Question about DLO Homedock Music Remote
My six year old DLO Homedock music remote went dead this weekend after our Mother's Day get together. Recharging doesn't help. It's still black & does not respond. Suspect dead battery. How do I get a replacement if this is confirmed?
Changing the name of a video after transfer to TV
Just go to itunes, right click a video, select get info them edit the details as you wish
Mar 05, 2014 | Digital Life Outfitters DLO DLO HomeDock...
I have a Vizio 37" HDTV that recently started losing the picture. The sound has been on continually but the picture now flashes steadily but mostly remains black. It went out one day, came back afte
it sounds like a backlight issue. It could be as simple as a few bad caacitors. If you already replaced the set and you just want $$$ toss it on your local Craigslist as a parts/repair set. There's always TV shop owner and parts scavangers that will buy the set as is. Price wise, if the set is in good condition and come with remote, and pedestal, I would ask $60 as is but you may get more
Mar 25, 2013 | Vizio VW37L 37 in. LCD HDTV
Blueparrrot B250 is 1 year old & it went dead so I
how do you know it is fully charged? i think it may be dead battery
Nov 06, 2012 | Computers & Internet
Deadphone after recharging, message says
try use a good battery. if it does not work, try check on the connecting pins on the battery connector of your cellphone. if still a problem, try disassemble the cellphone to check the battery interface on your cellphone, clean both connector and the interface of your cellphone... if still a problem, best to repair it to a nearest cellphone technician...
Jun 01, 2010 | Motorola Mobility RAZR V3
New RTI remote went black. Fully charged but nonresponsive.
Whenever possible contact an authorized RTI dealer in your area for support help!
There are a couple of reasons that a T1 or T2+ goes black. I understand that the screen does not light but if the buttons do not light either. The first most obvious reason is the battery is dead, even though it may act like it is charging. Pop the back off and check to see if the battery is slightly bulged. If so, it is for sure finished with its life. Further if the battery is over 2 - 3 years old it is probably done. Replacement batteries are available, but changing them requires more knowledge than just knowing how to use a Philips screw driver. The mother board battery connector is very susceptible to damage, so you must take great caution to hold the white mother board connector down gently on the edge with a small screw driver while you pull the white battery connector out.
Another potential problem area that will cause the screen to go off or become fractal is that there is an internal screw in the lower left that clamps the keyboard circuit board in place. This is also the ground clamp for the keypad illuminating surface. If this screw was not installed tightly the contact surface underneath will burn off. I have successfully repaired several of these by placing a triple folded small piece of aluminum foil in place of the burned out contact material under the screw and clear plastic illuminating sheet then tighten up the screw.
Only perform repairs if you are qualified to do so J
David
Master A/V Systems Integrator
www.soundandtheater.com/home.htm
Sep 27, 2009 | Rti Technologies Rti T1 Remote Control
My remote wont opperate at all,just went dead on me
My wife and I have decided to buy a new combo/dvd/vcr/recorder
as the recorder is about six years old, and given good service.
Sometimes repairs can drag on, and cost the earth to repair
Thank you for your help
Ken Jones
Aug 23, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Guages when crazy. Now won't even try to start.
You likely have it repaired by now but it sounds like a classic case of oxidized battery or cable connection (sometimes mis-diagnosed as bad battery but cured with new (clean) battery)
Feb 25, 2009 | 2002 Jeep Grand Cherokee
Battery keeps going dead. Especially if car not driven for day or two. KIA ran checks of electrical system but found nothing. Am on sixth battery. Newest one only 3 weeks old and went dead over weekend.
it may maybe that the alternator doesnt give out the specific amount of electricity to properly charge your battery. you may have to run some tests on the alternator itself to see if it is giving out the proper current to charge.
Aug 06, 2008 | Kia Optima Cars & Trucks
Picture on 42 in plasma went black
No recharging....just recycling. ILO S-U-C-K-S !
Dec 28, 2006 | iLO 2600 Television
DLO Homedock Music Remote Logo
Top DLO Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DLO Audio Player and Recorder Expert? Answer questions, earn points and help others
