Question about Intel D945GTP Motherboard
I loaded windows 7 on D945GTP and in device manager I get ipmi interface and pci serial port
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: I just installed a D945GTP
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Posted on Dec 10, 2010
gilbert_jay0
  • 243 Answers
SOURCE: ipmi interface driver
hi'' add my email gilbert_jay09@yahoo.com and send me mail so i can give you answers on your problem . . . thanks
Posted on Jul 12, 2012
Communication port is not working properly
COM1 and COM2 refer to a computer's communications, or serial, ports. COM1 ports are often used on older PCs to connect network devices, digital cameras and mice. Faulty drivers software that enables the hardware to communicate with the operating system or incorrect hardware configuration can influence COM1 behavior. In rare cases, the expansion card that adds the serial ports to the PC can fail, rendering both COM1 and COM2 ports useless. To repair a COM1 port, you must determine what is preventing the port from working before attempting a solution.
Click "Start." Go to "Control Panel" and then click "Hardware & Sound." Select "Device Manager" from the submenu. Expand "Ports (COM & LPT)." Double-click "COM1." Review Device Status on the General tab to check for problems with the software driver. If the message "The Device Is Working Properly" appears, click "OK" to close the window; otherwise, look up the error message on Microsoft Support. Follow the directions in the Knowledge Base to correct the issue. Press "Alt" and "V" to open View. Scroll to "Resources by Type." Press "Enter." Double-click "Interrupt Request (IRQ)" to see a list of devices. Double-click "Communications Port (COM1)." Check the term to the left of COM1 to see if the card uses an ISA or PCI interface. If the card uses a PCI interface, it can use the same IRQ as another PCI device without producing a hardware conflict. If the device is ISA, it needs its own IRQ. Go to the "Resources" tab. If "No Conflicts" appears in the Conflicting Device List, close the window; otherwise, uncheck "Use Automatic Settings." Click the drop-down menu and select each configuration until the port no longer interferes with another device. If conflicts occur with each configuration, double-click "IRQ"; you may need to try different configurations before Windows gives you permission to edit the interrupt request. Click the up or down arrow to change the IRQ until the message "No Devices Are Conflicting" appears in the Conflict Information field. Click "OK" to close each window. Click "Yes" when prompted. Connect a device to the COM1 port to test the port. If the device doesn't respond, shut down the computer and then unplug the power cable. Disconnect all devices from the back of the PC. Remove the case cover and touch the computer's chassis. Set the computer on its side so that the PCI and ISA cards sit at a 90-degree angle to the floor. Find the serial ports on the back of the PC. Look on the opposite side of the case to find the associated card. Shine a flashlight onto the card and make sure that the copper contacts are not visible. If you can see the contacts, reseat the card in its slot so that it's fully installed to the motherboard. Reassemble the case and boot into Windows to test the COM1 port. If the port still fails to work, you may need to replace the serial port card.
Jan 16, 2013 | Computers & Internet
I have a usb 3 expansion card - pci express interface that is not being detected by windows op7
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
Dec 01, 2012 | Transcend TS-PDU3 USB 3.0 Expansion Card
Ipmi interface driver
Jul 12, 2012 | Intel D975XBG Motherboard
I just installed a D945GTP and in device manager under "Other Devices" it shows "PCI Device" and "PCI Serial Port". Anyone knowI have everything installed.
Dec 10, 2010 | Intel D945GTP Motherboard
Hi There PCI Device & PCI Serial Port show exclamation errors Running Windows XP X64 bit
You need to download the Intel XP 64 bit drivers for this system.
This intel site will do it automatically for you. http://www.intel.com/p/en_US/support/highlights/dsktpboards/d945gtp
Look about 1/3 way down for Automatically detect and update drivers and software
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Sep 25, 2010 | Intel D945GTP Motherboard
Philips freevents MT2700 Drivers
Try taking a look at this site- it seems to have all you may need.
http://www.user-guides.co.uk/download/philips/philipsfreevents/philips-freevents-mt2700.html
Good luck and let us know how you make out.
Cheers,
TIH
Dec 25, 2009 | Computers & Internet
PCI Simple communication controller driver is not installed on Windows 7
then windows 7 has no driver for the device download the latest device driver that support win 7 operating system, if there is no device driver for win 7 then you should have to wait until the manufacturer releases a driver for win 7
Nov 16, 2009 | Intel DG33BU G33 Express Socket 775 mATX...
Stop 7
I know Ricoh hasn't been supporting these for some time now. Do you have a set of drivers for this device?
Aug 05, 2008 | Ricoh R5CA475 PCMCIA to PCI Interface Card...
Pc desktop
You will need to see if you can find Vista drivers for the two devices. If you are not sure where to look for the drivers you can download the Unknown Devices program which will give you specific chipset information that will allow you to search the internet for the drivers.
Dec 30, 2007 | Computers & Internet
Intel D945GTP Motherboard Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
