Question about Apple Customized 15" MacBook Pro Laptop Computer Notebook
My laptop won't charge. It was working when plugged in and now it won't even do that. Will replacing the battery fix my problem?
  • 48 Answers
It sounds like your battery and your charger are not working. Changing the battery should help, but you should first check to see if you are getting voltage to the laptop. Does the green light on the magnetic end (the end that plugs into laptop) light up when plugged in? If so, your charger is working. You should be able to turn on the laptop with or without a battery (even a dead battery) with a good power supply. If you can turn it on, check to see the number of battery cycles you currently have.
Follow these steps to access information about your Mac notebook battery including the cycle count:
  1. Your first step will vary depending on which version of Mac OS X you are using:
    • OS X Snow Leopard v10.6.8 or earlier: Open Apple System Profiler by choosing "About this Mac" from the Apple menu. Then, click More Info.
    • OS X Lion v10.7 or later: Open System Information by choosing "About this Mac" from the Apple menu. Click System Report.
  2. Click Power in the Contents list (under the Hardware section as shown below).
  3. The current cycle count is listed under the Battery Information section.
My laptop won't charge. It was working when plugge - ht1519-system_profiler-cycle_count-002-en.png
Take notice of Full Charge Capacity (mAh) on your machine. It should be close to the number shown above. If it is much lower than that and/or the cycle count is above 1000, it is time to replace the battery. I hope this helps.
Mac notebooks Determining battery cycle count
Posted on May 15, 2014
  • Christi Giamanco May 15, 2014
    The green light stays on on the charger, however the lights on the computer that gradually light up when it charges do not. The first one goes on right when plugged in and then dies out. The computer won't turn on at all, even when plugged in
Battery charging but laptop won't work while plugged in
The purchased is sub standard. Get a replacement from the store. N.B the fujitsu charger will work for some
Time and damage your laptop because of the higher amp
Jan 27, 2013 | Toshiba Satellite Computers & Internet
Despite of new battery my Asus PRO50 won't charge a 100%
Is it a replacement battery? Are the specs the EXACT match, DC volts and Amps? Some inexpensive batteries do not work well with your laptop, it's a Connector/ pin thing, they don't communicate with the laptop. Try pulling the plug and drain the battery and recharge. Cycle it a 4 times, drain/ recharge. Does your BIOS setup have a Battery Learning section?
Dec 13, 2012 | ASUS Computers & Internet
My laptop says its plugged in but not charging, what is the problem?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 11, 2012 | Dell Computers & Internet
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
My Asus Eee PC 1001PXD battery won't charge. The charges light is on but nothing happens and now the battery is completely dead and I cannot get my notebook on
Your problem is far more than the battery. Your problem is the power cord. Laptops for the most part will work off the power cord even if the battery is dead or even if the battery is not in the laptop. Your power cord charges your battery and if it is bad it will not charge it. You've been working off your battery even though you might have had the power cord plugged in, but if it's bad and not charging the battery, the battery drains and then you can't get the laptop to power on at all. Go purchase a ac adapter and power cord that is designed for your system. Don't buy one that some of the big box stores sell that has a an interchangeable plug at the end designed to fit just about any laptop. Those will eventually burn *********** board out.
Mar 20, 2012 | ASUS Computers & Internet
Dell Studio 1440. New battery&adapter won't charge
You either have one of the following:
1. Bad Battery
2. Wrong adapter - yours no comprende w/ unit.
3. Cracked Jack - means you've got to get a tech to take the unit apart and replace it. $150-200
4. Goto your device manager, double click bat., then right mouse click on acpi driver and update it. Hopefully that works.
or
5. Dell needs to shoot out a bios flash fix.
Feb 16, 2012 | Dell Studio 15 Laptop
My HP pavilion ze4949 will not charge the battery. I got this laptop 2nd hand, and the "charging" light that the manual states should be lit while the AC adapter is plugged in has never lit;...
Take the battery out and see if the A/C charger will run the PC.
If so the portion of the PC Motherboard that charges the battery has failed.
The Motherboard is the heart of the PC and quite difficult to replace at home.
Go to a PC repair and see if it is worth fixing. BIG Labor cast.
Sorry!
Aug 13, 2011 | HP Pavilion dv6000z Notebook
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Inspiron mini 10 Running on battery even when a/c is plugged in restart computer and plug in a/c again and charges up but then drains battery again
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Dell Inspiron Mini 10 Notebook
Computers & Internet Logo
74 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
