Question about Freezers
Was offered a new energy efficient freezer 16.7 cu foot standing frost free by Fridgidaire ( energy efficiency rating 65). My 13 yr old Kenmore: Model : 253.9287215 Freezer works fine. Is it rated the same and does it have more cubic feet. I can't find there answers and don't want to give up my kenmore if there is more storage in it and it is just as efficient . Do you know the answers to these questions?
    Scholar:
  • 73 Answers
I was not able to find any info quickly on your older Kenmore in my literature but its a sure bet that it was not as efficient as the new one. You can do a calculation or look at the plate (usually on the back) that states the amperage draw on each model- the higher one is the less efficient. As for cuft you need to do the math and measure the inside storage area in inches wide, inches deep and inches tall. Multiply the width X depth X height then divide by 144 (the cu inches in a cubic ft) this will give you the actual size of the Kenmore for comparison. Hope this helps... also you may want to check with your local electric utility company as many are offering a rebate to replace 10 yr old fridge. freezers and usually pick up for free.
Posted on May 22, 2014
  • Kim Adzigian May 22, 2014
    Thank you so much! That was very helpful. I plan to get the new one. I know appliances are no longer built to last anymore so was trying to figure out if the savings on yearly electric bill and storage capacity was worth getting the new one that may not last as long. Would I come out ahead or not . The amperage in the specs for the new one looked higher than the old one but I think that must be an error and meant as max amperage and not an average. Thanks so much for you help. I will do more calculations.
fridgetech
  • 473 Answers
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Posted on Oct 12, 2007
  • 161 Answers
SOURCE: Old Kenmore Freezer
It is uaually coded into the model #. Usually in the middle. I can usually eyeball them. another solution is measure the outside dimensions of a refrigerator or freezer you know the size of then compare them. This will give you a rough estimate.
Posted on Jun 30, 2008
  • 358 Answers
SOURCE: fan is squeaking all the time Kenmore frost free upright freezer
Yes you need to replace it,if dont will have bigger problems.
Posted on Apr 03, 2009
  • 97 Answers
SOURCE: won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Posted on Jun 17, 2009
bobicehouse
  • 1524 Answers
SOURCE: We have the Kenmore frost free, 20 cu. ft.
Faulty alarm.
Posted on May 29, 2010
Freezer seems to run all the time.
Good Morning Linda, this is Z. I appreciate your post!
I understand your Frigidaire freezer seems to continuously running. Unlike older freezer that turned off and on frequently, newer models save energy from having to start up and shut off repeatedly. For example, diesel-powered trucks conserve fuel and energy and therefore have less engine wear and tear by keeping the motor running; much like newer energy efficient refrigerators/freezer. If the compressor is running on a more constant basis; it is maintaining the temperature within your freezer, rather than having to cut off and start again to adjust the temperature.
I hope this information explains why your freezer runs more often. However, should you feel that a service technician is needed; you may visit the manufacturer website to find a provider in your area that will look at your freezer.
Best regards!
Aug 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Why is my fridgidaire freezer is buzzing?
if it is a frost free freezer you may have ice build up around fan blade
Jul 17, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The freezer seems to be running a lot. Is this normal for an energy efficient freezer?
Good day,
Yes, the new high efficiency units tend to run a lot compared to older models. That in fact is not a bad thing, since the compressor has to cycle on and off fewer times per day, and starting and stopping are what create wear and tear on refrigeration equipment. Actually you pay less because of the much smaller compressor that uses less power.
However, keep an eye on it. If it gets continually worse going forward, call for service. Hopefully Frigidaire has solved it's problems but was known to develop internal restrictions in the refrigeration system causing that problem to the point it runs continuously and fails to cool properly.
If the machine is under 5 years of age it would be corrected free of charge.
Oct 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Only one half of my chest type freezer freezes? It is old. Bought at least 18 years ago. Help!
My recommendation is to get rid of this 18 year old freezer as it is costing u a fortune to keep it plugged in. Then ask yourself if you really need an additional freezer at all?? If you do, consider purchasing a new small one that is really energy efficient. You will be way money ahead I assure u.
Apr 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Commercial reach in freezer
Hi scondon15,
I just read this article about the subject you ask about!
How old is the freezer?
Repair or replace?
When to pull the plug on your old refrigerator and or freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 19, 2008 | Piper Products Freezers
Freezer door left open
Hello Captain rose,
Did you turn off the freezer and then pull the plug?
Try this again. Turn off the freezer then pull the plug for 4 minutes, plug it back in and turn it on.
Do you hear the compressor turn on?
It should only take 24 hours max. to get back to full temperature!
If this does not help and you hear no compressor, especially if it is an old freezer .
They may have burned out the old compressor by causing it to work 2 hours straight .
Rather than cycling off and on every half hour or so!
If it was an old freezer, so it means it was on its last legs and would have happened some time soon any way!
Here is an article I read abut the age of refrigerators and freezers.
Repair or replace?
Thank You, HUUUM
Sep 17, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer - top shelf frosted over -- poor cooling through rest of freezer
Hi yadak,
Happy to help.
You may need a new door seal.
But they are not easy to put on properly
and I would not recommend spending a lot of money on a ten year old freezer!
the new ones are much more energy efficient and will save you a lot of money!
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 08, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
147 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
