Question about HP OfficeJet D135 All-In-One InkJet Printer
What is the problem and solution to error code 420 or 321
The fax fails to send. It dials, then it says it is connecting, becomes silent and then print the report with error 420 or error 321
  • HP Master
  • 1,679 Answers
Are you able to send fax to another # ?. Error 420 & Error 321 is mainly due to transmission of signals or incompatibility issue.
Try reducing Fax speed and turn off ECM from Fax menu and check.
Regards,
Sean
Posted on May 15, 2014
Riztech
  • 731 Answers
SOURCE: Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Posted on Feb 09, 2008
  • 57 Answers
SOURCE: FAx Error
I understand that you are receiving the error "fax not sent" and the transaction report Error 389*. while sending fax.
The issue that you are experiencing is due to communication, however please follow the instructions from the below article to get the issue resolved.
Here is the web document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=buu02549
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue that you are experiencing with.
Regards,
Lawrence
Posted on Feb 14, 2008
SOURCE: I don't want fax receiving confirmation report it waste my paper.
Go to menu (wrench)
Arrow down to Reports - OK
Arrow down to Fax Reports - Ok
Hit Ok at Fax Confirmation
Select Never and hit OK
Hit Cancel when done and it should now not print confirmations.
Posted on Jan 15, 2009
SOURCE: fax not working Error 388
We had the exact same problem. Static on the line. We had the cable company check and sure enough our digital modem for the phone line was bad. The new replacement fixed the problem instantly.
Posted on Jan 23, 2009
sanjay_tech
  • 20 Answers
SOURCE: HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Posted on Jan 26, 2009
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
We had a power outage and are having trouble faxing to China....It rings, seems to connect then gives no error code and puts the fax out for re-dial...Any suggestions on how to fix this?
Plug a phone into this outlet and see if you get a dial tone. If you do not you will have to call the phone company. If you can use a phone at that outlet but not your fax, then you know that the power surge that came when the power turned back on damaged a fuse in your machine. Joe
Mar 18, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
How fax says File full and will not fax any docs. How do we fix?
First I would plug a regular phone into the phone line to make sure it has a dial tone. Assuming that works send a fax to your cell phone and see if the fax machine dials out and makes your cell ring. Assuming that works check the fax for an error code as to why it is not faxing or failing.
Feb 11, 2010 | Panasonic UF-4000 Printer
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Jan 26, 2009 | HP Officejet 4315v All-In-One InkJet...
Error code 344*
Error code344 shows that The remote machine has failed to respond to a fax command from the product because the connection was interrupted.The remote user has pressed the Stop button while the remote machine was receiving.
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
check here for more information
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00062808#A5
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Error 344- Fax Function
Try to connect the phone line from the phone oulet directly to the line one connection of the machine.
May 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
Oct 29, 2007 | HP Officejet 7210 All-In-One InkJet...
HP OfficeJet D135 All-In-One InkJet Printer Logo
203 people viewed this question
Seeker5211
Seeker5211
