Maginon just bought a maginon action camcorder ac-500 touch but it will not install says have to go to maginon for instructions
2 Suggested Answers
  • 45112 Answers
SOURCE: How do I obtain an instruction manual for the Maginon wk 2 wildlife camera
Try Googling (maginon)(wk2)(manual) without parens.
Posted on Apr 24, 2017
Apr 24, 2017 | Cameras
Camera turn off USB plugged in laptop to charge ( first charge) the battery, SD class 10 HD card installed, now charging light goes on for a very short time and then goes off . as in fully charged. wh
A better that came with a new camera, most of the time is not defect. Please charge it at least 2 times, before you say it is defect.
If possible, use an external charger, because not all USB ports on a computer can deliver 5 volts and 500 mA (Ampere)
Oct 25, 2014 | Vivitar Sakar - DVR785HD-BLU - Blue 5MP...
Camcorder sony hdr-ax2000e turns itself off
hello, does it show any error code before is shuting down?
May 28, 2013 | Sony HDR Video Cameras
How to install upgrade sdram 128 pc133 for gateway 500
INSTALLATION PROCEDURE
1. Place the computer's power switch in the "off " position and disconnect the AC power cord. 2. Remove the computer's top cover following the instructions in the model-specific owner's manual.
3. Before touching any electronic components, make sure you first touch an unpainted, grounded metal object to discharge any static electricity stored on your clothing or body.
4. Locate the memory expansion sockets on the computer's motherboard. If all the sockets are full, remove smaller capacity modules to allow room for higher capacity modules.
5. Handle your new module's carefully; do not flex or bend the module(s). Always grasp the module by its edges.
6. For some installations, DIMM memory can be installed in any available expansion slot. Other installations may require the memory to be installed in a particular sequence based on the modules capacity. Check your owner's manual to determine the correct installation sequence for your configuration.
  • Insert the module into an available expansion socket. Note how the module is keyed to the socket. This ensures the module can be plugged into the socket one way only. Firmly press the module into position, making certain the module is completely seated in the socket. Repeat this procedure for any additional modules you are installing.
  • Most 168-pin DIMM modules have ejector tabs. The ejector tabs are used only when you need to remove a module. By pressing down on the ejector tabs, the module will pop-up from the socket and it can be removed.
    7. Once the modules have been installed, the computer's top cover can be reinstalled.
    8. Plug in the AC power cord and reinstall any cables disconnected during the installation process.
    9. Turn on the computer and follow the instructions in your computer owner's manual that describe the steps necessary to allow your computer to recognize the newly installed memory.
    May 03, 2010 | Gateway Essential 500 PC Desktop
    I need the installation Instructions for a Kenmore 500 Dryer
    While this manual is not for your specific Kenmore dryer, the Kenmoreinstall directions for the model in the manual will be the same. Start on page 5
    http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502231.pdf
    Nov 21, 2009 | Kenmore 500 6952 Dryer
    I had a power surge and my sony dcr-trv350 will not trn on is it worth fixing?
    Follow this procedure to troubleshoot if the camcorder will not turn on.
    IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
    1. Remove the battery from the camcorder.
    2. Connect the AC power adapter to the camcorder.
    3. Plug the AC power adapter into a working electrical outlet.
    4. Attempt to turn on the camcorder.
    5. Reset the camcorder back to factory settings.
    6. NOTES:
      • If the camcorder does not operate using the AC adapter, service may be required .
      • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
    7. Ensure the battery has been fully charged.
    8. Ensure the battery is properly inserted into the camcorder.
    9. Remove the AC power adapter from the camcorder.
    10. Attempt to turn on the camcorder.
    11. NOTES:
      • If the camcorder does not turn on, then the battery may need to be replaced.
    Aug 14, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
    I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
    Power Adapter for Mactor OneTouch 4
    AC Input : 100 AC - 240 AC (50/60HZ)
    DC Output ( V/A ) : 12V / 3.5A
    Output Power : 42W
    Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
    How to record with dates
    you shoul really need to look at the instructional functions of the can corder . simply look for the settings for you to get the right file
    Mar 13, 2008 | Canon Optura 500 Mini DV Digital Camcorder
    Computers & Internet Logo
    186 people viewed this question
    David Payne
    David Payne
