So I have the u draw tablet for the wii, I put the remote in the slot perfectly fine and then I started to load the game sponge bob. The tablet won't work. I don't know if it's either the pen or the tablet? I need help
4 Suggested Answers
aero26
  • 30 Answers
SOURCE: My Tablet pen wont release, it acts like im clicking and holding
I'm just gonna pass on a email from Tech Support I recieved.
"It sounds as though your pen has pressure in proximity. This is present when the tip sensor of your pen is stuck down causing the pen to think that it’s clicking before it’s even touching anything. What you may want to try would be to remove the nib from the tip end of the pen, it pulls straight out with a pair or tweezers or your teeth, and leave that out overnight with the pen left on its side. Place the nib back in the morning and if the issue persists then you may have a defective pen tip."
The rest consists of personal info and warranty advice so I'll leave it there.
Posted on Oct 13, 2009
  • 4 Answers
SOURCE: Pen keeps drawing when I lift it off tablet
This problem commonly occurs due to a stuck "nib" sensor (the sensor that detects pen pressure).
Take out the "nib" (important, so the sensor isn't damaged further) and whack the pen on your desk (or drop it on the floor from 3 feet up). It re-seats the "nib" sensor when it's stuck. If this doesn't work after multiple attempts, then the sensor may be too damaged.
Posted on Jan 19, 2010
SOURCE: Is it possible to remove features from a tablet?
I have the bamboo fun pen also. I am currently running Windows Vista 64bit home and have the same problem. I fixed mine by going into the control options > Tablet PC Settings > Other > Go to Pen and Input Devices > Settings (Under Pen Options) Then I clicked at the top Where it states "Enable press and hold for Right-clicking". I disabled that and my pen works with no holding for the right click. I can make scratch marks all day! Hope this helps you too.
Posted on Jan 28, 2010
Connection
try re-synching the remote to the wii and if that doesnt work re-install the game or buy a brand new not used copy of the game
May 19, 2013 | THQ Udraw Studio for Nintendo Wii
I recently purchased the 10 min solution game. I can calibrate the wii balance board just fine, and it works perfectly with any step aerobics that I do in the 10 min solution, however, if it switches to...
Here's what I think I figured out. The balance board powers off for the cardio boxing because it is not needed. The movements are measured by the hand remote and nunchuck not the balance board. The "bob" is still tricky to time right; great workout trying (sure hope I can walk tomorrow)! The trick is to move when the indicator square turns yellow. Good Luck! Hope this helps you!
Mar 04, 2011 | Activision 10 Minute Solution for Nintendo...
Second player's sound effects don't work. You can hear the noise for everything but the second player. There's absolutely no noise for it. Remote works perfectly fine; has brand new batteries in it. Game...
check that the red and white cables to the television are hooked up properly( correct holes and put in all the way) this happened to us and that was the problem.
Jan 25, 2011 | Nintendo Mario Kart (Wii) for Wii
How do you save your drawing to an SD card?
The SD slot is on the Wii itself, not the tablet. Insert the SD card and just save it from the Udraw menu.
This should solve your problem.
Dec 26, 2010 | THQ Udraw Studio for Nintendo Wii
Once the wii remote is plugged into the udraw game tablet the remote will not function
Make sure that the remote is conencted correctly. Also, you must place the Udraw in the slot after you have bypassed the Main Menu for the Wii. In other words, once the Udraw screen is up. Also, make sure that your batteries are good otherwise you will continually lose the signal. This should solve your problem.
Udraw doesn't work - brand new unit - connects fine - and navigation in menues works - but pen won't draw. What are we doing wrong?
Mke sure that you are pressing on the pen correclty and that your remote is properly inserted. Also make sure that your Wii is updated and free of debris on teh vents in the back. Try restarting after you have checked all this and you shuld be good to go.
Dec 25, 2010 | THQ Udraw Studio for Nintendo Wii
Wii console is working but controls are not. We have checked batteries in remotes and they are fine.
Take off the battery cover on the back of the wii remote and open the slot on the front of the wii where you put in the memory card:
http://g-ecx.images-amazon.com/images/G/01/ciu/09/d4/42196230a8a096736e5af010.L.jpg
Press the red button by where the batteries go in the remote and the red button by the memory card slot together and they should find each other and synchronise properly. If they ever lose synchronisation again just repeat the process.
Jan 04, 2010 | Nintendo Wii Console
My wii remote won't connect to my friends wii but connects to mine just fine
You will need to resync the remote back to your wii. Take off the battery cover and open up the flap on the front where you put a memory card in. Push the red button by where the batteries go on the wii remote and the red button above where the memroy card slot is, both the wii and wii remote should flash and eventually the first light on the bottom of the wii remote should flash indicating a successful sync.
Dec 29, 2009 | Nintendo Wii Console
I put my wii powersaves card into sd slot but they wont load
To use a wii powersave, you need to follow these easy steps.
1 Go on to the Wii oprion menue.
2 Go into the data management section.
3 Click save data
4 Click on Wii.
5 Click on SD card.
6 Search for your game title.
7 Click on it.
8 Copy the game data to your Wii.
Hope it helped!
Dec 30, 2008 | Datel PowerSaves with 512MB SD PowerSave...
New wii remote how to get started
Ok well first of all, you'r first remote is working fine right? Ok lets move on to the second remote. On the left of the wii there is a little hatch that you can open, in there there is the slot to insert a SD memory and there is a red button. Press the red button and wile that is hapenning grab the wiimote and pres 1 and 2 at the same time once. The lights on the remote should start flashing and it will be in sync all together.. And voila two wii remotes working fine,
-Alex
Nov 22, 2008 | Nintendo Wii Console
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
