3700
Posted on Jun 24, 2009
  • Tim Grayson
    Tim Grayson Jul 14, 2009
    Is there any way you could re-evaluate the 2 thumbs you
    gave me? It really hurts my reputation on the site even though it
    appears I answered your question?
    Thanks
    Tim
I have an Astec DS 1500-3-001 power supply that I want to use a a stand alone PS. What pins do I need to connect to get +12v DC output with 120 VAC Input.
Mike
I take it that this is a standard power supply out of a PC (switch mode)
These are a common connection point on any brand PC
Use a DC Voltmeter to find the Ground, +5 Volt & +12 volt wires to power your 3.5 inch Hard Drive. The 2.5" Hard Drives (laptop) has only Ground (Black) & +5 Volt.
Oct 30, 2014 | Computers & Internet
Plugged in not charging
laptop plugged in not charging:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
http://www.chargerbuy.com/laptop-ac-adapter/hp-ac-adapters.html
Jan 20, 2013 | HEWLETT-PACKARD Computers & Internet
When my computer starts the power light will blink and the fan starts. When the computer first had problems it froze and the fan turned on and wouldnt stop. I also smelt a burnt rubber smell. I read to...
Yes the voltmeter measures the voltage.
When you power up the computer to test the voltage on the 4 wire connectors.
Test the voltage red and balck wire should read 5 volts.
Test the voltage yellow an black wire should read 12 volts
If the burning smell is from the power supply then most likely a capacitor has blown in the switch mode power supply.
I would advise you purchase a new power supply, do not try and repair it, these mains devices can be dangerous if you don't have knowledge.
Sep 14, 2010 | HP Pavilion a705w PC Desktop
I have a smps(model compaq PS-5500-1C). How can check its out put volatage?
Hello Anvar, hi, to run the power supply on its own, you need to short the green wire with the black wire. (plug in the unit)
using a Volt meter, select a range of DC 50V. put the black probe of the voltmeter to any black wire, and the red probe to the ff:
red is 5V
Yellow is 12V
orange is around 3.3V
Blue is negative 12 (switch or interchange the probe to properly read 12V on the voltmeter)
White is negative 5.
Visit this site for more information:
http://en.wikipedia.org/wiki/Power_supply_unit_(computer)
Apr 26, 2010 | Compaq PS-5500-1C (244163001) 50-Watt...
Can A cobra inverter be plugged in to 115AC for DC 12volt output
in a word no!,,,,it cannot and you may blow it up if you hook it up to the 115ac volt supply,,,in side it there is a switch mode power transistor,,that bumps up the 12 volts to 115 volts it only works the one way,,that is 12 volts dc in and 115 volts ac out,,,,
Feb 22, 2010 | Cobra 2500w Power Inverter
Wii won't come on
Unplug the Wii for at least 5 minutes to 'RESET' the Wii console.
Then plug it back in and try it.
Does the Wii show a yellow light ?
Jun 08, 2009 | Nintendo Wii Console
Malibu landscape lighting transformer problem
Testing ohms across A and B will read open circuit through transformer coil.
Testing DC voltage across terminals A and B should read 12 volts DC, and nothing less.
Transformer should make humming sound when working.
Test that receptacle has power and breaker is not tripped.
There are no repair parts for power packs, but they come with 5 year limited warranty.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
May 30, 2009 | Intermatic Malibu 300W Power Pack...
No power to my router
Check the wall outlet for power, using a lamp or such. If you can get a multi-meter, set the meter to Volts-DC between 12 and 20. Plug the power supply into the wall outlet and test the other end for voltage. The power supply should tell you its output so the reading should be more than a couple of volts. If it is less or ZERO the power supply is dead. If it has power, then open the router and check for a fuse. If the fuse is dead, replace. If there is no fuse or the fuse is OK then the router may be dead. Best of luck.
May 29, 2009 | Linksys Wireless-G Broadband Router
Wii power supply
To reset the AC adapter you need to unplug it from the wall outlet and the Wii console and wait at least two minutes. Plug it back in and it should come on. If you have it plugged in a surge protector with other appliances, the other appliances may be interrupting the adapter, causing the power to go off.
Apr 04, 2008 | Nintendo Wii Console
Nintendo wii wont turn on
do you know any one else with one try using there powere pack ?
other wise it's defective.
Dec 28, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
181 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
