Question about Vehicle Parts & Accessories
Coolant problems Hi Everyone, Yesterday evening, my A7 had gave a 'Coolant temperature too high" warning sign and state: Let engine run with vehicle stationary, It had never gave me any problem except yesterday, and my a7 has only 25km on it, I can't believe this happen so soon, I've check the coolant level and it's normal, no leakage anywhere around the engine area, I start the car this morning, and idle it for 15mins, everything seems ok, the coolant temperature reading station @ 90 degrees. So I start to drive out and after running the car on the road for 5mins, the coolant reading begins to rise and very soon it reach to the max and the coolant warning sign lights up, so I had to pull over. Too bad the car had just past the waranty period, so any help or advise will be much appreciate. 2011 October A7 3.0 TFSI
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 808 Answers
Test the engine thermostat and cooling fan operation slipping fan belt bad water pump.
Posted on Jun 02, 2014
    Sergeant:
  • 216 Answers
Check to see if the radiator cooling fan operates when the problem occurs. If the fan doe s not operate, check for a blown fuse in the fan cooling circuit. That the engine does not overheat when idling for long periods seems to indicate the radiator cooling fan operates normally.
If the radiator fan operates normally when the engine is hot, the likely culprit is the engine thermostat, which then should be replaced. Thermostats can fail "closed," their normal position when the engine is cold. When that happens, they will not open to allow adequate coolantr flow as the engine heats up. An idling engine des not require much coolant flow to remain cool as it is not working very hard. When powering the car down the road, excessive heat is trapped in the cooling system and cannot be radiated by the radiator away due to the failed thermostat stuck in its closed position.
Posted on May 30, 2014
4 Suggested Answers
  • 17328 Answers
SOURCE: I drive a 2001 Chevy Tahoe with around 164,000 miles on it. I just got the power steering pump replaced yesterday and drove it last night and today and now when I turn corners it's making a really bad
Make sure that belt is tight. Make sure the connection to the pump is lined up correctly. Last but not least you may have to flush the whole system and refill it.
Posted on Apr 01, 2013
  • 35 Answers
SOURCE: 2000 BMW 5series, battery will not stay charged, and engine runs hot
it does not sound like a battery problem from the info provided. It sounds like your battery terminal post is not connecting at the battery. A cable may have a bad connector end on it and the car runs on the alternator once started. Buy a ten dollar volt/ohm meter and check the ohms resistance in the cables by removing the cables from the battery first and then connecting the test leads to the ends of each cable. The meter should read the same as if the leads we're connected to each other. To test the battery change the ohm meter setting to read volts DC in the 20 to 50 volt range and connect red to positive ( + ) side of battery and black lead to negative side ( - ) of battery. Battery must read more than 11 volts for most modern cars to engage the starter circuit, most working batteries will show more than twelve volts. Jump Start the vehicle with the battery connected and with the booster battery disconnected again test the voltage and it should read 14.5 to 15.5 volts. you may need to replace one or both cables or have the ends at the battery replaced. obviously the cables that run the starter are good or a booster battery would not work either. good bluck.
Posted on Jan 01, 2014
projdoc
  • 2237 Answers
SOURCE: Audi coolant
check the overflow tank and take the radiator cap off (when it's cooled down). if there is radiator fluid in either or both of them, you could have a stuck thermostat or a bad water pump. check the thermostat first.
Posted on Mar 01, 2014
Why susuki cultus reduce coolant level without over heating
Suggests sign of internal leak. Check dipstick for engine oil to see if there is a sign of coolant mixed with engine oil. (Generally foaming of oil instead of amber or dark solid color) (Could even show level is high due to coolant adding to oil and raising level.)
If there is, it's a very serious problem.
One quick way to try a very inexpensive fix that's worked for me is a product called Barr's Leak. (It's worked twice for me on two cars.) Get the expensive "copper" version (looks like liquid copper) and add to your coolant system following manufacturer's instructions. Top off coolant and then drive car for a couple of full engine temperature sessions.
If coolant then no longer goes down, change engine oil draining out old coolant that may have contaminated it and refill with new filter.
Keep an eye on level after that to see if coolant level remains stable.
If coolant still goes down, a engine over haul or new engine may be needed.
May 22, 2014 | 2005 Suzuki Esteem
Tip
Komatsu Fault Codes
E02 PC-the EPC system;
E03, Swing parking brake system;
E10, the engine controller power failure, the engine control drive system circuit malfunction (this engine stall;
E11, the engine control system failure (decrease of output power, in order to protect the engine);
E14, the feedback system abnormalities;
E15, engine sensors (temperature, fuel pressure, oil pressure) fault;
EOE, a network failure.
The fault code: the 989L00 the engine controller lock warning (mode 1).
989M00, the engine controller to lock warning (mode 2).
989N00, the engine controller to lock warning (mode 3).
AA10NX air filter clogging.
AB00KE charging voltage is too low.
B @ BAZG, low oil pressure.
B @ BAZK, the oil level is too low.
B @ BCNS, engine coolant overheating.
The @ B BCZK the coolant level is too low.
B @ the HANS, the hydraulic oil from overheating.
CA111, the engine controller internal fault.
CA115, the engine speed sensor and backup speed sensor failure.
CA122, the intake air pressure sensor feedback voltage is too high failure.
CA123, the intake air pressure sensor feedback voltage is too low failure.
CA131, the throttle plate sensor feedback voltage failure.
CA132 throttle plate sensor feedback voltage and low failure.
CA144, high coolant temperature sensor feedback voltage fault 145, the coolant temperature sensor feedback voltage is too low failure;
CA153, intake air temperature sensor feedback voltage is too high failure;
CA154, intake air temperature sensor feedback voltage is too low failure;
CA155, the intake air temperature is too high (over limit);
CA187, sensor power supply voltage is too high failure;
More Fault Codes HERE http://truckmanual.weebly.com/komatsu-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
Y dose the john dear 6330 run hot all the time even after it blowen out
Engine or hydraulic system overheating clearpix.gif clearpix.gif clearpix.gif clearpix.gif clearpix.gif clearpix.gif Coolant system low on coolant in 6020, 6030, 6030 Premium, 7020, 7030 and
7030 Premium Series Tractors.
]clearpix.gif//-->
Symptoms
After several hours of work, warning system indicates hot engine coolant or hot hydraulic oil.
Situation or Problem
Coolant level in reservoir is between the "MIN" and "MAX" range but engine or hydraulic system is overheating.
Summary
Air is entering cooling system, hindering coolant flow. Check coolant level. Fill to the "MAX" line on the coolant reservoir.
Bleeding Cooling System:
The bleed valve (see Operator's Manual for location) on the radiator must be closed when the tractor is operating. Open the valve when coolant is drained or filled. If the bleed valve is left open, coolant will internally bypass between the low temperature circuit and engine high temperature circuit causing overheating. When bleeding the system, open the bleed valve and run the engine with no load for 5 minutes at 1700 rpm. Then shut engine off for 5 to 10 minutes before closing the drain valve. Check the coolant level. If level is below the "MAX" fill line, repeat this procedure until coolant level stays at the "MAX" line.
May 21, 2014 | Cars & Trucks
Top up coolant with water
Water is fine since its warmer weather coolant is used mainly so it doesn't freeze as water would. You should be fine as long temps don't get below 32 degrees waters freezing point.
Jul 06, 2017 | 2006 Audi A8 4.2
No DTC definition code found p1114
Hi there:
DTC P1114 - Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
The engine coolant temperature sensor is a thermistor (a resistor which changes value based on temperature) mounted in the engine coolant passage. Low coolant temperature produces a high resistance 100,000 ohms at -40 oC (-40 oF) while high temperature causes low resistance 70 ohms at 130 oC (266 oF).
OPERATION
The VCM supplies a 5 volt signal to the engine coolant temperature sensor through a resistor in the VCM and measures the voltage. The voltage will be high when the engine is cold. The voltage will be low when the engine is hot. By measuring the voltage, the VCM calculates the engine coolant temperature. Engine coolant temperature affects most systems the VCM controls.
The scan tool displays engine coolant temperature in degrees. After engine start-up, the temperature should rise steadily to about 9O oC (194 oF) then stabilize when thermostat opens. If the engine has not been run for several hours (overnight), the engine coolant temperature and intake air temperature displays should be close to each other. When the VCM detects a malfunction in the Engine Coolant Temperature (ECT) sensor circuit, the following Diagnostic Trouble Code (DTC) s will set.
Hope this helps.
Feb 15, 2013 | 2000 Audi A6
I have a problem with the code P0118 of my 2002 Jetta GL can you help me?
Make sure coolant level is as it should be. If level is low look for evidence of leak(s). Top off fluid if necessary. The engine coolant temperature sensor is a very common issue with these vehicles and may be the cause of your issues if no leaks are found. Also a faulty thermostat cans cause the sensors to read voltage high but most likely a sensor issue. The sensor is a potentiometer (variable resistor). The computer sends 5v through one of the wires this voltage goes through a resistor which will vary the voltage based on temperature sensed by the engine coolant temperature sensor. The sensor has a negative temparature coefficient meaning the resistance will go down when temperature is high and up when temperature is low. The less resistance the more of the 5 v gets back to the computer. The PCM detects this high voltage and set the check engine light on warning you of an issue. Whe this sensor goes bad it is usually accompanied by temperature gauge fluctuation or erratic operation and the cooling fans run long or all the time even though the vehicle is cold. Hope this helps.
Feb 14, 2013 | Cars & Trucks
Hi there i have a 2007 vauxhall zafira lossing coolent needs top up every two weeks at times smells of burning rubber and gets very somkie can run this off after about 5 minutes
Get the coolant pressure tested,its definitely leaking coolant.You will need to get the coolant running line.
Pressure test will help you to know from where exactly coolant/refrigerant is getting leaked.===========For complete step by step troubleshooting i suggest you to go through the help links mentioned below :----Click the link below :-----
Coolant enters in transmission on Toyota Land cruiser?
http://schematicsdiagram.blogspot.com/2012/01/coolant-enters-in-transmission-on.html
1991 Toyota Camry: Order Coolant Bypass Tube?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-camry-order-coolant-bypass.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
1994 Toyota Camry: Coolant Leak?
http://technoanswers.blogspot.in/2012/04/1994-toyota-camry-coolant-leak.html
2006 Cadillac DTS: COOLANT LEAK AT DRIVER SIDE NEAR FIREWALL?
http://schematicsdiagram.blogspot.in/2012/04/2006-cadillac-dts-coolant-leak-at.html
MAF, IAT, MAP and Coolant Level Sensor problem all together on Mazda MPV?
http://schematicsdiagram.blogspot.com/2011/12/maf-iat-map-and-coolant-level-sensor.html
GMC Engine Coolant Temperature (ECT) Sensor Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-engine-coolant-temperature-ect.html
Loosing Coolant?
http://whoisbyme.blogspot.in/2012/06/loosing-coolant.html
Coolant temperature sensor dies again and again?
http://schematicsdiagram.blogspot.com/2012/01/coolant-temperature-sensor-dies-again.html
2000 Daewoo Lanos: Where to Add Coolant?
http://repairhelpcenter.blogspot.in/2012/06/2000-daewoo-lanos-where-to-add-coolant.html
Blue Water Warning Light on Dash?
http://whatisbyme.blogspot.in/2012/07/blue-water-warning-light-on-dash.html
Replacing Oldsmobile Engine coolant sensor?
How to test Engine coolant temperature sensor?
Replace Coolant Sensor Module on Oldsmobile?
These details will help.
Thanks.
Nov 27, 2012 | Cars & Trucks
1995 ford ranger
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?fromSearchPage=true&pageId=0996b43f802c551c&partName=Engine+Coolant+Temperature++ECT++Sensor&partId=0996b43f802c551c I f your coolant temperature is normal and no leaks from water pump,then it could be the coolant temperature sensor,real easy to replace.I will send another link of the part.
Aug 18, 2012 | 1995 Ford Ranger Supercab
Code 1 senser P0118 on a 2004 V.W beetle dicesel
P0118 for Volkswagen - (ECT) Engine Colant Temperature Circuit High
Symptoms:- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes:
(Inspect the following... Repair/Replace if necessary)
- Low engine coolant level
- Engine Coolant Temperature (ECT) sensor harness is open or shorted
- Engine Coolant Temperature (ECT) sensor electrical circuit poor connection
- Faulty Engine Coolant Temperature (ECT) sensor
- Faulty engine coolant thermostat
P0118 VOLKSWAGEN Description: The Engine Coolant Temperature (ECT) sensor is used to detect the engine coolant temperature. The sensor modifies a voltage signal from the Engine Control Module (ECM). The modified signal returns to the (ECM) as the engine coolant temperature input. The sensor uses a thermistor which is sensitive to the change in temperature. The electrical resistance of the thermistor decreases as temperature increases.
When is the code detected?:When an excessively high voltage from the sensor is sent to ECM.
I hope this helps! Let me know if you need further assistance.
Mar 08, 2012 | Mercedes-Benz C Cars & Trucks
I just purchased this truck n it smells like it is running hot?
Modern engines run at high under hood temperatures. If the temperature gauge is running normal and there is no signs of steam out of the water bottle, there should be no problem, but keep an eye on the coolant level and check the engine after a long slow run if you are still worried.
Feb 06, 2011 | 2003 GMC Envoy
Vehicle Parts & Accessories Logo
99 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
