Question about Kenwood KDC-MP2035 CD Player
Is there a reset for kdc-mp2035
Checked all fuses, fine. no power at deck. turned up volume and deck shut down
SOURCE: Setting the time on a Kenwood KDC-MP2035
Make sure the power is off before setting the clock (hold down the "FUNC" button until nothing shows but the time). Then Hold down one of the buttons on the right side for like 3 seconds until the time starts blinking. I can't remember which button it is as I don't have the unit in front of me right now. Use the track buttons to adjust the time. Hope this helps!
Posted on Dec 22, 2007
SOURCE: Kenwood KDC-MP2035 security code
yo tengo un reproductor kenwood kdc-mp2035cr pero este no me reproduce nada solo me sale un mensaje que dice protect y no me deja hacer nada ni colocarle nada por el auxiliar
Posted on Jul 06, 2008
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
Bob Gemmell
  • 209 Answers
SOURCE: Help
This is a safety feature to avoid damage to internal components, the wiring must be shorting out to earth. Disconnect the speaker cable connector at the rear of the unit and try it, if it is ok then you have a speaker wire shorting out to ground. if it is still saying protect then disconnect the other wires one by one.
Posted on Aug 29, 2009
SOURCE: Kenwood KDC-MPV619. No remote. Need unlock code for deck.
I had the same problem with my kdc-mpv619. I had bought a new truck that didn't have a remote and the screen says enter code. You do need a remote to fix it, but what they don't tell you is a universal remote will work. I used my direct tv remote and looked up all the codes for kenwood.
The one that worked for me was 30337 (not sure if that would work for you).
1) The way I tested it was go to my stereo and I held down the display button + volume up button. (This should remove the - - - - sign but it will still say CODE).
2) Then you press the 5 button on the remote and if the screen says CODEK then you know the remote works.
(to switch from K to C to A to R press the (>>) button on the screen.
3) Enter the code KCAR (the display will say CODEKCAR)
4) Final Step is hold do the fast forward button (>>) on the screen.
It should work for you after that ;-)
Posted on Sep 25, 2009
My kenwood kdc-mp2035 display reads protect. how can it be reset so it works again?
Mine started to do the same thing and they said it was going into a power save mode and that I would just have to replace it :(
Nov 19, 2012 | Kenwood KDC-MP2035 CD Player
Kenwood deck kdc-mp2035 im not sure about blue wire or yellow or red
Normally on Kenwood, blue is not usually used, it's for power antennae, make sure it's end is not bare though. Yellow would be to a continuous 12volt+, for memory. Red goes to accessory, (+12volt) where only power when key on, or in accessory position.
Oct 15, 2011 | Kenwood KDC-MP2035 CD Player
Radio shuts down when volume is turned past half way. bad ground?
it could be several things, it could be a bad ground, a bad power connection, a bad speaker(s) or the deck itself could be bad, i would check all your connections first. if they all check good try disconnecting one speaker at a time.
Sep 13, 2010 | Kenwood KDC-MP235 CD Player
Kenwood KDC-MP2035 cd player has power and everything functions but there is no sound. The 10A fuse in the unit is good.
make sure that the power output is enabled. this will turn on you internal amp. I have the same unit and I fouund this to be a problem. If this does not work your out put amps might be fried. good luck.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 07, 2009 | Kenwood KDC-MP2035 CD Player
My cd player says need a code after I hit the reset button and I don't know the code.
i added a securtiy code to my deck changed my car battery and now i cant get my security code to go away i hold the control knob for 3 seconds and the deck goes off any advice
Aug 28, 2009 | Kenwood KDC-MP2035 CD Player
Deck shuts off, when loud, while idling or at stop lights.
You are working your deck to hard, it is overheating and shutting down (protection mode) You like it loud, you will need a 4 channel amp. Also check the ground on your deck to ensure it has a nice connection.
Jun 02, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Mp2035 cd player will not turn on.
My hunch is that the fuses blew. When you cut all three at once you shorted the battery to ground and most likely blew out the fuses. Check the fuses and let me know. That is my best guess. Good luck
-Andrew Hawkins
Jun 10, 2008 | Kenwood KDC-MP2035 CD Player
Call
depends on the deck, most its just anothewr name for mute.. it will mute to significantly lower the volume so you can talk on the phone..
May 09, 2008 | Kenwood KDC-MP2035 CD Player
How do you reset this deck
There is a reset button on the left front of the deck>
Feb 16, 2008 | Kenwood KDC-MP2035 CD Player
Dec 21, 2007 | Kenwood KDC-MP2035 CD Player
Kenwood KDC-MP2035 CD Player Logo
37 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
