Question about Husqvarna Chain Saw Chain 14"
How to remove top cover
While attempting removal of the top cover on my Husqvarna 14" e235 chainsaw (to affect replacement of defective primer bulb) after removing 3 visible screws, the cover seems not to be free. I note a recessed screw head below the bulb.. does that also come out? What am I missing?
  • Mike Pilgrim May 17, 2014
    Problem solved. Removing the top cover after removing the referenced four screws required only a bit of force to break loose apparent jam in cover.
  • 3 Answers
Also, if it has a brake, make sure the brake is not pushed forward. This will cause it to lock on and not release the cover
Posted on Jun 26, 2014
  • 398 Answers
SOURCE: Spltting a crankcase on a Husqvarna 394 chainsaw?
the gasket is what is holding it together, if all the bolts are off. you gotta peel it apart. put one side in a vice is how i do it. and do it slowly. everything should slide out .im just telling you from my memory and i cant visualize that particular engine at the moment.
Posted on Mar 13, 2009
SOURCE: Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Posted on Sep 11, 2009
  • 2239 Answers
SOURCE: I broke the throttle trigger on a 445 Husqvarna
The two halfs of the rear handle do not seperate, once you have removed the r/h side grip you can remove the throttle lock, you then need to remove the pivot pin from the trigger with a pin punch, the trigger can then be pulled down and out, you may need to disconnect the throttle wire from the carb if you cannot drop the trigger far enough to remove the wire from it.
Posted on Jul 02, 2011
  • 2239 Answers
SOURCE: my husqvarna 455 rancher needs a carburetor kit how do you remove the carb
This is not so easy to explain, this is an X Torque engine so the carb does not come off so easy, there are air tubes on the back of the carb, however, remove the air filter, remove the earth cut out wire and earth return wire from the red switch, they are just push on, there is a blue clip on the throttle shaft side of the carb, gently pull out and twist ( this holds the throttle push rod into the carb ), open the throttle trigger with your finger at the same time now remove the throttle push rod from the throttle shaft, once out of the carb pull the rod toward the front of the saw and out of the tank, now unscrew the four allen headed screws from the air filter housing, and remove, ease the carb up and away far enough to remove the fuel hose, now remove completely.
Posted on Feb 18, 2012
  • 2239 Answers
SOURCE: Cannot find adjustment oil screw on my Husqvarna 61 Chainsaw
The 61 has a 4 position oil pump, the adjuster is a black plastic screw located to the top right hand corner of the pump face, just behind the sprocket, you will have to clean around that area to find it. The pump has numbers 1 to 4 around the screw, 4 being the highest position.
Posted on May 20, 2012
Replacing primer bulb poulan p3314
Carb mounted, remove the four screws. Frame mounted, remove the two screws.
Jun 01, 2014 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Cannot get fuel to pull up into primer bulb on p3314,what could be the problem?
The primer pulls fuel from the carb metering chamber, so if there is no fuel in the carb the primer will not fill, so either there is a blockage in the fuel filter in the tank ( replace filter ), or there is a blockage in the internal screen in the carb, this is under the pump cover, remove the cover and clean the screen, in some cases the non return valve in the primer itself is defective, so replace the primer.
Feb 02, 2013 | Poulan Pro 14" Gas Chainsaw 33CC P3314
How to change primer bulb on Husqvarna 125 b leaf blower
Remove air filter cover,remove air filter, remove two nuts holding the assembly,pull primer bulb assembly out,remove primer tube. Reinstall in reverse order. http://www.ebay.com/itm/530047721-POULAN-WEEDEATER-RED-SNAP-PRIMER-BULB-/190568099240?pt=LH_DefaultDomain_0&hash=item2c5ebe6da8#ht_1848wt_718
Aug 31, 2011 | Husqvarna Hand Held Blower 125 B Grass...
How to change the Primer bulb on a 235E chain saw?
Start by removing the top cover, the primer is an assembly, with a bayonet fitting into the air filter back plate, depress the two legs on the back of the primer whilst pulling the primer out, it should come away far enough to remove the two pipes from the back of it, note the orientation of the pipes so as to fit them correctly on the new prime, if you cannot get your fingers in to depress the legs use a small screw driver to push in one of the legs, use another screw driver to insert between the back plate and the primer to gently lever it out. The part no. of a new primer is 545008030
Aug 28, 2011 | Husqvarna Chain Saw Chain 14"
Primer button will not fill up
The primer bulb pulls fuel from the carb, into the bulb, and pushes it back to the tank. If the bulb does not fill there will be a number of reasons why, firstly if the saw is new, there will be oil in the carb from the starting prosess at the factory, the saw will start without fuel in the bulb, but will take many more pulls to get it going, once the saw starts and runs for a few minutes the oil in the carb will clear, and the bulb will fill normally when depressed, if your arm is not up to cranking the engine many times, remove the top cover, remove the air filter, dribble some fresh fuel/oil mix down the filter elbow, the saw will start after a few pulls. If the saw is a used machine the problem may well be a blocked fuel filter in the tank.
Feb 08, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
How to replace the fuel primer bulb and fuel lines in McCulloch 3516 chainsaw? the fuel primer bulb broke and the plastic lines have crumbled. i need to know how to run the lines from the fuel tank to...
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
Dec 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Where can i find the diagram for the fuel sysetem for a poulan
If the old lines are still attached, just replace one at a time. If everything is lying in a heap, then you will need to do a little sleuthing. Assuming the worst, begin with the line in the tank back end that holds the fuel filter (if it is old too--replace it). Be sure to use original rubber lines, not plastic. To connect the tank side of the line, you will need long hemostats or pliers to reach the tank fitting and the line must be long enough to allow the filter to be replaced from the opening. On the top side of the fitting, the line goes to the upper connection on the carburetor, but first run it to the primer bulb (which should be in good condition as well). Hook it either port, and attempt pumping fuel from the tank. If the correct port, it will draw fuel from the filter into the primer and expel it out the other port after about 3-6 pumps. If nothing, move the line to the other port and try pumping again. Once you get fuel to pump, then run a line from the open port into the tank for the return line. Remove the fuel line from the other port and attach it to the upper carburetor port. Run another line from the lower carburetor port over to the open primer port. Attempt pumping fuel again, this time pulling it through the carburetor into the primer bulb and expelling it back into the tank. All connections are just push-on and no cement required. Don't use more length than required for any section. Hope this helps!
Jun 08, 2010 | Poulan 14" Chainsaw
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Primer Bulb cracked Need new one?
remove carburetter air filter cover,two 'torx' screws on top.primer bulb is retained in case by 2 plastic 'ears' push ear[s] in& bulb slides out of case.make note/label 2 fuel lines attached; one 'stem' on primer is longer than the other.replacements can be found @ lawnmower/small engine repair shops.
Oct 10, 2009 | Garden
Husqvarna Chain Saw Chain 14" Logo
47 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
