How to remove yellow in center of screen on panasonic pt-52lcx66-k hdtv
    Master:
  • 687 Answers
You might start by cleaning the lenses & mirror(this may use a Mylar sheet rather than mirror,don't try to clean the mylar) then install a new lamp
part#: TY-LA1001 $70.00 http://www.tvpartsguy.com/servlet/the-11855/TV-Lamp-TY-dsh-LA1001-for/Detail
or $49.00 to $80.00 http://www.shopjimmy.com/catalogsearch/result/?q=ty-la1001
If that doesn't cure it you most likely need a new light engine/optic block which would make the repairs cost prohibitive even if you can locate the light engine.
Posted on Jun 05, 2014
  • 3 Answers
SOURCE: grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Posted on Jun 04, 2008
SOURCE: reset lamp counter on PT-52LCX66/PT
i aswell dont have PIP on remote but i found another way to fix....
hold the volume button ON TV - down and the 0 zero button on remote at same time :) just worked for me...
Posted on Jul 29, 2009
MNfisherman
  • 11896 Answers
SOURCE: my panasonic pt-52lcx66 it wont turn on what can i do myself
yes they do; They have glass fuses than have the thin wire running across on the inside. If the wire isn't running all the way across the fuse or is broken, then it is junk. If fuses is good, then power supply may be faulty which is quite common these days with newer electronics
Posted on Aug 27, 2009
tvtek
  • 1284 Answers
SOURCE: where do i locate lamp in my panasonic pt 52lcx66
The left speaker grill comes off then the lamp door will be behind there. Mind you if the lamp in your TV still works and you are changing it. Make sure that you let the TV cool down for a minimum of an hour before handling the old lamp. Also your lamp part number is TY-LA1001. Please take a moment to rate my answer. Thanks...
Posted on Nov 24, 2009
Testimonial: "Rite on thanx"
pabloloco
  • 2335 Answers
SOURCE: changed bulb on panasonic PT-52LCX66-k and cant reset timer.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
The buttons used are the TV's volume down and the remote's number 0.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Posted on Apr 11, 2010
How to remove yellow color in center of tv screen on pt-52lcx66-k panasonic hdtv
May 15, 2014 | Panasonic PT-47WX53 47" Rear Projection...
How do I reset a lamp counter on a PT-52LCX66/PT TV?
I hope that helps.
Feb 20, 2010 | Panasonic PT-52LCX66 Projection Television
I NEED TO RESET LAMP TIMER PANASONIC PT52LCX66.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV. Follow these steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Jan 27, 2010 | Panasonic PT-52LCX66 Projection Television
The lamp hour meter needs to be reset for Panasonic PT-52LCX66 Television. How do i reset it?
This works for most Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-52LCX66 Projection Television
How to change the bulb in my panasonic 52 inch model # pt-52lcx66 tv
I can help you change your bulb and reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
  1. Installation instructions for the TYLA1001 bulb are here.
  2. Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Aug 22, 2009 | Panasonic PT-52LCX66 Projection Television
Changed bulb on panasonic PT-52LCX66-k and cant reset timer.
I hope that helps.
Apr 11, 2009 | Panasonic PT-52LCX66 Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
