Question about LG LFX25976ST - 3-Door French Door Refrigerator with Ice and Water Dis
The ice is in the try but its not dumping the ice the lever is not all the way down its like its stuck
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: The ice maker will not
Hello, welcome to FixYa.
With the info you posted, I suggest running an icemaker test or attempting a "reset". The reset is done by simply shutting the stop/power switch "off" and then back "on".
The trouble shooting/test is done by way of pushing and holding the stop/power button on the side of the icemaker as shown below...also called a forced harvest mode as you may or not know...
This should be your icemaker and this will identify the components...
Let me know how you manage and I'll try to assist you going forward in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on Jun 24, 2011
Ice maker not dumping ice into bin. bin empty and ice in tray
check the operator manual for a switch or lever that is stuck or in the off position.
Aug 21, 2015 | Refrigerators
Ice maker makes ice but doesn't dump the ice, lever stuck in upward position
consequently the same thing happened to me but what I done was sell it trust me it wont work
Apr 01, 2015 | Refrigerators
How do I get to the ice dispenser lever switch on a Amana side by side
have you ever tried just lifting the lever up and leaving it there. normally that prevents the ice machine from dumping the ice which then stops making the ice until the lever is moved back down. Hope that helps!...Rick
Mar 30, 2012 | Amana ASD2628HE Side by Side Refrigerator
The ice maker isn't working. the ice tray was stuck in dump position.
Unplug your unit then plug it back in. Ensure that there is not ice stuck in the release lever.
Jan 08, 2011 | Refrigerators
After 2yrs of not using the icemaker, moved
Good day,
Pour water from small paper cup until it near fills the well of the ice maker. With the lever down, close freezer door and wait 2 to 3 hours. If it dumps then the ice maker should be good, if not, replace ice maker.
If dumps O.K. then the dual water valve is bad, and needs replaced.
You should check the fill tube that runs from the back of the machine to see if it is blocked with ice. (requires removing ice maker) but even so, if it is iced, you'll need to clear, but the water valve in the back rear of the machine is leaking and still needs replaced.
Thanks for using FixYa
Dec 20, 2009 | Refrigerators
Ice not dumping
There is a thermostat in the IM to sense when the ice is ready. Check that first...Eric
Sep 12, 2009 | Samsung RB215LASH
Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Maytag MSD2456G Side by Side Refrigerator
Icemaker is not dumping ice. Lever is in the down
the heaters go south in the tray and cant eject , need new one
Aug 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker and water dispenser
Defective solenoid on dispenser line or bad/leaky tubing at exit of solenoid are the likely culprits for your water problem. The lever "Must" move freely to "monitor" the level of the ice in the bin. If stuck or hanging up, the unit goes into "standby mode"......accordianman
Apr 03, 2008 | Amana SXD524VW Side by Side Refrigerator
Samsung Icemaker Problem
I also had the ice tray stuck in the dump position. I unplugged it waited 5 minutes and pluged it back in. And the Ice tray moved back into the correct fill position, and the arm did drop down, But now it has not filled with any water. So now what should I try?
Feb 20, 2007 | Samsung RS2534 Side by Side Refrigerator
LG LFX25976ST - 3-Door French Door Refrigerator with Ice and Water Dis Logo
35 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
