Question about Grizzly Big Bear Atv Maintenance Free Battery
Yamaha grizzly 660 shift linkage adjustment
I am having a really hard time getting it into park and getting the park light to light.Is this a linkage adjustment problem and if so how is it adjusted
    Problem Solver:
  • 10 Answers
Will it not go into park or will the light not come on? If it goes into park look at the switch.
Check and make sure there is nothing binding the shift linkage or that the linkage is not bent. If all looks good adjust it.
Adjust your shift linkage just enough for it to go into park. Then check engagement in other positions
Posted on May 16, 2014
2002 660 grizzly red light reverse light comes on then it starts to cut out
sounds like your reverse sensor is bad and the cdi limits rpms while in reverse as a safety thing.
Dec 06, 2016 | Yamaha 2004 Grizzly 660 Auto 4x4
Why won't my grizzly 660 go into neutral so I can start my bike
K, Linkage probably needs adjusted.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2006 GRIZZLY 660 MOD HELP and SHIFTER ISSUES
http://www.yamaha-motor.com/assets/service/manuals/2008/lit-11626-21-03_griz660_all_1498.pdf
Mar 20, 2016 | Yamaha 2004 Grizzly 660 Auto 4x4
2008 Grizzly 450. Starts and idles fine but at about 10 mph why does it start to cut out like a rev limiter?
2011 grizzly 450 reverse rev limiter - Yamaha Grizzly ATV Forum
www.grizzlycentral.com > ... > Grizzly Engine & Transmission
Mar 11, 2012 - 9 posts
This is a discussion on 2011 grizzly 450 reverse rev limiter within the ... is for earlier model years like 2008. thanks for welcoming to the site :) rev limiter - Yamaha Grizzly ATV Forum
May 23, 2009
Grizzly 700 Reverse rev-limiter Override Mod - Page 3 ...
May 21, 2009
Hitting rev limited/ slow speed.... - Yamaha Grizzly ...
May 20, 2009
reverse rev limiter - override witch bypass - Yamaha ...
Oct 22, 2008
More results from www.grizzlycentral.com
Rev Limiter - GrizzlyOwners.Com Yamaha Grizzly Forums
www.grizzlyowners.com > Grizzly 660 > Modifications
Old 06-30-2008, 10:43 AM Thread Starter. modrak .... jasson450r is offline ... hey guys! how do you do this rev limiter mod on a 06 660 griz? i'm interested in ...
How to bypass reverse switch Grizzly 700(speed limiter ...
? 1:03
https://www.youtube.com/watch?v=l8nn5Z4cuN0
Dec 25, 2015 | Yamaha Motorcycles
Why would my 660 grizzly pop in & out of forward gear, jus whines, jumpin in & Out ???
Grizzly 660 Shifting problem. - Yamaha Grizzly ATV Forum
www.grizzlycentral.com > ... > Grizzly Engine & TransmissionMar 12, 2012 - 4 posts This is a discussion on Grizzly 660 Shifting problem. within the Grizzly Engine ....2005 grizzly 660 gear position sensor problem.
Aug 17, 2015 | Yamaha 2005 Grizzly 660 Auto 4x4
Backfires when you try to rev up engine,
check fuel flow and check spark at spark plugs
According to an "ATV Rider" 2009 article, "When the Grizzly was introduced in 1998 as a 600cc machine, the top was blown right off the displacement wars of the time."
It was replaced in 2002 with Yamaha Grizzly 660, an even bigger engine derived from the well-established all-terrain vehicle (ATV) Yamaha Raptor 660R.
Grizzly's 660 cubic centimeter (cc), four-stroke, liquid-cooled single overhead camshaft, five-valve engine performs well in open country, but sometimes it causes serious problems for owners.
Before you call a Grizzly dealer, however, trying a few tricks in your garage can save you a lot of time and money.
Check the fuel level.
Locate the fuel meter indicator on top of the multifunction display.
If it does not work properly, open the fuel tank, and push the Yamaha 660 Grizzly side to side.
Ensure the fuel is not contaminated by water or rust.
If you have not driven your Grizzly 660 for a long time, drain the tank completely, and fill it with a fuel tank cleaner.
Check fuel hoses for cracks or leakage.
The hoses should be soft and simple to bend.
Replace those that show any sign of wear.
Check the compression.
Screw a compression tester into the spark plug hole, and press the electric starter button.
If no compression exists, contact a Yamaha dealer.
Wipe wet or dirty electrodes with a dry cloth.
The spark plug gap should be checked regularly
Correct the spark plug gap.
Measure the gap with a wire thickness gauge.
If necessary, adjust it to 0.8mm using a screwdriver or replace the spark plug.
Use only a Yamaha-specified spark plug.
Check the Yamaha 660 Grizzly's battery.
Operate its electric starter.
If the Grizzly starts quickly, then its battery is in good condition.
If the engine turns slowly, check the battery lead connections, and you may need to change the battery.
If the engine still does not eventually start, your Grizzly is beyond home repair.
Jul 23, 2013 | Yamaha 2005 Grizzly 660 Auto 4x4
I have a 2007 Yamaha Grizzly 660. It was running
It sounds like you got some corrosion going on, on the ground side. I would start with the battery cables first and see if they need cleaned up, then go to the connectors and unplug them and clean if necessary and put die-electrical grease in the sockets of the connectors before plugging them back in. I am assuming that the shifter is electrically assisted if there are problems going on with it as well...this is what makes me believe that it is a bad ground due to setting maybe in a damp inviroment.
Oct 19, 2009 | 2007 Yamaha XT 660 X
Red park light on dash blinks after running a while
The red blinking light is just an indicator that the motor has been revved up in neutral or park. I really don't know the importance of it, but I know you have to turn the key off and back on to get it to go off. Everytime I am checking a water pump on a grizzly that happens.
Jun 13, 2009 | 2006 Yamaha XT 660 X
2007 Yamaha grizzly 660 wll run fine, and then will die and is hard to start. Carbourator is clean. Does anyone have any suggestions?
CHECK VALVE CLEARANCES(INTAKES MOSTY) IS IT ONLY HARD TO START AFTER IT HAS BEEN RUNNING(HOT) OR IS IT HARD TO START COLD TOO?
Apr 29, 2009 | 2006 Yamaha XT 660 X
Grizzly Big Bear Atv Maintenance Free Battery Logo
314 people viewed this question
Top Yamaha Vehicle Parts & Accessories Experts
Coss
Andrew Taylor
Andrew Taylor
ray012965
Are you a Yamaha Vehicle Part and Accessory Expert? Answer questions, earn points and help others
